Question about Sony VAIO Digital Studio PCV-RS220 PC Desktop
Sony pcv2222 after pop noise itwill not power up replaced the power unit it still will not power,up doe it have a fuse some where
  • Sony Master
  • 5,660 Answers
Fuse?
No
Suggest you check the Electrolytic Capacitors on the motherboard.
(Radial Aluminum Electrolytic Capacitors to be more specific)
Sounds like one popped.
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://www.hardwaresecrets.com/article/595
http://www.hardwaresecrets.com/article/616
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 07, 2013
What would cause new fuse to blow when powering on (Sony STR-DN1030 Receiver).
Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Sony STR-DN1030 7.2-Ch. Wi-Fi Network A/V...
Hello ? !!
umm you either fried your battery, the power supply blew, or theres a fuse in it that blew for protection. first thing i would try is take the battery out and try plugging it directly into the wall, if it turns back on then your battery is shot,if not the power supply within the camcorder blew which could be a small transister or diode and would have to be replaced,or could be a small fuse that went pop within the camera. http://www.sony.co.uk/product/sdh-digital-8/dcr-trv250e/tab/manual here is the manual if you don't already have it. it may tell you if there is a fuse. either open it up and check the camcorder power supply where you plug in and see if theres any black around anything and if there is then thats what needs to be replaced.or if you dont think you can do that then take it in to the repair shop for servicing.
Jan 02, 2010 | Sony Handycam DCR-TRV250E Digital...
No power to Insignia dvd player.
Pop the top of the DVD player and check the fuse. It's located right next to the AC power plug on the inside. If the fuse is OK, replace the DVD player. Repairs cost more than a new unit. Sony has DVD players from $ 40. Any repair on any device would cost more than that. If your lucky, the unit just took a surge and blew the fuse. Hope this helps
Oct 14, 2009 | Audio Players & Recorders
My str-k502p stopped showing the lights on the front. everytime i plug it in it makes the clicking sound like its on but nothing shows up. when i try pressing the power button all that happens is the...
Check fuses on unit .Fuses should be on right side of amp .If all fuses are okay.If a fuse needs replacement .Replace with same type and always make sure unit is unplugged .Its possible unit needs repair
Jul 20, 2009 | Sony Audio Players & Recorders
SONY VPL-CS3
Hi there
Replacing the lamp won't make any difference at all.
If you have checked the fuse on the Powersupply Board and it tested ok , then the whole Board will need replacement.
Apr 29, 2008 | Sony LMP-C121 Projector Lamp for VPL-CS3,...
Noise and popping on Sony STR-DA3ES
Sounds like its going to square wave clipping and poking a dc offset at your speakers. Happens when the amp reaches power supply ceilings. Pink noise such as "rain sound" will push the output stages and power supply to limits. If its on all channels, check power supply caps and check for dry solder joints. also look for that crappy brown hold down glue that goes conductive/corrosive. check all output stages particularly about discrete output devices that are attached to heat-sinks. They have a bad habit of dry jointing also. Good Luck
looked for a free manual on line for you
http://www.nodevice.com/manual/Sony/page139.html got heaps... but not your exact model. You may be able to cross reference one
Feb 03, 2008 | Sony STR-DA3ES Receiver
Popping sound then no power
Hi! I think something to do with power supply.Try using different power outlet or have to replace the fuse inside the unit.If your tv is withing the warrenty dont open it,call samsung
Dec 12, 2007 | Samsung HP-R4262 42 in. Plasma Television
Problem with Pioneer Plasma
Pioneer has a power supply recall on some models. Do a search and you will find a number at Pioneer and they will replace your power supply for free. The loud popping noise and then nothing is a common problem with these. Hope this helps!
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Nov 30, 2007 | Pioneer PDP-505CMX 50 in. Plasma...
Loud bang, unit stopped working
I have seen the caps in the power supply vent, which means they get hot and the top pops up and splits open, resulting in the "bang" sound. If you have experience in electronics then remove the back of the set and examine the power supply, looking for any caps whose tops are bowed upward, and replace.
Jun 24, 2007 | Sony FWD-50PX2 50 in. Plasma Television
Power surge knocked out my pic and sound
The noise you hear is the degausing coil and n Sony TV's they are an indicator that the main fuse is good. Your power supply has no other fuses to replace. they are not easy to troubleshoot.
Feb 08, 2007 | Sony KV-32S26 32" TV
Sony VAIO Digital Studio PCV-RS220 PC Desktop Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
