Question about Craftsman Saws
When I try to raise the blade to cut a dedo in a thick board. the crank at the top of the column gets harder and harder to turn and finally binds up tight whenthe blade is about a half inch above the table .. How do I solve this problem?
  • Craftsman Master
  • 2,411 Answers
Have you tried to lubricate it? Some times a shot of WD40) will do the trick. The threads get dry and dirty as well a little rusty. if you have an air compressor I would also blow all around the area to blow the dirt out.
Posted on Apr 17, 2016
5 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: WHen cutting a 2x4 the chop saw will cut 1/2 the
Is the blade secure on the arbor, or is the motor itself bogging down?
If the motor is bogging down, make sure you let it come up to speed before making your cut...then let the blade do the cutting, instead of forcing it through the material. Also be sure the material is securely resting against the fence and the base of the saw, so as not to pinch in the middle of a cut.
Make sure you have a good power supply to the motor, and not a long skinny extension cord or the like.
I guess it's possible, if the saw is older or has been under heavy use, that the brushes are worn out and need replacing, but it's also possible the motor is just worn out. (Altho I have rarely if ever seen this occur.)
If you rule out operator error and power source, and the brushes are good, and of course the blade is sharp and clean, the I guess the motor must be at fault, and should be checked at a local service center.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 04, 2009
  • 15 Answers
SOURCE: Not cutting through wood. Cuts are diminishing.
Sounds like the wood your cutting through is to hard for your battery powered saw....try one with a cord they work much better, especially for hardwood's.
Posted on Jun 08, 2010
  • 18 Answers
SOURCE: New SKILSAW 5995 used once to cut 1/4 inch
Did you fully charge both batteries before using them the first time? If not then they may not be able to hold a charge. It sounds to me like the batteries are either dead or defective as obviously the saw now doesn't have the juice to cut the board. If it's still under warranty take it back and get a replacement. Also, how powerful are the batteries? Even an 18V saw will struggle sometimes cutting a 2x4, they just don't have that much power. The plywood is easier to cut obviously.
Posted on Aug 13, 2011
SOURCE: zero clearence isert
Can't find settings for chop saw cutting not precise
Posted on Apr 06, 2012
Any ideas why the raised line appears to and how to prevent it from happening at all?
You have a chip in your blades. This is most often caused by a nail, screw or small stone imbedded in the wood. The only remedy is to have the blades sharpened.
Snipe is a depression cut on the end of the wood as it passes the blade. This is caused by the incorrect height of the blades in relation to the table. You will find many videos in You Tube on how to set up your planer.
Jun 08, 2017 | Crafts & Hobbies
I can lower theblade but it is very difficult to raise and now its not raising at all just gets tighter until you hear a snaping sound
Try spraying the pivot points with soy based lubricant. It is very slick and should help ease the friction of raising the blade.
Apr 29, 2014 | Rockwell Tble Saw Series 34-335 Elevation...
I can't raise my table saw blade when I crank the handle
My DeWalt Table saw does this,and for me its cleaning with a air compressor and nozzle. I cand seem to prevent it though. I tried grease on time and it just plugged up faster. I want to try a gravite lube next. To me it seems to be a desiegn flaw and I just clean the spline thead shaft that lowers and raises the blade. So far I just settled into a maintance air spray and it seems to work well enough.
Apr 07, 2014 | Ryobi Bt3000 Bt3100 Dual Slot Miter Table
Blade won't rise
it lowers easy because of the weight of the motor. What I would try and do is unplug tool first and lay on its backside and try and blow all the dirt from the gears/slide assembly. Look for a broken part where the shaft goes thru and if none use a DRY LUBE spray and also check for proper meshing of the gears. After lubrucating while saw is laying on its back look at the gear for any possible binding. Set upright and try again.
Feb 19, 2012 | Bosch 4100 09 10" Worksite Table Saw...
When raising the bar to start to cut the Toro makes a terrible squeaking and the engine cuts. Help. The lawnmover will start. It is model 2622-21" rear bagger. We cut the back lawn and went to cut...
Is this a self propelled? Since it will run, blade spinning, the bar you are mentioning to start cutting is for the self propelled drive. The terrible squeaking is probably the belt slipping due to something causing the wheel to bind. Check for the ability to turn the drive wheel by hand. Then check under the cover for any binding.
I hope this helps you out.
Jul 27, 2011 | Toro Garden
I'm a wife with a do-it-yourself knack. I recently purchased a Ryobi 10 in. BTS211 table saw. I find the manual complicated as far as how to actually use the device. Can you recommend where I can get...
I am a retired contractor.
I have a shop with a 10" table saw.
And I have opinions about safe operation.
For safety, turn saw off when making adjustments.
1) Raise blade:
There is a handle you turn to raise the blade.
If you are cutting 1/2" plywood, then set your blade at 3/4" or a bit more.
Keep blade low and away from hands.
Keep hands high and away from blade.
For 1-1/2" thick 2x4, I usually set the saw at 1" and run the board through, and then flip the board over and run it through again, taking 2 passes to make really thick cuts.
2) Blade angle
There is a second handle you turn to set blade at an angle up to 45 degrees
Angle cannot be set if saw blade is fully raised >> lower blade to half way or less and experiment.
Angle cuts are difficult if wood is not perfectly flat and square, or too long or too short (boy is that helpful ... but cutting angles takes some experimentation)
3) Table Guide
You stand behind power saw to operate
The saw table guide is on left side of blade and clamps across the table
The guide markings show inches >>> these are usually approximate
To set guide for accuracy, measure distance from blade to saw guide, and then clamp guide down.
4) Push sticks push sticks push sticks and other safety stuff
Let me emphasize safety first last and always
A table saw will chop your fingers off in a blink
On the plus side, I hear it doesn't hurt. But OMG.
There is a very strong human instinct to reach in with your hand when working on stuff
Train your mind >> if the saw is running, do not lean or reach into the saw
If a board is stuck >>> turn off the saw and wait for full stop
If you wear baggy clothes of a loose shirt, the saw will grab you and pull you in too fast for you to react
Keep your clothes tight and your arms bare
Always use push sticks or push boards::
Notice the saw blade is set low
Two push sticks are used to assist when cutting short board > one stick holds down the board ahead of blade, the other stick is pushing board through saw.
Keep your hands away from the blade no matter what.
The person stands behind and to the side of the board being cut.
The cut wood is supported by a catch table (in this case there are rollers)
Where to stand
Obviously you stand behind the saw to cut wood, and sometimes with long pieces, you can move in front and pull them through, and sometimes with large plywood you stand kinda back and to the side.
Why not stand directly behind a saw? Because saws throw stuff back.
When 'ripping' a board lengthwise as shown in photo above, if the saw catches the board just right, it will throw it backwards like a spear.
If a board 'binds' the saw causing saw blade to stop, then turn off saw, back up the board, and cut again.
Crosscut guide
The saw comes with a T-shaped guide that fits into a groove.
This is a 'push stick' >>> you use it to cross cut a board, and it lets you stand to the side of the saw blade so things wont flip back on you
When using the cross cut guide, remove the table guide that clamps across the saw, or push the table guide WAY back so pieces don't get caught in a bind and the blade flips up the piece and hits you in the face
Remember, the saw throws everything backwards
The saw is strong and fast, and you are best when traveling slow and without rush around your strong friend.
Oct 15, 2010 | Garden
The blade bends inward as soon as it touches a workpiece, cutting unevenly.the blade guides top and bottom are adjusted properly
The tension on the blade is too low. There is a knob up on top that when tightened will raise the upper wheel, tightening the blade. With the saw turned off, open the cover and turn the knob, you will be able to see the wheel being raised and the blade straightening out.
Apr 22, 2010 | Ryobi 9 in. Benchtop Band Saw
Not cutting straight
All band saws do this to some extent, but here are some things to consider
1. The tension may be too low, so that it deflects excessively when you put a little pressure on it.
2. You may be using a blade with too fine teeth for the thickness of material you are cutting. The more teeth that are cutting at the same time, the harder you have to push to get them to cut.
3. You may have a dull or poor quality blade.
Apr 06, 2010 | Ryobi 9 in. Benchtop Band Saw
Hand crank binds
The bearings may be packed with sawdust. Clean it out, look for any place where there could be movement and squirt WD40 in those areas, while cranking. This may free it up.
Apr 04, 2010 | Dewalt DW745 10" Compact Job Site Table...
Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Oct 14, 2009 | Husqvarna Huskylock Computerized 905
Saws Logo
162 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
