Question about Miele G 1470 SCVi Built-in Dishwasher
How can I replace the waterproof hose for Miele G1470? I don't know how to take off the back panel. Thank you.
I bought a new waterproof hose 120V, because my dishwasher wasn't getting water, and I was told by Miele technical service that this hose doesn't allow water to get in.
bigg t
  • 640 Answers
SOURCE: miele G893
you should have a dispenser on the door to add salt,regardless get c.l.r. calcium lime rust remover from a supermarket,lowes,home depot.put a cup in the unit ,run for 15 minutes and then put a cup in again.let the unit complete its cycle.if you still smell the odor repeat until its gone.you could also use baking soda,flour or vinegar.
Posted on Jan 06, 2008
  • 210 Answers
SOURCE: Does anyone have a service manual for the Miele G575 dishwasher?
Check the bottom floor pan, if water is there, only the drain will operate. Sometimes the float switch, which is a styrofoam block, gets warpped and activates the switch. This turns on the drain pump which overrides everything.
Sgt 48
Posted on Jun 04, 2008
SOURCE: Obtaining Miele Dishwasher parts
Miele's US website lists a toll free call in # for parts under the customer service heading. I found them to be helpful and informed. See below:
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
Posted on Dec 24, 2009
  • 177 Answers
SOURCE: Miele dishwasher not heating
hi,
you would have to turn the unit on it's side and remove the bottom plate and check with a multi meter the resistance of the heating element to see if the heating element is defective. i doubt the dishwashing liquid caused a fault other than causing the unit to over sud and spill water into the base. You could remove the panel under the door and have a look and see if you have flooded the base. if you have a float switch in the base (white polystyrene disc and switch) this will stop the unit from working as well. dry up any water and try it again. hope this helps and don't use the dishwashing liquid in the unit.
Posted on Jan 22, 2010
SOURCE: hi my miele dishwasher g665 no hot water or drying
new heating element
Posted on Jan 27, 2010
Replacing split drain hose on Miele dishwasher, cannot see how to access connection point inside the dishwasher!
A model number would be required for specifics.
Probably need to access from bottom. Probably best to lay it on the back. I am assuming your user manual suggests tipping towards back if/when moving. If it is a miele there is probably a built in water softener and lots of water in tanks that are not easy to see until panels are removed. Side panel might be easier to be removed to allow a view of stuff.
If applicable you might want to search the web for,
2011-11-25_043923_g600__800_miele_service_manual.pdf
Jan 31, 2013 | Miele Premier-Plus Built-in Dishwasher
How do I replace water inlet control valve on a Miele G851 SCI
there is a box on the end of your inlet hose that contains two solenoids. that is called your water proof system hose. when you try to start a cycle, that box should vibrate as the solenoids get power and try to let the water in. if it vibrates, but no water passes, you need to replace the hose. the only place to get one is through miele. 800 843 7231, press 0 and ask for parts.
May 30, 2012 | Miele Dishwashers
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Power intermmitently fades down. I have to keep pressing the plys button to keep it running
Hi joant58,
We had the same problem with our miele. We bought a new hose and that solved the problem. Unfortunately, it was not cheap. Over $100, but I don't remember a more exact amount.
Sep 10, 2011 | Miele Blue Moon Bagged Canister Vacuum
I've bought a Miele W310 front loader, which is secondhand, so i don't have a manual. i would just like to know how to do a short wash. There are buttons: 'Short' 'Prewash'...
The short cycle is only an option for Cottons. Make sure that you have set the desired program temp for a cotton cycle (95-30 degrees C). You should be able to select the Short cycle by pressing the button below the Soak light several times. (Note: this cycle is for small amounts of clothing which are lightly soiled - use less detergent (1/2 the amount for a full load).)
If it doesn't work when on the Cotton cycle, then the switch inside the control panel may be faulty.
The manual is available from Miele, http://www.miele.co.uk/customer/OperatingInstructions.aspx . Enter the type of appliance and then scroll down the list. The direct link to the manual for the W310 is http://www.miele.co.uk/Resources/OperatingInstructions/W%20310.pdf .
I hope this helps.
Jun 25, 2011 | Washing Machines
I purchased a used Miele G880 and it appeared to running good. After a week we noticed water coming through the basement ceiling with the machine not running. We have noticed that the machine is filling...
Hi - yes these units are fitted with what we refer to as waterproof hoses, any leaks from the inlets would leak into the machine.
Now you could check if the connection has been fitted correctly to the taps, secondly if there are any impediments causing the valve to stay slightly open hence the leak.
Unless your water pressure is exceptionally higher than norm which is doubtful. I cannot think of anything else otherwise you will need to replace the inlet unit which are not exactly cheap.
See how you go & will check back in a day or ....
Jun 09, 2011 | Miele G880 Dishwasher
Water intake alert coming on however the water is turned on. No water seems to be entering the dishwasher.
No water intake, may be a defective intake hose valve. Miele calls it, the Waterproof System hose (WPS). However, first shut off your water valve to the dishwasher; disconnect the WPS; and inspect and clean the plastic filter. If the problem persists, then replace the WPS (~$170).
Oct 17, 2010 | Miele Premier-Plus Built-in Dishwasher
Miele dishwasher doesn't work.error F70
When this problem happened to our machine, it was simply the pipes under the sink where the dishwasher drain pipe fits were blocked with muck. This was preventing the one way valve connecting the drain hose to the household waste from fully opening thus preventing the machine complete its drain cycle.
Solution was to thoroughly clean the sink drain pipes - plunger, power plunger and then a dose of chemical cleaner. Dishwasher is as right as rain now:)
Mar 29, 2010 | Dishwashers
Miele W916 front-loading washing machine filling very slowly
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
Mar 05, 2010 | Miele Novotronic W1918A Front Load Washer
MIele waterproof system reacted
That means that there is a leak that passed throught the waterproof system, and the water protection system had reacted putting the machine on error mode, as the water can damage electric parts, and cause serious hazard.
Sometimes you can reset the error by unplugging power cord, however you should call immediately a technician, as using the appliance when there is a problem with the waterproof system, you can be seriously injured by electric shock.
Operating instructions for Washing machine W 3923 WPS
Nov 16, 2008 | Washing Machines
Miele G 1470 SCVi Built-in Dishwasher Logo
73 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
