Question about Acer Aspire 7250-bz600 Laptop
My volume is stuck on high. How do I fix this?
I cannot turn the volume down. It is stuck on high.
  • fritzsancart
    fritzsancart Jan 09, 2013
    I have tried these technics a couple of times to no avail. Any other suggestions?
  • Acer Master
  • 7,627 Answers
Open the Control Panel, Sound, adjust volume, OR Click on the Sound Icon in the Tray Notification Area, adjust sound. OR reboot the machine.
Posted on Jan 07, 2013
  • max carson
    max carson Jan 09, 2013
    Open Device Manager, Sound, uninstall the audio device, reboot. Windows 7 should ID the Audio and install the correct driver. If not ,the Audio Driver (6.0.1.6358) can be found here :http://support.acer.com/product/default....
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
Volume on 1999 Nissan Altima
fine tuner spray in the switch
Jan 28, 2014 | Nissan Altima Cars & Trucks
Coby rc 057...when I turn the volume up the volume keeps turning back down all by itself. How can I fix this?
your button for got stucked for down...it always pressed that`s why after you make it high,it automatically comes to low.un plug it and try to clean the sorroundings of this button(if there `s any sticky dirt)
Jan 26, 2014 | Televison & Video
Ht-2004 volume down button stuck, no sound
Remove button and maintenance work has extended the spring
Jan 25, 2014 | Audio Players & Recorders
32'' insignia TV volume stuck down
This may turn out to be a failed component internally.
Dec 31, 2013 | Insignia Televison & Video
Volume knob doesn't work. Stuck on high volume.
you will have to open the unit up if under warrenty take back to shop! your volume nob needs replcing as inside its shorted out. Maplins or RS componets. For the effort involved you may want to buy a new radio. :-)
Nov 28, 2009 | Eton FR1000 Radio
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
Aiwa CXZL 31 volume button seems stuck
all u have to do is turn the volume down once then bang it against the door 5 times...it should be fine...
Jan 04, 2009 | Aiwa Audio Players & Recorders
Volume control
check the volume switch
Dec 31, 2007 | Symphonic ST420FF 20" TV
Acer Aspire 7250-bz600 Laptop Logo
660 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
