Question about Vector 2000w Power Inverter
Who can I contact for Technical Support converning my Vector 2000 Watt Inverter
The green and red light comes on but no power and the lights fade out.
SOURCE: my vector power inverter needs to be reset
Inverters use high power transistors to create an A/C voltage from a D/C input. These transistors are the common point of failure when the units are not cooled properly or used beyond their rated capacity. (Actually, you should always buy an inverter that’s rating for continuous use is well below what your actual need is). What’s most likely happened is that these have shorted out and need to be replaced. Unfortunately, replacement parts alone will likely cost nearly what a new unit costs.
Sorry to be the bearer of bad news; but you basically have a nice paperweight with some pretty lights and fans on it.
Posted on Aug 15, 2009
  • 172 Answers
SOURCE: i have a vector 3000 watt inveter red fault light
Check that ground is correctly connected. If nuetral is provided, ensure it too is connected. Your total load is 780 watts. Check power in and ground out of the supply side. There may be a fuse in the inverter on the output side also, replace if necessary. If fault light does not go out after these checks, you will need to contact Black and Decker who manufactures the vector series now.
Posted on Jan 16, 2010
  • 608 Answers
SOURCE: vector 2500 watt inverter red led fault light no
There is a fuse on these things at the back of the case. Could be in a slide out plastic holder, or in a round holder with a knurled screw or bayonet type cap. If this fuse is not blown, then the news is not good.
Posted on Mar 21, 2010
nitrospawn
  • 290 Answers
SOURCE: Bought a new vector maxxsst 1200 watt inverter
Inverter run on batteries sir, and if these batteries are not charged, the run time {the number of hours it will work} reduces.
S0, you will need to connect the inverter to a power source.Theses will allow your batteries to be charged and enable it to run for a long period of time.
Make sure your batteries are still OK.i.e working properly
Posted on May 04, 2010
  • 185 Answers
SOURCE: (Vector 400 Watt sst Power inverter) When I plug
I am assuming that the inverter works with other devices. This being the case, i am thinking that the television start up current is drawing too much power too quick for the inverter to handle and this is what is shutting down the inverter.
Posted on Feb 06, 2011
Westinghouse 32' flat screen tv .red power light comes on .when turned on screen shows westinghouse symble then fades away .green light stays on then tv turns its self off.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 22, 2016 | Westinghouse Televison & Video
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Jun 04, 2012 | Pride Jazzy Select 6 Indoor Power...
The red light is on on my ps3 but when i turn the power on the green light comes on then goes back off
That's is hardware problem.
Buy new motherboard and this will solve your problem
People think it is the power supply but it is not. Replace the motherboard and this problem will fade away.
http://www.ifixit.com/Guide/Repair/Installing-PlayStation-3-Motherboard/3493/1
Rate if you think this helped you.
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
I have a vector 750 watt inverter (vec1047bd). The charge controller in my photovoltaic system went bad and I had it repaired. When I got the controller back, my inverter did not work. The inverter has a...
If you have a manual for the inverter check and see ifDin there are diagnostic codes with the LEDs.
http://documents.dewalt.com/documents/English/Instruction%20Manual/Vector/VEC1045.pdf
I looked through this and your description of the problem was not listed in the document, but you may be able to contact the manufacturer and get more information. Basically this is a DC to AC power conversion device, which takes the 12v DC input and converts it to 115V AC
and in does so at a maximum peak power of 750 watts at 115V AC. since your charge controller went bad, it is possible in the process it overloaded this device or the battery system put out too low of a voltage when the charge controller died and low voltage input is not something this unit was able to tolerate. Check your remaining components to be sure they are good, then look at the inverter's board and transformer to see if anything was damaged. I would want to verify the charge controller was good and the batteries in good condition - and perhaps consider replacing this inverter with one more suited to your actual load wattage requirements.
Nov 19, 2017 | Vector VEC1047BD 750 Watt Power Inverter
With the vector 2000 watt converter do you need to run 2 batterys.
well unless you bought the 24 volt unit no one battery will run the unit, according to black and decker this unit is not being made, did you buy it new or at a yard sale?
one way to tell is look on bottom of unit, it will tell you if it is 24 or 12 volt model.
Mar 06, 2011 | Black & Decker Vector MAXX SST Series,...
I bought two veco51d 3000 watt inverters made by vector and conectted with two positive and two negative cables to a good battery 12.6 volts load test at 750 cranking amps and both inverters light up and...
Hello, I hear you. Was the reason to supply 240 volts? When you try the inverters separately, do you get 120Volts output? Let us look at the units working individually first and go from there.
Feb 06, 2011 | Vector 3000 Watt Continuous 6000 Peak Dc...
I am trying to hook up to my new comp. and new internet and the lights come on for the wireless, wired and router r green then the modem light is red, what am i doing wrong
There is nothing wrong with your modem. There are modems that when you turn it on, the wireless, dsl lights are green while the power light is red then after a few seconds, the green lights disappear and the red light will turn green. After sometime green light will come back on. This means your modem is restarting and doing a self check.
If the power light stays red, then you a have a problem with your modem.
Sep 10, 2010 | Computers & Internet
May 03, 2010 | Vector ® Maxx SST 1200 - watt Power...
Vector 2000w Power Inverter Logo
32 people viewed this question
Top Vector Electronics - Others Experts
Craig Butler
Craig Butler
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
