Question about Radio Communications
Wiring diagram cobra 3190 - Radio Communications
D-104 wiring to a cobra cb
Find your radio on this page and then look at the wiring diagrams
Oct 11, 2012 | Astatic D104 T - Ug8 Crystal Microphone...
Wiring diagram for cobra 29 ltd BT mic , when each color go
if you have another cobra mic that was previously used on a 29 it should fit . just about all 4 pin cobra mics are alike .You can even use them on Galaxy radios and others.
Jul 27, 2012 | Cobra Radio Communications
Burnt one of the lead power wires of plug in on the inside and do not have wiring diagram to see where it goes, where do I go to get diagram for the wiring of the Cobra LTD Classic.
I don't know how well that radio is going to work even if you repair the bad wire. You may have blown the protection diode, D23, which is an N10014, and easy to fix however, you may have done much worse. You could have blown the audio chip, and maybe even the PLL.
If you blew the PLL then it's not even worth fixing.
Here is all the information available for a cobra 29
Oct 23, 2010 | Cobra 29 LTD CB Radio
I tried to start my car this morning it makes a ticking noise and it doesn`t start. and alarm isn`t going.I have cobra 3190. How i can remove the alarm? plzz some help?
if the ticking noise is coming from the engine compartment, you have a dead battery. some alarms will not function when the voltage is too low, therefore you can't lock/unlock or arm/disarm the alarm.
Feb 21, 2010 | Vehicle Parts & Accessories
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Wiring problem on Cobra HG-M75 CB Mic
Pin-1-Shield-Ground
2-Yellow-Audio
3-Red-TX
4-Black-RX
notes:The blue & white wire not used.
Jul 03, 2009 | Cobra HG-M75 Microphone
I need Wire diagram for Cobra 29 LTD Classic CB
http://xbones_antennas.tripod.com/id21.html
May 03, 2009 | Cobra 29 LTD CB Radio
Need a engine wiring diagram for a 95 Mustang Cobra 302. Alternator is not charging and the wiring harness was hacked in by previous owner.
try these:
www.allfordmustangs.com/forums/attachments/94.
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-instrument-cluster.gif
or google: 1995 mustang cobra engine wiring diagram
PLEASE RATE MY ANSWER.
Mar 07, 2009 | 1997 Chevrolet Cavalier
Radio Communications Logo
81 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
