Question about Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
Long beep when power on PC
When power on PC, long beep, no display, CPU fan and power supply fan work.
    Scholar:
  • 58 Answers
Usually any kind of clear distinctive beep while booting up is an error code. If you get a long beep with no display then it could be the memory or CPU. Check to make sure all of your cards are pushed in all the way. Just take your hand and push on your memory, cpu, and other cards gently but firmly to make sure they are seated. Also make sure that everything is connected. You may have missed connecting power to something.
Posted on Jan 20, 2009
  • wijaya123 May 04, 2011
    i,am all so hardware technician.yes this solution is correct.this is very use full.
2 Suggested Answers
  • 283 Answers
SOURCE: on board led indicators are
remove all ram memory wait 5 min,make sure to unplug from a/c,reboot with no mem should hear beeping unplug reinstall mem should boot ok if mem good,good luck!
Posted on Jan 08, 2011
My msi ms - 7352 ver :1.0 won't display but wen i plug the power cable on the power supply the cpu fan and power supply fan spin but wen i turn the pc on it doesn't display
Auto power on the mother board means there was not found RAM or VGA adapter. If you herd Beep tones
follow this link to identify the error
https://forum-en.msi.com/faq/article/bios-beep-codes
if not pls check the power supply 4pin connector correctly plugged .
Also need to check the cpu and post error codes by post diagnostic card to identify the eror.
Oct 24, 2013 | Computers & Internet
When powered on unit only beeps. continuous beeping- approx 1 every two seconds. nothing boots up at all, only beeps! Tried removing memory thinking it may be a memory issue but that was not the issue!...
Hi
If you have a Gigabyte MoBo then the CPU fan has stopped running.
Open the casing side cover and see if the CPU cooling fan is running or not.
If it does not run, the go into BIOS and disable "HDD S.M.A.R.T. Capability" in Advanced Bios Features
also set "CPU smart fan control" to disable in PC Health Status
OR
This may be a power supply problem.
The voltages of the power supply are going out of limits.
change the power supply and see.
May 20, 2011 | HP Pavilion Media Center a1510n PC...
On board led indicators are red in motherboard TF7100P-M7 power supply works cpu fan works both fans of the CPU heat sink assembly and power supply fan spin It shows no display, No beep
Jan 08, 2011 | Biostar TF7100P-M7 Motherboard
I have a T6420, went to turn it on and the fans come on at full speed and never slow down, nor do I get any type of display? What could be the problem? Power supply, mother board, CPU?
I could likely be any of the three items you mentioned.
Are you getting any beeps at all when you start your computer? If not, I would definitely have it looked at by a technician.
A trained technician should test the power supply, then CPU, then motherboard after ensuring fans work properly, CMOS is reset, and components are isolated.
Mar 11, 2010 | E-Machines eMachines Desktop PC
I have a mecer computer, LGA 775 motherboard asus and the problem is the computer turns on when switching on and there is no display it beeps non stop . CPU and power supply fans are working ,lights goes...
continuous beeping is Power supply, motherboard, cpu, or keyboard problem. somecases it can also be the memory.
start with the memory then cpu and powersupply and finally motherboard.
let me know if the beep code changes as you change components, count the short and long beeps.
Jan 07, 2009 | ASUS P5VDC-X Motherboard
Dell XPS 730 - Brand New - No display - Fan Loud
check if u r able to open the optical drive if its opening then power supply is gone bad or else get mobo an power supply replace
Dec 13, 2008 | Computers & Internet
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
No Display
Be sure that your power supply is working!
If the PS is working ,Try to examine your memory . if your computer getting long beeping. means that CPU is working if not beeping something wrong with your CPU. if beeping Unplug the memory clean it and connect it back. then test the computer. if doesn't solve the problem try replace the memory.
Dec 10, 2007 | Computers & Internet
No any display in the monitor, no beep of the RAM while CPU fan is running
Check your power supply. It sounds like you have a bad power supply. Even though the computer powers up, it does not mean that it's good. I have had this problem before, and almost 9 out of 10 times the power supply had gone bad. Just try a different one and see. hope this helps you.
Oct 01, 2007 | ASUS P5S800-VM Motherboard
Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard Logo
469 people viewed this question
Top Foxconn Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
