Question about Momo Design Watches
Adjust rubber watch bracelet - Momo Design Watches
SOURCE: fossil watch me1001 bracelet adjustment
I took mine to a watch store, and had them remove a link.
Posted on Dec 26, 2007
VOTIT
  • 2071 Answers
SOURCE: watch
You better prepare a plain cloth to avoid scratch a piece of jewelry screw and ponson pinch ,if you cannot secure a ponson, find a big needle or sharp nail,take your watch put a piece of cloth to protect from scratch,hold your watch firmly that cannot slipt.In the side of links,there is a screw marks, or pinch marks lock,if you see screw marks you should use the screw ,if pinch mark ,use the needle or the nail to punch out the lock and detach it ..Again punch it in so it locks or screw it in.That s all you do patswan...
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Jul 25, 2008
escapement
  • 2334 Answers
SOURCE: how to adjust metal bracelet on casio A168 watch
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 05, 2009
escapement
  • 2334 Answers
SOURCE: where to buy the rubber on the both end of
Follow this link: http://www.nike.com/timing/ Select your region, then click on SUPPORT and then click on FAQ. Scroll down and read WHAT SHOULD I DO IF MY WATCH STRAP BREAKS. Rate me, plz.
Posted on Feb 16, 2010
gemineye61
  • 831 Answers
SOURCE: I bought the self adjustable bracelet watch but do
Self-adjusting bands usually feature easy to remove links that simply snap out. They usually look just like the main clasp or blend in with the band. Simply locate these links and undo the closures to remove or add them.
Posted on Aug 20, 2010
Unclear as to how you adjust the rubber band strap
  1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
  2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
  3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
I need to buy new bracelet
mcdevito75 here, BEST BET for your Ebel watch, look for a small watch repair shop in your area, to order a new bracelet.
Jul 13, 2010 | Ebel Type E Stainless Steel Rubber Strap...
Adjust expansion bracelet
Since all bracelets are simiar, the instructions I found on the Fossil web site may help you.
I have found some instructions on the Fossil website and since most
watches are very similar you can try the method described there.
Go to "fossil.com", go to the bottom of the page and you will see a
menu, click on "customer care", and then look under "Product Info" on
the left and you will see "watch instructions"
Go down the list to the bottom and under "Phillipe Stark" there is an item "bracelet instructions".
Feb 14, 2010 | Watches
How do you adjust the band on a rolex watch
Unscrew bracelet screws from the side and take out/add link. Then screw bracelet screws back.
Jan 29, 2010 | Rolex Day-Date President 118239 Wristwatch
Self-adjustable bracelet watch
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck.
Rate me, please.
Mar 19, 2009 | Timex 2J611 Watch
I want to adjust the steel bracelet on my new GMT II
You can do it yourself but proper watchmakers screwdriver is needed.
Check the sides of your bracelet and you will see screw ends with grooves. Unscrew them and adjust your bracelet (take the links out). Then screw them back in.
Regards
Arthur
Dec 13, 2008 | Rolex Watches
Rubber bracelet broken
Contact Skagen on line and provide the model number of the watch that should be found on the case back. They should be able to provide a replacement.
Nov 04, 2008 | Skagen Watches
Fossil watch me1001 bracelet adjustment
Dec 08, 2007 | Watches
Watches Logo
169 people viewed this question
Top Momo Design Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Momo Design Watch Expert? Answer questions, earn points and help others
