Question about Sharp Office Equipment & Supplies
I need the gear located just under the fusing unit for sharp fax fo6700
I really need the part number for this gear
  • Sharp Expert
  • 337 Answers
Service Manual
techbravo.net/sharpftp/SM-FO6700.pdf
Posted on Jan 30, 2013
I have a Sharp copier MX 2300G.It has developed a problem and it instructs me to call service under this code L4-02
The tray one lift up motor (angles the paper up to the feed rollers) has a plastic shaft that can twist and will need to be replaced. "To enhance the strength of the output shaft gear against twisting, the material of the
output shaft gear has been changed. Along with the material change, the colour has also
been changed from Beige to White." new part number is CCOVP1607FC438
Oct 14, 2010 | Sharp Office Equipment & Supplies
I have a sharp al-1631 copier. it was working fine and then i had a bad misfeed. the paper was crinkled like an accordion, but i managed to get it out of the fusing and area and below the fusing area. ...
You can not make any copies? Is this because it continues to jam every copy in the same location? At the fuser? If so then this means you have a quite common issue with this series of machine. You have a broken fuser drive gear. Part number NGERH0540FCZZ. I have included a picture of the part. All you will need is someone to remove the fusing unit (the part that gets hot) and replace the gear. You can get the part from PrecisionRoller.com
Good Luck and Thank You for using Fixya. Our solutions are being rated this month based on positive testimonials. If my solution is helpful please leave a short testimonial for me.
Thanks!
Oct 05, 2010 | Sharp AL 1631 Copier
Need part number for the green door latch it broke
I think this might be a futile effort. Check with Sharp to be certain But generally any machine that uses ink instead of toner is a throw-away unit because it's less expensive to replace than repair. In many cases the parts aren't and never were available.
Sep 21, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp sf 2014 copier problem
clean the paper feed rollers with soap and water damp cloth take paper tray out use flashlight to locate rollers also clean registration roller under the drum check and see if u have any broken gear teeth on your fusing assemby also if after cleaning it works i recommend u replace feed rollers
Jun 04, 2009 | Sharp Office Equipment & Supplies
How to fax?
You access the fax functions (if optional kit is installed) by way of the Image Send button on your panel. Press Image Send, then press the FAX key on the screen. dial as you would any fax when the number is dialed and the document is in the feeder, press the start (copy) button and you are faxing...
Les Olson Company, Sharps #1 ind. Dealer in the USA. Selling Sharp in Utah and Las Vegas with 7 locations to serve you.
Feb 03, 2009 | Sharp AR-M355N Copier
How many fax numbers can be stored on the FO-DC535?
You will need a larger unit with more memory 32mb.
Oct 22, 2007 | Sharp FO-DC535 Fax
19 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
