Question about Champion International Watches
My champion watch is frozen. How can I reset it?
Model la06/la07/la10/gt10
I need help with my new watch, how to set time? Watch is Champion Outlander.
Try Googling (champion)(model)(manual) without parens for instructions.
Dec 16, 2017 | Watches
Looking for english user manual
I would Google your watch model. Look for the model number on the watch back, then search for the user manual. I have to do this every time I need to change my Citizen EcoDrives for Daylight Savings, since the manual that came with the watch covers many models and it isn't clear which instructions are for MY models.
Nov 16, 2015 | Watches
How to set?& manual required invicta.15343 pro dive
Invicta Pro Diver - View model
invictawatch.com/collections/view-model/15342-pro-diver
INVICTA COLLECTIONS click to view models · AKULA ... Instruction Manual Print. More models of the same style. 15343. Invicta Pro Diver · share watch. 15341.
Sep 25, 2015 | Watches
How do you "unfreeze" a champion c9 wrist watch?
I am having the same problem. The battery is fine, the seconds are ticking away, but none of the side buttons work. The light doesn't come on and nothing happens with any of the others either. The only thing that did work was pressing all four of the buttons simultaneously, which seemed to totally reset the watch. The problem is it reset but didn't fix the buttons. So now I can't even see the correct time anymore.
Nov 21, 2014 | Geneva Watch Group C9 by Champion Mens...
Watch is frozen, will not reset or change modes
you will need to press the reset or a/c button located usually near the battery well with a pin and a magnifying glass
May 06, 2014 | Mio 0021usblk2 Drive Petite Hrm Black...
Watch not runing model 5030
That watch is powered from a 371 button cell1 battery. It is using model 9238/1970 movement. That movement is not listed as a chronograph.
Dec 12, 2013 | Invicta Watches
Replacing a battery on a C9 by Champion Womens watch
to change the battery in a champion watch:
(1) remove the back, (2) carefully peel loose the foam strip and set it aside (3) release the battery retaining bracket with a needle or awl and tweezers, (4) grasp the case with your thumb and forefinger so that your thumb is holding the works inside the case, (5) turn the watch over and the battery should fall out (6) put the new battery in the holder, (7) snap the retaining bracket back in place (8) replace the foam strip (9) replace the back 5b238361-61b1-4b0d-ab40-54fb346f5586.jpg
Dec 07, 2013 | Geneva Watch Group C9 by Champion Womens...
Watches Logo
107 people viewed this question
Top Champion International Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Champion International Watch Expert? Answer questions, earn points and help others
