Question about Samsung RS2534 Side by Side Refrigerator
Need to move it.
We have a Samsung fridge/freezer (non-dispenser) and we need to know how to lock/unlock wheels for ease of movement.
  • 700 Answers
You have to adjust the front legs untio the wheels make contact with the floor.. then after moving it adjust untill the doors are level with each other
Posted on Jan 20, 2009
Frozen water line on samsung fridge
I did a GOOGLE search using your reforge model number. I came up with several sites that have all of the info you need. The best was RC Repair parts. Here you will find all of the repair parts you need with pictures of same. Look it over I used this service for my Refrige a few years back and it was GREAT! also did a repair on my washing machine again a big help and all the parts were listed and available.
Jan 21, 2015 | Samsung RS265TDRS Side by Side...
Whirlpool 6th sense fridge freezer electronic panel - how do i unlock? child lock not on
Emma:
The lock and unlock feature is accomplished by holding the lock button for 3 seconds, and you will see a count down number just above it that indicates 3, then 2, then 1, and a soft tone along with the lock icon appears. To reverse this hold the same button for 3 seconds following the same procedure and the unlock icon will appear.
Jul 14, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Unpluged the panel from ice maker . when i repluged it with the power on it start bringging ice out automaticly. now water dispener does no work . Is this an elctronic problem?
Check temp setting. Freezer temp in between -14 and +8*F. And fridge temp must be in between 38* and 46*F.
Make sure the dispenser is notlocked. Some models have a lock feature that deactivates the dispenser andcontrol buttons. The lock button is located on the dispenser front cover.This feature controls unintentional dispensing. Press the"Unlock" or "Locked" button to reactivate the dispenser andallow dispenser function. You may need to hold the button for2 to 3 seconds. A clogged or incorrectly installedwater filter will reduce the water flow to the water dispenser. Check for aproblem with the filter by removing the filter and operating the dispenser. Ifwater begins to flow, then the filter is either clogged or incorrectlyinstalled. A clogged filter will need to be replaced.
Thanks. Helpful?
Feb 17, 2011 | Frigidaire FRS3R5EMB Side by Side...
We have a samsung side by side fridge freezer dispenser model and the fridge side has stopped working but the freezer does appear to still be functioning. The fridge temp control keeps restting itself to...
Hi. If you remove the light unit ond the lower casing which has four screws two of which are under the small vent covers that unclip. The light unit by the way has two screws under the difuser and that unclips. Mark the top before removeing with tape to give ease of replacement. After removing the top light unit inside the fridge and unclipping the two electrical terminals it can be removed. The same is true for the lower unit. Be aware the lower unit will be frozen in place. Ease it away to break the ice seal and remove the electrical connections. Use a hairdrier on full powar to fefrost the cooler unit at the rear of the fridge. Use the same method to defrost the removed fan unit. Pay attention to the fan drain. It may need the insulation trimming to make it drain and work again when re installed. Cut it away with a craft knife. When it is dry and defrosted re install in using the reverse procedure. Be aware it will frost up again and need you to do the whole thing again as soon as the fan gives signs of fouling on ice. You will hear it catch. Regards. Paul.
Mar 16, 2010 | Samsung RS2630SH Side by Side Refrigerator
Samsung american fridgefreezer
2 years is much too short for starting problems with a refridgerator contact your dealer for a condition because of warranty on the repair you eventual will spend on it. Hidden defects are factory falts are there some holes for melting water are clogged inside the fridge somewhere
An ordinary refrigerator is made for a 17-year life span. like brands as Bosch Siemens Kuppersbusch easely have that lifetime but your dealer is the right point to get your service .
Aug 18, 2017 | Samsung RS2630SH Side by Side Refrigerator
Admiral Fridge Freezer
We had thought this was a free service...??? Yes, we fixed it ourselves, after trial and error. We pulled out the ice bin and there is an arm that is moves back and forth beside it. It had frozen up. That is the ice crusher. Thaw it out and it is fixed. By the way, the above posting was not by us--ours stated that our ice crusher did not crush ice anymore. Instead, cubes came out...
Jul 12, 2008 | Admiral 26 cu. ft. Side-By-Side...
How to move the fridge
The wheels are probably OK, the tech likely lowered the leveling feet in the front to keep it from rolling by accident. Turn the little level legs (the screw up into the fridge) until the weight is back on the roller wheels, then you should be able to move it. A pair of "channel lock" pliers on the rubber feet work the best depending on how much weight is on them.
Dec 30, 2006 | Amana ARB2217CSR Bottom Freezer...
Samsung RS2534 Side by Side Refrigerator Logo
1,939 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
