Question about Cooper Wiring Devices 277W-BOX SINGLE POLE SWITCH & RED NEON PILOT LIGHT
Problem with Night Light setup for Cooper 277.
Im trying to wire a light to a Cooper 277 pilot switch. The # 2 diagram in the instructions say to wire a jumper from the brass screw to the silver screw in order to get the pilot light to be OFF when the switch is ON. Of course this only feeds the hot back thru the neutral and shorts everything out when you turn the switch on. What am I missing here?
3 Suggested Answers
dogsled48195
  • 411 Answers
SOURCE: Common feed Single Pole Switch
The big slot is the white wire ground is the green screw small slot is the black wire the 2 screws next to each other is the hot
Posted on Feb 19, 2011
SOURCE: I am trying to wire
Open following link for cooper 277 wiring illustration:
http://waterheatertimer.org/images/Cooper-277-pilot-400.jpg
Wired as shown in illustration, the pilot light and the Load will come on each time switch is turned on.
The illustration show Load is light bulb.
In your case, the Load will be an outlet instead of light bulb.
So the Load will have 2 wires. The black wire from switch connects to brass screw on outlet. The neutral connects to silver screw.
Bare ground wires connect to green screws.
Posted on Jul 04, 2011
Westinghouse fan wiring diagram
Copy following link for general assistance wiring 4-wire ceiling fan switch:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Jul 14, 2012 | Electrical Supplies
Wiring diagram for a p i r to lights
Copy following links for basic switch wiring:
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#rocker
Jan 17, 2012 | Home
Wiring diagram for time clock with photocell contacter and bypass switch
Copy following link for possible wiring diagrams showing photo eye and contactor:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#photo-eye
Dec 15, 2011 | Home
I have a cooper comb devces how do i wire i want switch to control the plug
The Cooper combo device requires neutral wire to energize the outlet.
To control outlet with switch, the Hot side of device must have break-away fin.
Remove break-away fin.
Connect jumper wire from switch load side to outlet Hot side.
Open following link for instructions with illustration:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#combo
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical wiring or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 20, 2011 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
I just purchased a Cooper Wiring Device 277W-box w/pilot light. The current switch in my home is next to another light switch which operates my hallway light. The other switch (the one I want to install...
Open following link for wiring diagram with written instructions.
Some of your wiring does not sound up to code.
1) Two differences between regular switch and cooper 277
-Different color screws: Regular switch has two brass screws, and either wire can connect to either screw. Cooper 277 has dark, brass, silver screws, and hot wire connects to dark screw, and wire to light connects to brass screw.
-Cooper needs neutral wire connected to silver screw, to power the indicator light.
2) Some of the wiring in your box does not sound up to code.
Bare ground wire should not be connected to black and white wires.
Electrician should check this out.
Probably the ground wire is being used as a Neutral. Bare ground wires and white neutral wires both connect to neutral busbar at main breaker box.
Aug 22, 2011 | Hardware & Accessories
I am trying to wire a cooper 277 swich to control an outlet. I am having a hard time getting it to work. I have followed the wiring diagram with no luck. I would like the Pilot to be on when the switch is...
Jul 04, 2011 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
How to install 692 series light switch
P&S 692 is pilot light switch.
Pilot light requires neutral wire. Neutral wires are white wires twisted together and covered with wire nut located in back of electric box.
P&S 692 wires same as Cooper 277
Jun 20, 2011 | Pass & Seymour #692LAGCC6 15A Almond SP...
77020 fan switch dont turn off. i need a diagram please...
Copy following link for wiring 3-speed fan switches
May 25, 2011 | Speed Ceiling Fan 3-speed Switch By...
I need the wiring diagram for a Cooper 277W single pole switch with pilot light. The light is to be on when the switch is on. Thanks!
I have 120Volt cooper 277 pilot light switch here in my office.
Dang instruction sheet shows wiring for all kinds of cooper devices.
EXCEPT pilot light switch.
So I tested with multimeter and came up with following:
Key to any wiring device is color of screws.
Hot from breaker box always goes to dark-colored screws.
Neutral always goes to silver-colored screws.
Brass screws are for Hot wires from breaker or Hot going to Load
Green screw - ground
Dec 03, 2010 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
Cooper Wiring Devices 277W-BOX SINGLE POLE SWITCH & RED NEON PILOT LIGHT Logo
85 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
