SOURCE: My Toshiba L300 satellite pro wont load up
USE A BOOT CD AND RECOVER THE FILE AND MAKE SCAN VIRUS
rapidshare.com/files/51117041/ERD-2007.rar
IF YOU HAVE SATA DISK DISABILITATE SATA IN BIOS... TRY....
SOURCE: Acer Aspire 3693WMLi -Launch startup repair
It might also means that your hard drive is not working properly. My laptop's hard drive went out making the same blipping sound and white screen after that, this happens some times for over heating. Now if you get a error number let us know it might help
SOURCE: windows error recovery
Hello!!
enter the repair the console by inserting the Xp cd.. and try the command FIXBOOT .. and then restart!!:)
Cheers!!
SOURCE: Laptop won't starup (Black screen displayed) Help me please!!
Try this.
Turn the computer on and immediately press and hold the F8 key.
On the Advanced Boot Options menu, choose Repair Your Computer.
When you reach the System Recovery Options menu, choose Startup Repair. You already did that, but try it again.
If that doesn't do the work, go back to the System Recovery Options menu and do a System Restore.
You can use the Bootrec.exe tool in the Windows Recovery Environment
(Windows RE) to troubleshoot and repair the following items in Windows
Vista or Windows 7:
Note When you are troubleshooting startup issues by using the Windows RE, you should first try the Startup Repair option in the System Recovery Options dialog box. If the Startup Repair option does not resolve the issue, or if you must troubleshoot more steps manually, use the Bootrec.exe tool.
To run the Bootrec.exe tool, you must start Windows RE. To do this, follow these steps:
Note To start the computer from the Windows
DVD, the computer must be configured to start from the DVD drive. For
more information about how to configure the computer to start from the
DVD drive, see the documentation that is included with the computer or
contact the computer manufacturer.
Thank you Sir, Have a nice day.
SOURCE: asus x58l launch startup repair doesnt work cant
What is your operating system? If you have Vista press F8 at boot and select Last known good configuration that may work.
