Question about Fisher and Paykel Dryers
Reset fuse on Fisher and Paykel gas dryer model DG08-USO
How do I open the front to access the fuse
2 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Fisher & paykel Dryer
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour or is not drying properly, check these.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 28, 2008
Does the Bose system in a 2003 Yukon Denali have a fuse
yes open drivers side front door fuse access panel near door hinge side pull from bottom out look on back side of door for fuse location
Feb 27, 2015 | 2003 GMC Yukon Denali
Fisher Paykel DG08 has too long dry times (hours).
Could be a variety of issues. If it is an older dryer, there could be a buildup of lint inside which prevents efficient heat transfer. It could also be a blockage in the exhaust hose, the area that the lint filter sits in, or the burner nozzle may need to be cleaned or replaced. Do what you are comfortable doing to clear any blockages, but don't experiment where gas is involved...seek a repairman if necessary.
Oct 09, 2014 | Dryers
Tailights are not working
Replace the fuse. Usually when the tail lights are out the dash lights are out as well. In most cars they share the same fuse.Fuse box could be under the hood above one of the front tires. Some cars also have the fuse panel inside the car in front of the door opening. Look for an access panel. There will be a guid on the cover telling which fuse goes to what. If your dash lights are on try replacing the bulbs.
Dec 14, 2013 | Nissan Vehicle Parts & Accessories
No heat--only cool air.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,./
Mar 31, 2011 | Fisher and Paykel DG08 Electric Dryer
Where is the fuse box located?
Open the passenger side front door...the inside fuse panel is under the pop off cover on the right side of the dashboard...(you cannot access this unless the passenger door is open...also try the internet under search engine..."Jeep Grand Cherokee Forum"...Hope this helps.
Feb 02, 2011 | 1994 Jeep Grand Cherokee
Dryer stops while clothes drying it appears dryer is over heating, because it takes a while before you can start it back
You have correctly identified the problem - your dryer is overheating. This will almost cetainly be caused by your thermostat having failed in the closed (on) position. The thermostat switches power to the heating coil on/off to keep the dryer at a roughly constant temperature.
Your dryer also has a thermal fuse which cuts all power to the dryer when it overheats. The thermal fuse takes 15-30 minutes to reset - this is why you can't restart the dryer for a while.
Basically, you need a new thermostat!
Please rate this solution if you find it helpful. Thanks!
Nov 01, 2010 | Fisher and Paykel DG08 Electric Dryer
How can i reset an electric dryer fisher & paykel it runs but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Does the 2006 dodge magnum have more than two sets of fuses?
THERE ARE JUST TWO.
Power Distribution Centers/FUSE BOXES
1. Front Power Distribution Center
A power distribution center is located in the engine
compartment. This center contains fuses and relay
2. Rear Power Distribution Center
There is also a power distribution center located in the
rear compartment under the spare tire access panel. This
center contains fuses and relays.
Opening The Access Panel
Rear
Jun 04, 2010 | 2006 Dodge Magnum
Open Questions:
Dryers Logo
94 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
