Question about Water Heaters
Need to install the Zhq1821sh heater, so i need the manual
You need the name brand plus the model and then I could possible help you
Posted on Jan 07, 2013
Where can i download the manual for a thermor water heater"?"
www.reliancewaterheaters.com/lit/spec/2006ServiceHandbook.pdf
May 07, 2014 | Reliance Water Heaters
Damper stuck
Unknown if this is new installation or older installation that stopped working, so we're guessing
Damper is sold separately. Refer to part numbers in product manual.
http://waterheatertimer.org/pdf/Whirlpool-flue-damper-manual.pdf
http://waterheatertimer.org/Review-Whirlpool-Flue-damper-gas-Water-Heater.html
Call whirlpool Warranty and Service department 1-877-817-6750/ 12 years parts coverage for single-family residential installation when installed by code and information shown in product manual, and maintained as showing in product manual.
Clean air intake located on bottom of unit as shown page 24-25 product manual... the problem might be not enough incoming air supply.
Review manual for correct venting.
Check outlet for 80% rated voltage and for correct polarity, and for ground continuity with manifold tube located under gas control valve.
Troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Call local service technician. Call installer.
May 06, 2013 | Water Heaters
Bought a rheem rete 13 off ebay
Question posted under Rheem tankless water heater:
Call Rheem at 800 432 8373
They will need serial number located on label on side of unit.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Usually I recommend that people tear out their tankless water heater and sell it on ebay, and then install tank-type heater from different manufacturer:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
I would be very reluctant to connect used gas appliance without a product manual, and service manual.
http://waterheatertimer.org/images/Exploded-house3.jpg
Mar 19, 2013 | Rheem Tankless Hot Water Heater...
How can i install my hot water heater model 71-408 b
71-408 is probably electric water heater.
Unknown brand, unknown type.
Water heater comes with product manual with step-by-step instructions.
Example instructions:
http://waterheatertimer.org/pdf/How-to-install-electric-water-heater.pdf
If this is under-counter model:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Oct 25, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Whilpool hot water will not light
Unknown if this is new heater, or heater that worked before.
1) New heater: more information is needed about installation, type of gas valve, and what you have tried so far.
2) Heater that stopped working:
Manual is good start point, and then add a comment with which type of heater you have and what you have tried so far:
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
Problem can be simple or complex: dirty combustion parts and tubes; thermocouple is bad if gas control valve is not-electronic type; bad gas control valve thermostat; overheating tripped ECO because of bad thermostat or dirty burner parts; lockout due to FV event and exposure to flammable vapors; air in gas line need to be bled off; overly hot environment needs better ventilation; bad air supply because air intake needs cleaning; bad venting or downdraft or tight house needs ventilation; deteriorated burner parts need replacement because of moisture leak or exposure to chemicals; etc.
Open following link for some troubleshoot resources and illustrations and more reading.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 12, 2011 | Water Heaters
Water doesn't stay hot PowerStar AE3.4
Are you using a single lever faucet? The install guide does indicate that you may need to reduce the input from the cold water side to ensure that water stays at a consistent temperature (see page 7 of the installation and service manual). Also, remember, this is a SMALL hot water heater. So if you're running for any length of time at full output, it may not keep up with you (see page 8 of the service an installation manual). I found the manual online at http://www.airwater.biz/images_templ/bosch-water-heaters-ae3.4-manual.pdf.
Jan 24, 2009 | Bosch PowerStar AE3.4 AE3.4 Point-of-Use...
Water Heaters Logo
26 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
