Question about Kenmore 55609 / 55602 / 55604 / 55606 Side by Side Refrigerator
Ice maker won't work
There is water to sol. but the ice maker won't run the water in ordo any thing there is water to the door, but the ice maker won't cycle. It just stopped, it was making ice fine one day and quit the next.
    President:
  • 1,214 Answers
Several issues can occur with this icemaker, the most common one being the shut off arm (the wire arm on the right hand side of the ice maker) is lifted into the off position.
Or, there has been
1) Mold thermostat failure
2) Mold heater failure
3) Motor failure
4) Fill switch failure
5) Water fill valve failure
Posted on Jan 20, 2009
There are usually two solenoids one for the water and one for the ice, you can trouble shot by switching the wires on the solenoids and see if you can still dispense water. If you can then the icemaker inside is where you problem is and it is easy to replace usually one elctrical connection and thwo maybe three screws and can be purchased online...
Why is ice maker making small cubes?
Low water pressure can make small cubes.
Feb 14, 2016 | Refrigerators
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
Fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Frigidaire Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
My ice maker on Maytag MF12468AE stopped making ice. When I add water to the tray, the cubes form but are not ejected. Is the the water valve bad or is the entire ice maker itself bad?
The ice maker is bad and they have been discontinued by the manufacturer. Luckily, there is a replacement part that works in your machine, part number W10477228. The reason I say its bad is because it should have atleast ejected the ice that was made when you poured water in it if it were working properly. The only other thing it could be is that the temperature is not cold enough in the ice maker area, which is 10 degrees F or colder. If the temperature isn't at least that then the ice maker won't cycle at all.
Jun 05, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice maker works and you can get water . The ice will drop down but the Door on the ice maker won't open
you will have to repl the door sol and mech as this mech unit has failed . it come as a cmplete assembly .. mm
Aug 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
My Maytag refrigerator has an ice maker that will not shoot out ice. the ice maker will make ice and send ice to the door where it comes out but the door needs more pressure in order for it to open. I can...
the door has a solonoid the opens it and is not working . ice does not put the pressure on the door. look for bad sol. or linkage to sol . or bad pc board that tell it to open .. ****
Jan 12, 2010 | Maytag 25.6 cu. ft. Side-By-Side...
Ice maker does not work, also water thru door does not work ,I feel that it`s nothing big cause no noises or anything else
some model's use a 3 sol valve in back and the 3 rd sol has failed . replace the water valve and it will solve problem probably . thery are like light bulbs . good today and so on .. if your model is a filter model repl the complete valve and filter when serviced .. mm
Jan 05, 2010 | Refrigerators
check the position of the strippers in the icemaker. normal "home position" is at the 2 o'clock facing the front of the i/m if the strippers are in any other position most likely you have a bad motor module on the i/m pt# 628366 (whirlpool part number) should fix it up for you.. Good luck Peyton
Jan 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 55609 / 55602 / 55604 / 55606 Side by Side Refrigerator Logo
141 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
