Question about Fujitsu Plasmavision PDS-4233 42 in. Television
No Image displayed
When power applied to the unit, and the power button pressed, the unit clicks once, a small hum and then the fans start up, but the panel doesnt ever light up. I have taken off the back cover and checked the two ceramic fuses on the power supply, and the two fuses on either side of the power supply (i am assuming they are the panel controller or something). Help is appreciated.
  • Ben Langberg Jul 04, 2007
    Will try sound throught the system, seems like it isnt even powering up at all. There is no backlight even powering up. The plasma screen when turned does not show any life...
  • Ben Langberg Sep 08, 2007
    Thanks guys, disconnected the inverter circuit, and sound did come on for about 10 seconds then the panel shuts down again. I have sent a email of to a service center regarding a power supply. Fingers crossed! Thanks for leading me in the right direction.
    Sergeant:
  • 279 Answers
If you haven't fixed this yet... it does sound like you need to replace the power supply panel, as techman suggested. I looked, but was unable to find a place to order parts for this unit online. However, I did find a list of Fujitsu service centers. I suggest calling one (or more) of them and asking where you can get parts for the unit. They should know, and while not every service center will share this information, in my experience most will. http://www.plasmavision.com/locate_serv_ctr.htm Hope that helps.
Posted on Sep 07, 2007
    President:
  • 3,130 Answers
If you get no sound but the hum, there is a problem on the power supply panel inside this TV set. The only way to repair this set would be to replace the power supply panel. But before you condemn the power supply panel, open the set and disconnect the back-lite inverter supply and make sure that is not loading down the TV sets power supply. You would not see a picture if you disconnected the inverter circuit, but the sound should come on. Good Luck
Posted on Jul 03, 2007
  • Larry  Dillon
    Larry Dillon Sep 08, 2007
    Oh and to the expert tech, what do you think this set needs?
SOURCE:
Hello... I have a Goodman CKL49 a/c unit on the exterior of my house. I have checked everything I can think of and isolated the issue to the fan motor not turning on. The unit will recieve the signal from...
Hello, try using a small object to push the fan with power applied to it, if this gets the fan going tnen the capacitor must be replaced. If the fan does not start up then the motor is shot and must be replaced.
Sep 02, 2011 | Goodman CKL49AR49 Air Conditioner
The page on-screen look thin and I want to make it wider image on screen. I need large text and page. How do I adjust the screen image?
You can make it by adjusting screen resolution. Right click on an empty space on desktop and go to properties, there click on Settings Tab. There you can see Screen resolution options. Drag the bar to adjust your display as you like. Once done click apply and OK
Mar 29, 2011 | Computers & Internet
When the mode button is pushed, I only receive the option of dehumidifying, or just fan. The manual claims it has a heat option but it is not available. A friend of mine has the same one and they have the...
Sorry to read about your problem, I hope this helps you out.
Their has to be a model difference issue . I have checked the Manuel and have put a copy of the section, for modes. and their is no heat only mode.
Your unit uses heat anyway, so i really do not know how, heat only would help you. I would say to look at the sticker on your friends model, and see if the numbers are exact.
Default Setting:
When the unit is first connected to a power supply, the electronic circuit board will automatically default to the following factory settings;
Mode: Dehumidifier Humidity Set Air Value:60% RH Fan Speed: = Low
NOTE: In the event of a power failure or the unit is switched 'Off', the most recent settings are retained and restored once the power is switched "On"/resumed.
IMPORTANT NOTE: Depending on the ambient humidity conditions, when power is restored or switched 'On' the dehumidifier may not start automatically under the factory or custom (see page 7) default setting. This is an indica- tion that the ambient RH% level of the surrounding envi- ronment is lower than the current default setting and it may be necessary to select a lower set RH% value.
DRY MODE SELECTION: 1. The unit does not have to be switched on (opera- tional) to select/set a program. All programs can be selected with the unit in the "off" position.
2. Press the MODE button until the Dry symbol is shown in the mode area of the display. Note: Each time the MODE button is pressed, the setting will alternate between DRY (dehumidifier) and FAN (only) mode.
3. Press the or cursor buttons to select the desired RH% operating value. To select CONTINUOUS operation,pressthe buttonuntilthesymbol"--" appears in the SET AIR display. During CONTINUOUS mode operation, the humidistat (control) will be by-passed and the compressor will operate non-stop regardless of humidity conditions.
FAN SPEED SELECTION:
4. Press the fan symbol on the keypad. Each time the button is pressed, the mode selection will alternate between "High Fan" and "Low Fan" speed options. The fan speed you select will appear in the LED display; either a 4 blade fan symbol for 'high fan' or a 3 blade fan symbol for 'low fan' will be shown in the display area.
5. When all settings are complete, press the I/O button to start the selected operation (MODE) and the blue opera- tion light will illuminate.
FAN ONLY MODE SELECTION:
1. Press the MODE button until the fan blade symbol is shown in the mode area of the display. 2. Press the "Fan" symbol on the keypad. Each time the button is pressed, the mode selection will alternate between "High Fan" and "Low Fan" speed options.
3. When all settings are complete, press the on/off button to start fan mode operation and the blue operation light will illuminate.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Danby DDR586R Dehumidifier
Display photo??
Greetings!
Hello lalandavis, regarding on your problem please check first your yahoo messenger if you have already uploaded your image/picture. then if you don't have upload yet please upload your image/picture in YM top view your photos in Ym. Otherwise if you have already done uploading then make sure you have click the share my picture in order for your photo/image to be visible in your YM. You can view you display image by clicking your picture and click the small arrow below the image or press "Ctrl + Shft + F8" buttons at once to view the display image tab.
Thanks
Jon
Dec 17, 2010 | Yahoo Messenger
When I turn on my nuvi 200 it says press dot. When I press the dot it just moves around the screen to different location.
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position. Once unit powers on release the power button.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 09/30/2010
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
I coonected my laptop to a philips model 32PF5320-28 and now i cant find what channel to put on so that i can see the image
from the Philips manual
To ensure the best picture quality from the PC
feature of this TV, several Picture Controls are
available for adjustment.
PC PICTURE CONTROLS
1 From the Source, choose PC-VGA or
PC-D mode (depending on the cable used
to connect the TV from the PC). Refer to
page 22 and follow the steps in “How to use
the Source List”.
2 Press the MENU button on the remote
control to display the Picture menu.
3 Press the CURSOR RIGHT button to
access the Picture menu.
4 Press the CURSOR UP or CURSOR
DOWN button repeatedly to select any of
the picture items:
Brightness – adds or subtracts light from
the darkest part of the picture.
Picture – improves the detail of the lightest
parts of the picture.
Horizontal – Allows you to adjust the
horizontal placement of the image.
Vertical – allows you to adjust the vertical
Color Temp. – Allows you to adjust the
color temperature of the picture. Select
from Normal, Cool, or Warm.
5 Once you have highlighted a selection,
press the CURSOR LEFT or CURSOR
RIGHT button to navigate, adjust, or
activate the specific controls.
6 Press the STATUS/EXIT button to
remove the menu from the screen.
To enable the dual monitor feature of your notebook, first ensure that the
second monitor is connected, then, select Start, Control Panel, Display and click
on Settings. Select the secondary monitor (2) icon in the display box and then
click the check box Extend my Windows desktop onto this monitor. Finally, click
Apply to confirm the new settings and click OK to complete the process.
should be channel 3 for selected channel
May 01, 2010 | Philips Televison & Video
OKI C8600 Replace Image Drum - 563: K Drum Life
Solution:
  • Power on printer while holding both the + & - buttons simultaneously; release when “OKIUSER” is displayed.
  • Press either the + or – button until “ENGINE DIAG MODE” is displayed; press the Enter button and “DIAGNOSTIC MODE xx.xx.xx” will be displayed.
  • Press and hold both the - & On-line buttons simultaneously until “ENG DIAG LEVEL2” is displayed.
  • Press either the + or – button until “CONSUMABLE COUNTER SET” is displayed, press the Enter button; you are now in the menu to set various consumables.
  • Press either the + or – buttons to scroll through the various consumables, at the desired consumable press the Enter button and the last digit of the count will start flashing.
  • Press the Cancel button to decrease the digit amount or press the On-line button to increase the digit amount; press the + or – buttons to move along individual digits in the count.
  • Once the count is at the level you desire, press and hold the On-line, Cancel, & Back buttons simultaneously until the “*” reappears next to the count; consumable’s count are reseted to the number you specified.
  • Press the + or – buttons to move to the next consumable and repeat at step 5.
  • Once all consumable counts have been set to desired amounts that are below their end-of-life thresholds, you can use the Back, +, & - buttons to exit through the menus
  • until “INITIALIZING” is displayed.
Oct 14, 2009 | Oki Electric Industry C8600n Led Printer
Thermostat display has an image of a flame
Sounds like the circulating fan on your furnace is not running. This will cause the furnace to shut down due to overheating, and you can smell the overheating as well. You will probably have to press a reset button on the burner to clear the overheat shutdown. Check the fan belt if there is one. If no belt you have an integral motor. Remove all power from the system and make sure the fan spins freely. If it doesn't, try to work some oil into the bearings. These things always fail on a holiday, but if you can't get the fan spinning you're going to have to call in a HVAC specialist.
Jan 01, 2009 | Honeywell Programmable Thermostat Heater
Window AC unit
See if your motor is okay 1st. Find your wires feeding your Fan motor. (This means the 2 power wires L1 & L2 if 220v or L1 & N if 115V) Carefully put the power to these 2 wires and see if you hear the motor hum or start. If it hums the run capacitor could be bad.Try spinning the motor with the power applied. If it starts most likely the run capacitor is out. If it starts without you helping it the control board or switch is most likely out.
It is possible the unit has a energy saving setting. If it gets locked into this the fan may not run.
If the unit has electronic controls and an electronic display read out, the board is the most likely suspect. Unplug it and see if it resets.
If not then the board is probably out with a stuck relay or stuck program. New board time. Or replace the unit.
If it has a rotary or push button type control then either of these 2 switches are suspect.
Jul 12, 2008 | Fedders AEQ07FBG Air Conditioner
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Press the OK/MENU button and then press the right arrow button to enter the Mode Menu. Press the down arrow button until the SETUP tab is highlighted. Press the right arrow button and then the down arrow button until PIXEL MAPPING is highlighted. Press the right arrow key, which will highlight START. Press the OK/MENU. The back of the camera will display an indicator bar with the word BUSY. Once Pixel Mapping is completed the Mode Menu displays. Press the OK/MENU button to resume normal picture taking. The bright dot should no longer appear in your downloaded images.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Fujitsu Plasmavision PDS-4233 42 in. Television Logo
213 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
