Washes great once it gets to the final rinse and spin its banging like some thing inside the machine stripped it down nothing in it x
    Genius:
  • Washing Mach... Master
  • 1,669 Answers
The load of moist clothes inside the drum is out of balance. Open the door on the machine and wait for the drum to stop, then spread the clothes around the drum as much as possible. This should help to rebalance the drum.
Posted on Jan 07, 2013
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
the dr
  • 447 Answers
SOURCE: Boom and Bang Washing Machine
Bed sheets or comforters will often get out of balance in the spin cycle or during the rinse cycle. Throw some towels in there next time at least 5 big ones. They are engineered to take a little of this banging, it should only happen once in a while.
Posted on Oct 05, 2007
SOURCE: lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Posted on Dec 10, 2007
  • 46 Answers
SOURCE: Banging while spinning
slid the machine out away from the wall and tilt back enough to see underneath. just below the door there is a large concrete weight. chances are it is loose and needs to be tightened. if this problem has been going on for a while the bolts holding the weight on will have snaped and the drum/weight or both will need replacing . ( ex hoover engineer)
Posted on Feb 08, 2008
venexcsd
  • 1185 Answers
SOURCE: During the final spin cycle, water is leaking inside the machine
You have a problem with the pressure switch cutting in too early before all of the water has drained away from the outer drum
There is either an obstruction in the outlet pipe or pump which is not allowing the water to discharge fast enough.
The machine is then spinning with too much water left in the outer drum added to the water which is being expelled from the clothes equals leaking
Take the hose off the back of the machine and put it in a sink , make sure it is secure and do a rinse cycle
Watch the outlet and make sure it is a strong flow if it is weak then you have probably got an item of clothing stuck in the pipe from the drum to the pump and a strip down is required
One more thing there is a small plastic bottle attached to the back of the outer drum this has tube which leads to the pressure switch
Make sure there is no congealed soap in the Air Bell as it is called
Posted on Jul 05, 2009
Washer is banging/knocking really loud when spinning and strips of what looks like hard fiber are getting on the clothes. What is wrong and can it be fixed?
hi your problem is the bearings have worn down causing the drum to bang around as it spins and making it struggle to stay in the right position, the white dry wall looking things that you keep finding inside are the bearings themselves,bt lucky enough for you they are very cheap to replace and can be bought online or at any good repair center, all you need to do is write down the make and model number, also to fit them yourself you can go to the makers site and download a service manual, its very easy to do as i have done lots over the years, hope this helps and good luck
Mar 26, 2012 | Washing Machines
Hello there My WMA 31 washes clothes, but will not rinse or spin. It does a wash, then stops after about 15 minutes and the 'Wash', 'Rinse and Spin' and 'Final Spin' lights all...
Be sure that BOTH hot and cold water are turned on and flowing. The smell can be resolved by running washing machine cleaner (not just soap) through the machine once a month or so.
Jun 21, 2011 | Hotpoint WMA31 Front Load Washer
Just finished 2 washes with my Electrolux (eifl55IRR) washer and both times there were still soap suds in the machine after final rinse and final spin. I used just the right amount of HE detergent as...
Use a compatible fabric softener. The fabric softener not only softens fabric and makes clothes smell nice, but they break down and neutralizes detergents.
Mar 14, 2010 | Electrolux EW1000i Front Load Washer
Machine will not final spin
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
Feb 15, 2010 | Hotpoint Washing Machines
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
Jul 05, 2009 | Fisher and Paykel WA37T26G Top Load Washer
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Hotpoint aquarius wf210 g washes but stops at rinse
that is a possabilty, make sure you have water going to cold valves put test bulb on the wires going to valves it should light] close Ire. that means you have current going to valves] get back to me if you can\t sort it
Nov 03, 2007 | Hotpoint Aquarius WD640 Front Load...
Oct 05, 2007 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
