Question about Dell Inspiron 1764 Laptop
Screen crashed to flickering gray screen
My laptop screen crashes while I am logged on in the middle of everything from checking emails to transitioning between web sites. The screen crash is a mostly gray with some white and blue flickers like a lightning storm. I usually hit ESC. button and re-enter my sites after a minute or so. I can usually pick up right where the crash occurred after I return after a crash. I had this issue about a year ago,and received a "Fix" via the re-boot/SAFE mode menu. I don't remember how it was solved.
  • Dell Master
  • 7,627 Answers
Try a roll back of the Graphics driver. Have you done any Graphic Updates? Install the driver from the DELL or Windows Update website. Does it work with a external monitor? When you boot in safe mode your machine uses the Basis graphics driver. Is the monitor OK when you boot in safe mode?
Posted on Jan 07, 2013
Hollyecho
  • 313 Answers
SOURCE: computer froze
Yes, it does. Try this:
How to Repair Install: ***Also removes Service Packs***
Sometimes the only way to repair XP is to reinstall. You do not have to wipe your partition and start over. Just as with previous versions of Windows you can reinstall right over top of an existing setup. This has the advantage of retaining your installed applications, data and settings. You will lose previously saved System Restore Points but System Restore will begin creating new restore points again immediately following the Repair Install. You will need to reinstall SP2 and any Critical Updates from the Windows Update Site. Be aware that a Repair Install will leave your system vulnerable to the Blaster and Welchia worms. Do not go on line until you have enabled XP's firewall first. Then visit the Windows Update Site to patch your system It is always prudent to backup important data before you make changes to XP.
There are two approaches. The first one should be used if you can still boot to your Windows Desktop. Simply pop the XP CD into the CD-Rom drive and select Install->Upgrade[recommended]. This will install XP overtop of itself in the same way as upgrading from a previous setup. However if your version is an OEM version then you will not have this option. If you do not see the option to Upgrade[recommended] DO NOT choose New Install as that will either overwrite your current setup completely or give you a dual boot setup. Also if you have an older version of XP and have upgraded to a new service pack you will get a message stating that a newer version of Windows was found and you will not be able to run the Upgrade. Create a Slipstream version to solve this problem
If you cannot boot to the Desktop, or you have an OEM version of XP, or you want to remove a service pack then the following should be used to complete a Repair Install.
Boot with the Windows XP CD and at the Setup Screen press the Enter Key
You will be taken to the Windows XP Licensing Agreement. After reading the agreement press F8 to proceed.
setup02.jpg The next screen gives you the option to do a fresh (clean) install or to repair the selected Windows XP installation. To run a Repair Install Press "R" at this time.
***CAUTION*** if you do not see the option to repair the selected Windows XP installation DO NOT choose the option to continue installing a fresh copy without repairing as that will overwrite your data and cause unrecoverable data loss.
setup03.jpg Windows XP will copy the necessary files to your Hard Drive to begin the installation and will then reboot. You will see the message that informs you to "Press any key to boot the CD". Do not press any keys this time just wait a few seconds and the Windows Startup Screen will be displayed. Following this you will be greeted by the Windows XP Setup Screens.
setup05.jpg rc%20017.jpg setup06.jpg When Setup has completed you should find all of your previously installed apps and settings are intact.
Posted on Jul 17, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Windows Vista crash/hang in Dell Inspirion 1525
Disable the turbo memroy driver and see if it will let you go onlin, if so download the driver or updated driver (if any), then unistall and reinstall it. If it won't allow you to do this, then try a system repair with your recovery or operating system disc.
Posted on Jul 23, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Blue screen with rows of white lines (not BSOD) causing laptop crash
A blue screen generally indicates an operating system error or hard drive failure. Start by doing a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a new operating system. If the hard drive won't format, or you have any issues during or after the install, then the hard drive has failed and will need replaced. You will need an operating system or recovery disc in order to do this. If this is a preloaded machine that didn't come with any discs, then you will need to acquire the disc.
Posted on Aug 13, 2008
ag66339
  • 127 Answers
SOURCE: Dell Inspiron 1501 won't boot
The initial Dell Screen you see at the begining is your BIOS access. Push F12 repeatedly when you see this screen and it will take you into a system restore mode. It will let you boot from CD first (which your PC is not set up for). You should be able to start the CD fine from there.
Posted on Sep 21, 2009
  • 788 Answers
SOURCE: I get a blue screen with flickering white lines
It couuld be the invertor is burning out.
If you boot into safe mode and the same thing happens, it is not a software problem or drivers.
Posted on Sep 28, 2009
Pass word log in
Just try to remember the exact answer for your security question. Try to remember if you have used upper case or lower case characters for your security question answer.
May 05, 2017 | Computers & Internet
I got a new laptop the thing my old one crashed and I had a code thing 2 put in facebook. and my cell phone broke. got new cell phone. how can I get back 2 my facebook
Email still the same? You have access to the email? Put email in and say forgot password...have it emailed to you they will reset your password and then you go put your new password in after clicking the link provided and there ya go ...then log in with your new password and don't forget your password again
Dec 11, 2014 | HP Computers & Internet
Just got a refurbished HP Pavilion DV7-4165DX laptop. Right out of the box it blue screen crashes and continues to do this several times a day. I have used the backup partition to reformat/reinstall...
One of the main reasons for blue screen crashes is a faulty device driver.
RMB click "My computer" - LMB "Manage" - LMB "Device Manager" and look for yellow question marks in the device listing. If you find one, said device driver needs attention.
To find drivers for you laptop, go to the HP website, follow links for support and downloads entering details of you laptop and operating system as you go.
It may be worth the trouble of updating you drivers to the latest versions anyway.
May 10, 2011 | Computers & Internet
Compaq nc6120 keeps crashing/powers off immediatetly
i guse its cause by some virus only .... best solution for this take all the data backup full format the c drive and reinstall the os
Dec 07, 2009 | Compaq NC6120 P-M 730 XGA Notebook
Can't get laptop to switch on
The crash sounds more like a hard drive failure, or maybe something was improperly written to the master boot record sector or another such important sector. I'd try to fix the MBR (google that: "Fix MBR windows xp") to see if everything is really gone or just hidden because the boot record (index) is lost.
Apr 10, 2009 | Fujitsu Siemens Computers & Internet
I downloaded the Quicktime update about 2 weels ago. I am now running Quicktime 7.6 on MAC OS 10.4.11 on my 15 inch Powerbook G4 which is about 3.5 years old. Ever since the upgrade, my screen will refresh...
I don't think this is related to your Quicktime upgrade. What you are describing sounds like a Finder crash and reboot. This would cause all Finder windows (folders, icons, etc.) to disappear from the screen, but would not affect any other open application such as Safari or Entourage.
In Applications/Utilities there is a tool called Console. Launch it. Click the icon "Show Log List." Click the flippy triangle next to ~/Library/Logs. Click the triangle for CrashReporter. Click on Finder.crash.log. Yeah, it's a lot of gobbledygook, but see if the crash times correlate with the times you saw your screen refresh.
The source of crashes like this could be a startup item (System Preferences / Accounts), a third-party System Preference, a corrupt preference file, or a dozen other things.
Create a new temporary user account. Log out and log in to that account. Work from it for a while. Do you still get the resets? If not, the problem is not in the OS, and is not a public System Preference. You may have to remove your startup items and deinstall any additional System Preferences you have added to see if the problem goes away; then install new versions of each of them until the problem comes back (if it ever does -- the problem might have been an old version).
Mar 10, 2009 | Computers & Internet
DS Lite repair worked, but only until I put it back together
You may have some pressure somewhere that it shouldn't be. The electrical tape takes up space, and could be taking space that is not there when the console is assembled. Or you keep knocking a connection loose when you put it together.
Try it while it's on. If the console crashes or dies at any point, whatever step you were in the middle of is probably causing that problem. Just make sure not to get anything in it while you were, and don't touch any electrical parts, in case you accidentally short something.
Dec 19, 2008 | Nintendo DS Lite Console
We are having problems trying to crash our cumputer. The reason is children had downloaded some viruses and we have already did a back up of all good files needed. Now we need to crash it and reinstall...
Why in the world are you trying to crash your computer??? Just download a virus utility, such as Trend Micro or McAffee, and let it deal with the virus. If you are having problems logging in, restart your computer, and after it goes through the BIOS screens, before it brings up the screen that says "Windows XP" with the little progress bar, press F8. Select safe mode with Networking, wait for it to go though all of the MULTIDISK screens, and then download the virus utility. If this doesn't help, please report back and elaborate on everything. What computer you have, what you mean by "crash it" (reformat???), what drivers you need to reinstall... etc...
Jul 05, 2008 | Computers & Internet
2 problems in one
Depending on what operating system you are using, I suggest repairing the operating system. For windows xp here is a guide that you can follow http://www.michaelstevenstech.com/XPrepairinstall.htm.
For windows vista
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Apr 16, 2008 | Acer Aspire 3680 Laptop
Dell Inspiron 1764 Laptop Logo
130 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
