Question about Gateway P-6860FX Notebook
No backlight I have replaced the screen with no luck, I have replaced the inverter board with no luck and I have replaced the display cable with no luck. I still see a display on the screen and the unit even works and boots into windows with no problems. I'm about to kick this to the curb and forget about it, someone help me.
  • Gateway Master
  • 5,660 Answers
A) Replacement LCD screen backlight could be bad.
Happens. Sometimes you get a bad part. (Bad LCD screen assembly, in this case)
LCD screen may not be the correct one.
http://support.gateway.com/s/Mobile/2008/GodzillaFX/2528410R/2528410Rsp2.shtml
http://support.gateway.com/s/Mobile/2008/Godzilla/2528407R/2528407Rmv.shtml
A screen Inverter, and an LCD screen; are a MATCHED unit.
B) Screen Inverter:
May be bad, or the Wrong one
C) You may not have the screen Inverter, connected correctly to the Backlight.
Connections aren't tight.
D) The Display Cable TO LCD screen connection may not be tight, or correctly connected.
I know the display shows graphics, but a poor connection of Display Cable to LCD screen, can make the Backlight dim out.
I'm betting it is a poor connection, or the wrong screen Inverter, or wrong LCD screen.
Regards,
joecoolvette
(Be shame to kick that laptop to the curb. Nice laptop)
Posted on Jan 07, 2013
5 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: Okay, so I had a customer come in with this laptop
When the LCD is black and you can see a dim image on the screen then it is a black light problem. could be a faulty inverter but mosr likely a burnt out/worn out CCFL lamp. By connecting and external monitor to the video port, you can determine weather the video card is OK.
If you don't get an image on an external monitor then the video card is faulty and it is impossible to repair except by replacing the motherboard.
Posted on Apr 05, 2009
pa1nkiller
  • 68 Answers
SOURCE: W340ui LCD Display out
some laptops do get shorts in the cables from opening and closing all the time
Posted on Aug 21, 2009
  • 561 Answers
SOURCE: Coil Part Number for Gateway MT3707 Inverter Board
Hi
Thnak you for your query
You will have to replace the WHOLE inverter board, not just part of it
The inverter is responsible for taking 12V supply and converting the power to a higher volatage to allow the screen to light up
I would suggest that you book the laptop into a reputable PC shop to complete the repair
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Posted on Feb 19, 2010
SOURCE: New laptop lcd display not working
check all usb connections i just fixed a emachine that seemed to boot up but no display would show lcd or ext. so i got to looking and one off the usb ports was broke and bent downt into the opening and shorting out when i removed it and turned back on it started booting up as normal
Posted on Apr 01, 2011
My Philips X58 Freevents laptop's screen has stopped lighting up, however I can just see that there are my programmes on the screen if I shine a torch onto it. Can you advise the fault and how best...
A faint and barely visible image on the screen indicates that the backlight(s) that illuminates the display isn't powering on. A device called an inverter board takes DC power from the laptop motherboard and converts it to AC power to power the screen backlight.
Before attempting anything below, be sure and remove the laptop battery and unplug the laptop
You need to take the screen apart and check to make sure that no cables are loose that are connected to the inverter board. If everything is secure, the next thing I would do is try to test the inverter board by hooking up an LCD from another laptop to the inverter and turning the laptop on to see if it lights up. If the other screen does light up, then the inverter board is likely good and your backlight needs to be replaced. Backlight replacement, unfortunately, can be very tricky for even an experienced technician, and many will opt to just replace the entire screen.
If you can't test the inverter board, then it might be worth it to order one and see if installing it fixes the problem.
Youtube is a great place to check for instructional videos on laptop repair, such as this one:
http://www.youtube.com/watch?v=jjXLR5yY7X4
Finally, if you can't or don't want to repair the display problem, then you can always hook an external monitor or a television up to the video port and use your laptop that way.
Sep 24, 2011 | Computers & Internet
My screen has gone very dark - what do I need to do to brighten the screen
You don't give any information about your computer, and that makes it hard to give a precise answer. But if you have a laptop, or you're having this trouble with an LCD monitor on a desktop computer, the display backlight may have quit working. Without the backlight you can only very dimly see the display. The usual reason is that the inverter board (in a laptop) or power supply (desktop monitor) isn't working.
Laptop inverter boards are pretty simple to replace, and you can find them for most brands and models now at reasonable cost. Check eBay where there are many sellers. Once you have the replacement, you just need to remove the front bezel of the display, which usually means taking out screws at the corners and releasing snap tabs around the edges. The inverter board mounts below the display panel and there are two cables connected. Unplug the cables, remove the old inverter, put the new one in and reconnect the cables and you're done. The brightness should be back to normal. (It's also possible but less common for the backlight lamp in the LCD panel itself to be bad. While it is possible to replace the lamp it is very difficult to do. It's usually simpler and safer to replace the whole display panel, although they can be expensive.)
In a desktop monitor, bad capacitors in the power supply often cause the backlight to go out. Many sites show what bad capacitors look like and describe how to remove and replace bad ones. It's a more difficult repair than the laptop inverter replacement, involving soldering on the circuit board, but it's still something you might be able to yourself.
Good luck, and thanks for using FIxya!
Aug 06, 2011 | Computers & Internet
I have an HP Pavillion DV4 laptop, when turned on the screen displays nothing. Ive been using my laptop by means of an external monitor.
You might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 17, 2010 | HP Pavilion dv4000 Notebook
Hi, I have hp pavilion dv2500 laptop. I have display problem.pls help how to rectify it. If i connect exteranl CRT monitor Display is coming . Pls tell me how to disassemble the laptop.
In this service manual, you will find an illustration of how to disassemble the laptop & replace either the LCD cable or screen inverter board:
http://h10032.www1.hp.com/ctg/Manual/c01295820.pdf
Sep 17, 2010 | HP Pavilion dv2500t Notebook
Fade display problem
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
Sep 10, 2010 | Acer TravelMate 2300 Notebook
ACER ASPIRE HAS NO DISPLAY
Sep 07, 2010 | Acer Aspire 1690 Notebook
Keyboard working but no display
Sep 07, 2010 | Computers & Internet
My toshiba laptop display screen won't light up?
This might be a sign of a faulty LCD cable or screen inverter board.
Test with an external monitor attached to the laptop. If you get display on the external monitor, then this confirms the case
Aug 21, 2010 | Toshiba Computers & Internet
I have a Fujitsu Siemens Lifebook s7020 with no backlight. The display is showing everything but it's hard to see because there's no backlight. Everything is also fine with an external screen. I have a...
The Inverter board must be tested and eventually replaced. The inverter is the small board located at the base of display. This is connected to one side to the backlight lamp, to which supplies AC high voltage, and on the other side to motherboard, where receives DC voltage.
Inverter contacts to otherboard and to lamp must be tested , using a multimeter to read volts. The inverter is an AC board, and for safety reason the test must be done by a trained repairer.
If the inverter is OK check the contacts to motherboard and wiring harness to motherboard..
Also ensure that light is not just dimmer because energy save mode is on, or because the laptop is running on batteries.
Sep 07, 2009 | Fujitsu Siemens LifeBook S7020 Notebook
Backlight wont stay on
The inverter board which provides the backlight power isn't working properly. This is a pretty common problem with LCD screens. The inverter is in the display, mounted under the display panel. It's a fairly simple job to replace the inverter. You have to remove the screws holding the front of the display to the back and separate the pieces. The inverter is held in place by a couple of screws and has a couple of cables connecting it to the main board and display panel. Unplug those, remove the inverter, mount the replacement and plug the cables back in. Then reassemble the display. A search on Google for "acer 5315 inverter" turned up several sources for the replacement part. Here is one. I don't know anything about this seller; I just picked it as an example.
May 19, 2009 | Acer Aspire 5315 Notebook
Open Questions:
Having issues on Acer Product ' call +1888784-9316 Care Number 24/7 Helpline Acer is a Taiwan-based electronics multinational that is best known for its computer products, although it also produces other consumer electronics such as personal digital assistants and mobile phones, as well as computer-related products such as servers and storage devices. Acer has ruled the consumer electronics market because it has the most innovative approach. Acer laptops are famous for their energy efficient performance with long lasting battery life, high portability due to the laptop's light weight construction, along with the added features like high speed Bluetooth and wireless connectivity and also wide screen display that provides exemplary image quality with higher resolution. Because of all these and many more qualities acer support have made it to the top of the list of customer's choice for best laptops. But its users might face some issues from time to time that could prove to hinder their important work and so, to prevent this, we have a team of technically superior and experienced technicians who can be contacted anytime on our toll free call acer tech support number. Issues faced by Acer customers:- • Black laptop screen issues • Stretched images on laptop screen issues • Laptop heating up followed by forced shut down • Window update issues • Crashing issues in acer computer support • Windows 10 upgrade problems • Computer Tune up issues • BIOS update • Virus removal issues Call on our Acer support phone number acer customer service and get all these issues and many more related to Acer laptops, addressed by our technically advanced and experienced support team members. Our Services: If you have any query or issue related to Acer laptops that you want to get resolved in the most efficient way possible by some of the greatest minds in this job with highest levels of experience then contact us on our toll free Acer support phone number. Contact our technical support team for any assistance regarding issues concerning Acer Laptops by Calling on our acer technical support phone number. Get all your troubles sorted out in a matter of few minutes by most courteous and experienced technicians.
Jun 18, 2018 | Acer Computers & Internet
See all Gateway P-6860FX Notebook Questions
Gateway P-6860FX Notebook Logo
269 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
