Question about Hunter 33201 Humidifier
Install filter where do the filters go
Package indicates wilter might need to be chaged once a season
You should probably follow the directions in the instruction manual, which do say how often to change it. If you wish to risk a moldy house or an unproductive filter you can use it longer than advised. I soak mine in 50% vineger 50% water for an hour to dissolve mineral deposits and kill fungus, so the wick doesn't become too clogged to operate. I believe this lets it last a few times longer, but it is a Honeywell model of filter and I don't know how that would work on your filter.
Mar 06, 2014 | MoistAIR Genuine MAF-1 Wick Filter
In response to an indicator light I replaced the filter. What must I do to turn of the same indicator light?mortarlingto@aol.com
If you did not turn the unit OFF and unplug. it before changing the filter, do so now.Just repeat the process, but make sure the master ON/OFF Switch is OFF and the unit is unplugged before removing and replacing the filter. Be sure the filter is properly installed.Wait at least 5 minutes, before plugging the unit back in and Turning the Master ON/OFF Switch to ON. That should give the electronics time to rest themselves.
Hope this helps you.
Jun 20, 2011 | Aprilaire 360 Humidifier
I have a Vicks V3100 and dont know how to put it together or if I even have a filter. I do not know what the filter looks like
There is a Wicking Filter that is also the same media that creates the humidity. This filter looks like rolled up paper media(like for a swamp cooler). This filter installs at the back of the unit with the water resevoir removed. The water then is absorbed by this media and as the air passes through it humidity is released into the air. The Wicking Filter will need to be replaced when the performance of the unit decreases and the material becomes hard from mineral deposits. There is also a Protec Cleaning Cartridge that looks like a small plastic ball with a stem on it. Inside this cartridge are softening agents that remove hard minerals and extend the life of the Wicking Filter. The Cleaning Cartridge is just simply placed inside the water resevoir. To prolong the life of the Wicking Filter and unit make sure to use clean and cool water. Distilled water will work the best if available. The harder the water you use the more the unit will need cleaning due to hard water. When the unit becomes clogged with diposits you will need to run a solution of vinegar and water through the unit to clean it. If you use distilled or filtered water(reverse osmosis) then the unit will rarely need cleaning.
May 14, 2010 | Vicks V3100 1.2 Gallon Humidifier
What controls how much water flows into an Aprilaire 550? It was fine until a couple of days ago. I replaced filter, but it still appears to be too strong. It not only runs out the drain tube but is...
In the water line where it connects to the solenoid is an orifice. You can install a smaller plastic orifice or you can install a manual feed valve to where you can control the flow.
Feb 12, 2010 | Aprilaire 550 Humidifier
Replace humidifier filter
turn the unit off then take the tank off then the base which is the fan portion and the filter fits right there.. if it's a round filter then it slips right on. now if it's the squares they will slip into some slots and usually they will take about 4 if that's the case. if you have any other question please feel free to let me know.
Jan 09, 2009 | Bionaire BCM7207-U Humidifier
Orifice clogs to Aprilaire 600
http://www.aprilaire.com/themes/aa/en/manuals/600a.pdf look at page thirteen in this manual there is allready a inline filter on the unit. hope this helps
Jan 06, 2009 | Aprilaire 600 Humidifier
Hunter humidifer
I dont know why your humidifier is spitting water out.
But it sounds like you need to clean the unit and install a new filter. Once the filter becomes used, the humidifier won't work as well. Less water will be used because the clogged filter can't hold as much. Once you replace the filter, your water consumption should go back up and you should feel a difference in your home again.
Good Luck.
Feb 15, 2008 | Hunter 33201 Humidifier
Water leak
your drain pipe is clogged up, going to drain- Duh
Jan 13, 2008 | Aprilaire 550 Humidifier
Carrier Humidifier MN# HUMCCLFP1218A - not working
First of all the white build up is hard water residue. If you haven't replaced the filter in 3 and a half years you NEED to replace it. They have a safety switch may not be satisfied because of your filter.
Dec 21, 2007 | Humidifiers
Hunter 33201 Humidifier Logo
Top Hunter Humidifiers Experts
jdthefixer
ka4iup
ka4iup
Vernon Taylor
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
