Question about Husqvarna Sewing Machines
I lost the plug for my beloved husqvarna sewing machine. can i buy another one
It is an older model,
  • Husqvarna Master
  • 7,365 Answers
What is the model number of the sewing machine?
are you wanting a power cord for the machine?
Posted on Jan 07, 2013
RickE1
  • 202 Answers
SOURCE: Viking Husqvarna model 6440 gets stuck in reverse
There are numerous things that can cause this, some very simple, some less so.
1. Fortunatly, the most common one is also the simplest to cure. When you turn the selector (upper left) knob between stitches, one of the things that is happening when you feel the resistance is that it is lifting the followers off the camstack so that it can move to another stitch. When the camstack is normally doing its job, lifting the feed cam follower is what puts the mechanism in reverse. So, while the selector is between stitches, the machine is temporarily in reverse. Also, the dots where the dial is to be placed to change the camstacks is between stitches, so if the dial is on these dots or anywhere else except snapped into a stitch, you will get nothing but reverse.
2. The buttonhole mechanism is stuck in the reverse portion of the buttonhole. Usually if this is the case, the needle position will also be stuck on the left side, and the width control /buttonhole control will not function correctly. Usually you can correct this yourself and I'll explain how in a bit. It is usually caused by lack of use of the buttonhole mechanism.
3. Either the arm that connects the camstack to the stitch length block or the block itself is stuck. Both these parts are spring loadedto bring them in the forward position, so long periods of rest are a contributing factor.
All of these causes except for the first one are because of the mechanism not being exercised frequently enough. These older Vikings do not like to sit still very longYou should fully exercise all the knobs at every sitting.
Ok, try this fix. And this is to free up the mechanisms that are probaby stuck from non use and old oil and grime buildup. Take your seamformer (cam) out of the back. Find a hairdryer and blow some heat in there for awhile. This will soften up any hard oil or grease that may be causing the mechanisms to stick. Then if you can it would be best to have what is called TRI-FLOW oil (the BEST) and spray or drop quite a bit into there covering the mechanisms and let it soak in. You might try a good sewing machine oil soaking or WD-40 in small amounts. Little by little test your knobs, slowly working whatever is stuck lose. Never force the issue. Small amounts of movement little by little will eventually free it up.
Good luck. Hope this helps. If this does not help you may have to take it to a technician and hopefully you won't find out that your take up slide isn't broken which is a major job.
Posted on Nov 25, 2007
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
  • 636 Answers
SOURCE: Sewing machine Homemaker Everyday model HMFY-2300
Try this site manuals online , down load for free.
Posted on Jul 26, 2009
  • 371 Answers
SOURCE: husqvarna sewing machine - viking 400
Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
Posted on Sep 24, 2009
  • 371 Answers
SOURCE: I need the instruction manual for a Husqvarna 1050 sewing machine
Checking with an authorized Husqvarna Viking dealer. They should be able to order a replacement manual from Viking for you. Check Husqvarna Viking website for dealer closest too you.
Where can I find an instruction book for a Husqvarna Orchidea sewing//embroidery machine?
Is this your machine... ?
If so, then Try this following link, it might be what you are looking for?
Husqvarna Orchidea Manual PDF Download
Mar 04, 2015 | Husqvarna Sewing Machines
Husqvarna designer 1 lost mains lead
Call your local husqvarna sewing machine dealer. If they don't have one they might be able to offer an aftermarket alternative.
Oct 20, 2012 | Husqvarna Designer I
6440 husqvarna sewing machine needs repair and replacement parts are difficult to acquire. where to get repair?
Try here http://www.sewingpartsonline.com/viking-6440-sewing-machine-parts.aspx
If your needed part isn't available there... The only hope in that case is to find another Husky of the same model and use one or the other as a parts machine. (or part out your Husky and buy something else with the earnings..... just don't buy new plastic ones)
Aug 24, 2012 | Sewing Machines
Operators manual for husqvarna viking sewinmg machine
What is the model of the sewing machine?
http://www.ismacs.net/free-sewing-machine-manuals-list.html
This site will give you 150, 180 and 190 manuals.
Jan 07, 2012 | Husqvarna Sewing Machines
I can't find the plug and cable that came with the machine. Is there anywhere I can buy one? Thanks
If you are in the USA (110V) then try this website
http://www.sewingpartsonline.com/husqvarna-viking-215-sewing-machine-parts.aspx
If your country is 240V then you may need to purchase the power lead from a UK website or your local Husqvarna Viking agency.
Apr 26, 2011 | Husqvarna Huskystar 215 Sewing Machine
I need a Sewing Manual for a Husqavarna 950S.
The 950s instruction book is probably out of print as it is an older model. A great sewing machine for sure! You can call Husqvarna Viking at: 1-800-474-6437 and they may be able to get you a photo copy of the original owners manual.
Aug 23, 2009 | Husqvarna Sewing Machines
Missing bobbin case and bobbins Husqvarna 4000-serie sewing machine
ask where Husquvana machines are sold. google dealers if you don't know.
Oct 24, 2008 | Husqvarna Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
