A faulty ink cartridge cradle latch causing problems.
On my printer, the small protuding part on the underside of the black ink cartridge cradle latch has broken-off which means that the 'terminals' at the rear of the cartridge aren't being pressed sufficiently on to the 'terminals' on the cradle when the latch is closed. Consequently, the ''print cartridge status light'' is flashing and a message appears on the screen saying that 'there is a problem with this right hand cartridge'. Clearly, I need a new cradle latch fitted but no-one seems to want to repair printers.
  • roberto serbin May 11, 2010
    Which type of printer do you have and do you have the single black ink cartridge with a single color cartridge. I have a few printers that I could probably send you the cradle if you think you can repair it yourself. They are pretty straight forward in disassembly and reassembly.
  • 32 Answers
Part #'s for HP #56 black & #57color are:
ASSY-LATCH BLACK - C6490-60011
ASSY-LATCH COLOR - C6490-60012
see my post @ techtalkz.com/hp/124170-hp-psc-2210-cartridge-latch.html
Parts re-sellers for HP:
United States Big Blue Products, Inc.
Huntington Station, NY
Tel: 888-BIGBLUE
http://www.bigblueonline.com/hp.htm
Bradshaw Group, Inc.
Richardson, TX
Tel: 972-644-7558
http://www.bradshawgroup.com
Computer Exchange LTD
Lawrenceville, GA
Tel: 770-806-3939
800-883-0800
http://www.computerexchangeltd.com
Depot America, Inc.
Farmingdale, NJ
Tel: 800-648-6833 or 732-919-0209
http://www.depot-america.com/
Image1 Products, Inc.
Plano, TX 75074
Tel: 866-846-2431
http://www.image1products.com
Laser Pros International
Rhinelander, WI
Tel: 888-558-5277 or 715-369-5995
http://www.LaserPros.com
Masterworks International Inc.
Houston, TX
Tel: 800-695-2282
Fax: 713-896-0885
sales@mwintl.com
http://www.mwintl.com
Parts Now!
Middleton, WI
Tel: 1-800-886-6688 or 608-276-8688
http://www.partsnow.com
System Design Advantage LLC
Bloomington, MN
Tel: 1-800-947-0007
http://www.sdallc.com
TSAworld, Inc.
Norcross, GA
Tel: 800-633-6626 or 770-417-2323
http://www.tsaworld.com
Vance Baldwin Electronics
Fort Lauderdale, FL
Tel: 954-723-9191
http://www.vancebaldwin.com
Posted on Nov 19, 2009
Magenta only printing one-half of its width, when I run test printing.
Your description of the problem says to me that there is one thing wrong:
  • Your cartridge have half the nozzles of the magenta blocked either because of the ink drying (which is unlikely) or the tape that covered the nozzles when you purchases the catrdige tore when you took it off, and therefore the blocking. Check the underside of the cartridge carefully to see if this is not the case.
  • What you can also do is to dab the cartridge on tissue to see if the 3 colours result in lines of equal length. if it does, the contact points on the from might be damaged, or a piece of tape vovers some of the contact points.
  • If nothing obstructs the contact points, look inside the printer where the cartridges fit (the cradle) to see if there is not a small piece of paper preventing the contact points to make contact with the pins inside the cradle.
  • If non eof the above, it is likely that your cartridge is faulty. Try another one. 2 cartridges will not give the same problem, and if it does, the problem is somwehere on your printer. Pins in the cradle might be bent or the thin flat cable from the cradle to the main board has be damaged somehow.
Good luck
Aug 25, 2011 | Canon PIXMA iP8500 InkJet Photo Printer
Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
To resolve the issue:
  1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
    NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
  2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
    1. Open the printer access door.
      NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
    3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
    4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
      For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
  3. If the error continues, restart your printer:
    1. Turn off the printer by pressing the power button.
    2. Wait five seconds.
    3. Turn on the printer.
  4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
  5. If the error continues, contact us.
When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
Jun 07, 2011 | Office Equipment & Supplies
How do i change the ink cartridge on my printer
These are the steps on how to install/replace cartridge(s) on Hp Deskjet 5550.
  • Press the POWER button to turn on the printer.
  • Open the top cover. The cradle moves to the center of the printer.
  • Open the cradle latch.
  • Slide the print cartridge out of the print cartridge cradle and discard it.
  • Remove the replacement print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strip is on the bottom.
  • Slide the print cartridge firmly into the cradle. Ensure that the copper contacts of the print cartridge meet the copper contacts of the print cartridge cradle.
  • Close the cradle latch.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Nov 19, 2010 | HP DeskJet 5550 InkJet Printer
DeskJet 895Cxi Printer ran out of black ink before my summerholliday. Back on job monday I replaced a new inkbox, HP 45 Black. The colour ink was changed just before my holliday. Still the orange light...
Follow each of these steps until the problem is resolved:
Remove and then reinsert the print cartridge(s) into the printer.
Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
Manually clean the print cartridges and print cartridge cradles:
Open the printer cover and wait until the carriage moves to the center.
Press the Power button to turn off the printer.
Disconnect power cord from the back of the printer.
Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
Lightly moisten a cotton swab with distilled water.
Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
Reinsert the print cartridges.
Close the printer cover.
Connect the power cord to the back of the printer.
Press the Power button to turn on the printer.
Calibrate the print cartridges.
If the light is still flashing, replace the print cartridges.
http://www.fixya.com/support/t5472914-hp_deskjet_932c_went
Aug 04, 2010 | Office Equipment & Supplies
Left ligh keep flashing. after installing new ink.
  • Make sure cartridge is placed in properly,
  • Re seat the cartridge and check.
  • It should work
Please rate my response!!
Jan 29, 2010 | HP DeskJet 940c InkJet Printer
HOw to install ink cartridge on HP Photosmart7760
Install the ink cartridges.
  1. Turn on the printer.
  2. Lift the top cover.
  3. Open both ink cartridge cradle latches by pulling each latch forward and then up.
  4. Pull the pink pull-tab to remove the clear tape from each ink cartridge. Do not touch or remove the copper contacts.
  5. Insert the HP #57 tri-color ink cartridge in the left stall. Insert the HP #58 photo ink cartridge in the right stall.
  6. Close both ink cartridge cradle latches by pushing down on each latch until it snaps into place.
  7. Close the top cover and press the OK button to print a calibration page. This verifies that the print cartridges are installed correctly.
Sep 13, 2009 | HP PhotoSmart 7760 InkJet Printer
Change ink cartridge
Here is the procedure to change the ink cartridge
  • First Press the POWER button to turn on the printer.
  • Open the top cover.The cradle moves to the center of the printer.Open the cradle latch.
  • Slide the print cartridge firmly into the cradle. Ensure that the copper contacts the print cartridge meet the copper contacts of the print cartridge cradle
  • Verify white paper is loaded in the printer, then close the top cover. The printer automatically prints a calibration page for optimum print quality.
good luck:-)
Oct 08, 2008 | HP Office Equipment & Supplies
My Heward Packard desktop 932C will not connect to my Dell laptop
what kind of connectivity you are trying to connect, most connectors comes as a USB cables, this comes as a easy connector that should be no problem at all, pls follow this info...
This document describes the hardware setup for a new printer. Unpack the printer
  2. Turn the knob on the rear access door of the printer counter-clockwise.
  4. Push the module back into the printer until it snaps firmly into place. (Do not press the buttons on the ends of the module while replacing it.) c00107976.gif
Insert paper
  1. Slide the paper adjuster out as far as it will go.
  2. Flip up the OUT tray so that you can see the IN tray more easily. c00107977.gif
  3. Place up to 100 sheets of printer paper face down in the IN tray.
  4. Slide the paper adjusters to fit snugly against the edges of the paper.
Turn on the power
  1. Locate the power module for the printer.
  2. Insert the rectangular end of the power supply cord into the power outlet on the back of the printer.
  3. Insert the two-prong end of the cord into an electrical outlet. c00107979.gif
Insert cartridges
  1. Open the top cover of the printer. When you open the cover of the printer, the RESUME button will flash until you close the cover. The printer part that will hold the cartridges (called the cartridge cradle) moves to the center of the printer.
  2. Remove the ink cartridges from the box.
  3. Remove the tape from the cartridges. c00107981.gif CAUTION: Do not touch the copper contacts (on the back of the cartridges) or the ink nozzles (on the bottom of the cartridges).
  4. Lift the cradle latches inside the printer.
  5. Hold the black ink cartridge vertical, with the copper electrical contacts toward the rear of the printer.
  6. Push the black ink cartridge firmly down into the cradle on the right. c00107982.gif
  7. Hold the color ink cartridge vertical, with the copper electrical contacts toward the rear of the printer.
  8. Push the color ink cartridge firmly down into the cradle on the left.
  9. Close both latches. When you push down the latches, you will hear a click and feel resistance.
  10. Close the lid of the printer. You will hear the sound of the cartridge cradles as they move to the right side of the printer.
Attach the printer Attach the printer to the computer with a parallel cable or a USB cable. Print a test page Turn the printer on and press the RESUME button to print a test page.
  1. If the RESUME light continues to flash, press it again.
  2. If the printer cable is firmly attached to the printer, then check to be sure that the printer cartridges are seated securely in their cradles.
  3. If the printer cartridges are seated firmly in their cradles, then check for any tape or packing material that you may have left inside the printer or on the cartridges.
  4. If you press the RESUME button for too long, you may print several test pages unnecessarily.
check it out.... goodluck
Jul 27, 2008 | Office Equipment & Supplies
665 people viewed this question
k24674
jasbo
jasbo
