Question about AT&T ATT TL86109 Cordless Phone
Have answering machine and fax on same line. How do I receive calls or faxes?
  • AT&T Master
  • 3,287 Answers
Your fax machine *may* have specific instructions (if not too old) for this very common type of installation (many do). Consult your fax manual to learn how to set this up. Your AT&T TL86109 phone has no options for adding a fax machine.
If your fax machine lacks the built-in ability to forward non-fax calls to your telephone or TAD, you will need to either purchase a fax machine that can do this, purchase and install a "fax switch" or, manage your fax calls manually - by only enabling the fax machine to answer calls when a fax is expected.
If yout still have problems, please post the name / model of your FAX machine. I hope this helps & good luck!
Posted on Jan 07, 2013
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
How do i set up fax to automaticely receive faxes after several rings
For a phone line dedicated only to the fax machine, the process is as follows:
  1. Press Menu/Set, 0, 1.
  2. You will see the Fax Receive window
  3. Use UP and DOWN arrows to change the setting to FAX ONLY
  4. Press Menu/Set.
  5. Press STOP/EXIT
Your fax machine will now answer every incoming call.
If the fax machine is sharing the phone line with a telephone, repeat the above steps and change from FAX ONLY to FAX/TEL This option will allow you to share the line with a phone only, not an answering machine. Once in FAX/TEL mode, the fax machine will still grab every incoming FAX call, and give a special ring (slightly different than a regular telephone ring) when it's a regular incoming phone call signaling you to answer the phone. I hope this helps with your problem. Best of luck!
Greg
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
IT WILL RING BUT GOES TO ANSWERING MACHINE DOES NOT RECEIVE FAX
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
Brother fax 4750e can not receive or send fax. sender said the line just ring and ring endlessly
To set up for receiving Fax, do the following:
Press Mode button repeatedly untin Fax and Fax/Tel lights are lit.
Faxes will automatically print and answering machine will take the calls. If you have a dedicated fax line, do the following:
Press Mode button repeatedly until just the FAX light is lit. Then the machine will answer every call as a fax.
Apr 23, 2009 | Brother IntelliFAX 4100 Laser Fax
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
FAX, MODEL 920 NOT RECEIVING
Try calling your fax machine from a cell phone. If the fax doesen't answer, or if the line is busy, the phone line may be bad. Also check that the phone line to the fax is plugged into the receptical marked LINE, not PHONE. The PHONE receptical is to connect a telephone to the fax machine. If it still does not answer, try going into the fax menu and go to RECEIVE settngs. Try changing each setting, then call the fax with the cell to see if it answers. Write down each setting before you change it, so you can set it back if changing it does not solve the problem.
Jul 10, 2008 | HP 920 Plain Paper Fax
How do I set up my X7170 to receive a FAX?
Link
Receiving a fax You can choose to receive a fax automatically, manually, or through an answering machine.
Note: For your All-In-One to receive a color fax, the machine from which you are receiving must also support color faxes.
Automatically Recommended for a dedicated fax line
Your All-In-One automatically accepts incoming faxes using the automatic answering mode. When the Auto Answer light is on, the All-In-One receives a fax after the specified number of rings set in the Options menu.
To set a number of rings for the automatic answering mode:
  1. On the control panel, press Mode repeatedly until Fax is selected.
  2. Press Options until ANSWER FAX WHEN appears.
  3. Press + to choose After 1 ring, After 2 rings, After 3 rings (default), or After 5 rings.
  4. Press Select.
  5. Make sure the Auto Answer light on the All-In-One is on.
When the number of rings that you set is detected, the All-In-One automatically receives your fax.
Manually Recommended for a shared fax and telephone line
You can choose which incoming faxes to accept by setting your All-In-One to manual answering mode.
  1. Make sure the All-In-One Auto Answer light is off.
  2. Press *9* on the telephone after you answer the telephone and hear fax tones.
  3. Hang up the telephone.
The All-In-One receives your fax.
Answering machine Recommended for a shared fax and telephone line
To receive a fax with an answering machine connected to your All-In-One, set the answering machine to answer incoming calls before the All-In-One does. For example, if you set the answering machine to answer calls after 3 rings, set the All-In-One to answer calls after 5 rings.
  3. Press + until After 5 rings appears.
  4. Press Select.
When a ring is detected, the answering machine picks up the call.
  • If a fax is detected, the All-In-One receives the fax and disconnects the answering machine.
  • If not, the answering machine completes the call.
Note: You must set up the equipment as shown in connecting to an answering machine.
May 21, 2008 | Lexmark X7170 All-In-One InkJet Printer
Fax answer machine
FAX RECEPTION THROUGH AN ANSWERING MACHINE:
This mode is recommended for a shared fax and telephone line.
To receive a fax if your All-In-One is connected to an answering machine:
On the control panel, press Fax.
Set the answering machine to answer incoming calls before the All-In-One does. For example, if you have set the answering machine to answer calls after 3 rings, set the All-In-One to answer calls after 5 rings.
To change this setting on the All-In-One:
Press Options until Number of rings appears.
Press the right arrow (+) until After 5 rings appears.
Press Select.
Make sure the Auto Answer light on the All-In-One is on. When a ring is detected, the answering machine picks up the call.
If a fax is detected, the All-In-One receives the fax, and disconnects the answering machine.
If a fax is not detected, the answering machine completes the call.
Feb 18, 2008 | Lexmark X4270 All-In-One InkJet Printer
AT&T ATT TL86109 Cordless Phone Logo
146 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
