Question about Fisher and Paykel Dishwashers
My single draw dishwashing wont start i turn it on it beeps 3 times then turns off
  • Fisher and P... Master
  • 3,247 Answers
This could be caused by some sensor problem which prevents the controller from starting.
Please provide model number. Take a clean damp cloth and wipe all the buttons around the drawer panel including the edges.
If this makes no difference then most likely the problem is more deaper. Things like drawer close sensor or lid seal actuator could be faulty.
Posted on Jan 12, 2013
SOURCE: Dishwasher beeps 3 times and won't start
I finally solved this problem by doing the following:
I removed the front plate, this can be done by removing the two round plugs one on each side of the lower front of the washer just above the rack. once you do this the front comes off, then you remove the ground wire. From the front upper right there is a photo sensor in two plastic tube, make sure they are in correctly and not slipped out of position.
My washer, it appears the plastic casing that is holding the circuit board and the sensor broke off on one end, I simply taped it to the main body by using electrical tape and made sure it was secure.
I put everything back and now my washer doesn't stop anymore.
Posted on May 31, 2009
  • 713 Answers
SOURCE: I have a single draw Fisher and Paykel dishwasher.
ok , F1 means your flood switch has activated, which is underneath the drawer. now they show the F1 fault because of 2 reasons.1st there is still water underneath drawer causing switch to activate. 2nd your activator board which has the flood switch attached is faulty reading your posting it has been about 15 days since the fault happened. the water should have dryed around switch by now. if there is power to the unit and it is still coming up with F1 fault then possibly you have damaged the activator board. please reply and tell me if you have power on or off at the present time. to fix the problem it is alittle bit involved but i can guide you thru it when you reply .good luck
Posted on May 07, 2010
  • 3247 Answers
SOURCE: top draw beeping delay and water not draining
Not sure what you mean by beeping "delay" I am not sure if there is any such light on the dishwasher. The HRS DELAY is displayed on the LCD when dishwasher has been set in delayed start mode. Are you seeing this flashing in an orange background? There could be several reasons for water not draining. Does the beeping go away if you press the power on/off button? Also does the delay flashing stop. Have you checked to see nothing is blocking the drain pump which is the same rotor that drives the washer arms.. What about the kitchen down pipe - is it clear? If you think you have to take the drawers out to reach the drain hose then follow instructions on page 7 step 2 of the installation manual. It is for a later model but your one should be similar. Make sure you turn the mains power off when working inside the dishwasher.
Posted on Jul 08, 2010
Joe Onley
  • 363 Answers
SOURCE: Classique dishwasher, 3 weeks old.
You have a warranty, call the seller and ask how to use the limited warranty you have on the machine. As long as you didn't do something to the machine, they will usually just give you a different one to save on service calls in the long run, just get an exchange, I don't see any reason they won't do it.
Posted on Sep 01, 2011
Cannot turn my fisher and paykel dishwasher off..keeps beeping and motors are running in both draws. I have taken the bottom draw out and it is dry.. I can only turn it off if I turn the house mains off...
I am assuming you infer that the bottom of the dishwasher is dry when you took the bottom drawer out. This means the floodswitch located on the power filter board at the bottom of dishwasher might be faulty. Do you get any Fault code on the display.
Apr 21, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a single DS603H dishwasher. When I press start it just beeps a couple of times. Nothing happens, it does not start or anything.
this means the machine still thinks the draw is open so ofcoarse will not start, the sensor that detects the draw being shut is on the left hand side of the unit when u pull the draw out u will see 2 little clear squares on the side up the top near the control panel make sure they are clean aswell as the recieving end on the cabinet is clean as they r simple infrared sensors so if the beam of light is obstructed it wont think it is shut as the beam of light comes out of the control board and bounces off a light refracting prism and then sends it back to the board so if the beam cant return it wont start if they are all clean then you r looking at replacing the main control board as the sensor is contained within it
May 27, 2011 | Fisher and Paykel 24 in. DS-603 Built-in...
F 4 is comming up on the time delay button of my dishwasher and the wash wont start whats the problem
This means that the Dishwashers has detected a condition it needs to check. Press "Cancel" to clear the display and to stop the beeping sound, then try turning the Dishwashers off and on again. If you still see the "F," turn off the power to your Dishwashers and wait five minutes before turning it on again. If you hear the beep or see the "F" when you try to washing again, please call your authorized provider for service.
Hope this help?.
Please rate thumb.
thanks for visit.
Dec 15, 2010 | Whirlpool Dishwashers
Top draw beeping delay and water not draining
Jul 06, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
Dishwasher was scrolling through some sort of menu and beeping
Looks like the electronic micro controller fault.Due to power surge this could have resulted. It is bad luck!
Apr 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I keep getting a beep and believe it is a Fault Code
try turnning the unit of at the plug the the controll panel holde the program botton in and trun unit on try this on both draws
Jul 23, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher & paykel double dish drawer top draw just beeps...
The controllers get very brittle & can break away from their housing, the reason it's rapidly beaping is because it thinks the door is open. PLEASE TURN IT OFF FIRST AT THE POWER POINT. Take the front draw panel off by pulling the plugs situated on the front behind the draws, the controller is at the top right hand side if it is loose then thats the problem, double sided tape will work but lots of it or try a wedge type arrangement. I know this is an old post but people refer to these for solutions much later.
Mar 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Starting up Problems
I found it 2 min. ago. Ok here: while your ps3 is on hold the power button on the ps3 for you will hear one beep, keep holding it then when you hear the second beep take your finger off. Your ps3 should turn off. Now push the power button while holding your finger on it again, you will hear two single beeps, then a double beep, let your finger ago and a screen should appear with six options. Chose something like reset(or restore) file data or something like that and click yes, this wont do anything to your game/music/movie/etc. files but now your ps3 shall work.
Feb 01, 2009 | Sony Playstation 3 (PS3) Console
Top Draw flashing lights and playing music!?..
this sounds exactly like the problem we had the tech cam out removed the draw and found hte fuse on the heater element was blown -Because the dishwasher was under warrenty he replaced the heater the computer and gave us a new impella
********I'm guessing here but I think you can replace the fuseable resister in the heater element and all will be fine***
Oct 18, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwashers Logo
47 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
