Question about Ricoh SP 4210N Laser Printer
4210n SC322 error code - Ricoh SP 4210N Laser Printer
3 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: i need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 19, 2009
my "RICOH Afico mp 1900" Give me "Error occurred> sc322 if the error functional problem turn main power switch of then on main power apparears again, call service now what i can do
Posted on Jan 22, 2013
Ricoh afficio 1600ml error code sc322
laser code could be laser unit or board problem that lser unit plugs into.
Feb 01, 2017 | Ricoh Aficio Office Equipment & Supplies
How do i clear code sc322 on nashua aficio 2016
Code SC322: Laser synchronization error
The main scan synchronization detector board cannot detect the laser synchronization signal for more than 5 consecutive 100 ms intervals.
Causes:
• Poor connection between the LD unit and the BICU board
• Damaged cable between BICU and LD unit
• LD unit out of position
• LD unit defective
• BICU board defective
Error Codes Ricoh Aficio 2016
Jan 04, 2015 | Office Equipment & Supplies
Error code sc322 gestetner
It's an error code for a laser synchronization error. Possible causes according to the service manual:
•Laser synchronization board connectors loose, disconnected, or
damaged
•Laser synchronization board defective
•LD drive board defective
I've also seen where toner leaks and covers the laser sync board and causes this error. Try cleaning any toner off the Sync board and see if that fixes it.
Oct 11, 2012 | Gestetner DSm745 Black and White Copier
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Code error sc322
laser error code polygon mirror motor bad -Carl
Dec 06, 2010 | Ricoh Aficio 1035 Copier
Lanier LD118d showing a error sc322, how to fix
sc322 is an error with the copier's laser unit. You can pull the laser unit out and clean it up if there is toner on or in it, but more than likely either the polygon mirror motor or the laser unit as a whole assembly should be replaced.
Jun 16, 2010 | Lanier UNKNOWN
Functional Problem SC322
Polygon mirror motor is bad. Sometimes you can put a drop of oil on the shaft, but at best is a temporary fix. You'll end up having to replace it. Good luck
Jul 13, 2009 | Lanier Office Equipment & Supplies
SC322 on Savin 4035
Laser synchronization error. It could be just toner on the LD unit. Try cleaning and doing the Pitch adjustment. If that doesn't work , then either the unit itself is bad, or the Sync. Detector board.
***This will obviously require a tech.
May 04, 2009 | Office Equipment & Supplies
I need solution to aficio 200 error code sc322
Possible causes:
Thanks, Joe
Apr 19, 2009 | Ricoh Aficio 180 Laser Printer
Ricoh AP2600 printer gives an error message of SC322
1st Laser synchronization error signal error. The 1st Laser that turns on inside of the printer can't synchronize properly to print out documents which is why this message comes up and nothing is printing. Probably is going to need to be replaced but a qualified service tech is going to need to look at it further.
Feb 10, 2009 | Ricoh Aficio AP2600 Laser Printer
Ricoh SP 4210N Laser Printer Logo
56 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
