Looking at the carb from th left side of machine which one is the high speed and which screw is for the high speed. One is longer than the other bu nothing is marked on carb
SOURCE: Homelite Blower HB180V carb adjustments.
Hi
high speed H=2 turns ,lowspeed L=2 1/2 turns
they are inscripted near the adjusting screws.
regards savumihai71
SOURCE: poulan pro bvm200 leaf blower/vac won't run on high
Is the exhaust spark arresor screen clean? a blocked exhaust will do this.
SOURCE: Probglem:Machine would run for 15-20 seconds and
i had a similar problem last year. finally took it to a repair shop..they replaced the diaphram under warranty. seems to be ok now, though i am not overly impressed with this machine
SOURCE: Trying to adjust carb on hb-180v model
Here is how to adjust a Zama diaghragm carburetor:
http://www.zamacarb.com/tipspage.html
SOURCE: I have a Toro 524 with Tecumseh engine, model
The high speed mixture screw is initially set at 1 & 1/2 turns out. Then adjust it to give good acceleration and top speed, while not closing the screw more than you need to. The low speed mixture screw is set at 3/4 of a turn out. Adjust that, to give a smooth idle. The 3rd screw, the idle speed screw, is set to give a low idle speed without stalling.
