Question about Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
High Electric Bill due to Well Pump Cycling On Frequently
We live on 5 acres in a rural community and are dealig with a high electric bill. We are All Electric. Our Well Pump System seems to be the culprit! The pressure dropsrom 60# - 40# at irregular intervals of 10-25 minutes,causing the pump to come on for a few seconds around the clock. I trenched from the well for 25' and found a 1 1/4" PVC coupling had beenimproperly cemented when system installed 34 yrs ago; causing minor leak. After repair, the problem continues, possibly extending the interval slightly between the time pump comes on! I suspect the check valve at pressure switch near pressure tank? My schematic, als shows one in the well? Help!
The short run time of the pump indicates very litttle water volume is needed to reach to turn off pressure. To me this indicates you may have two problems. There is a leak somewhere in the system that allows the pressure to drop to the turn on point. Any check valve will fail eventually so barring any other leak that is your problem. I would think only one check valve is needed in the system so the second one may have been added to crutch the first one leaking. Normally the one check valve is placed on the pump before it is attached to the well pipe. The pump must be removed from the well to accomplish the replacement.
The second problem has something to do with the storage tank. If the pumps runs whenever you open a faucet or in your short cycle situation, then your tank is way too small or it is "water logged". Assuming it has been sized correctly, which means at least 20 gallon capacity then air needs to be added to the tank which will compress when the pump adds water until the high pressure setting is reached. When water is release to the house the air will expand until the low pressure setting is reached and the cycle repeats. The point here is that a significant quanity of water flows between pump cycles.
If your tank was installed in perhaps the last 20 years then it is likely a bladder type whitch contains the water so it never comes in contact with the steel tank, preventing internal corrosion and leaching of metals into the water. If the bladder has failed then the formally isolated air will have been absorbed by the water and your short cycling condition develops. That is what happens in non bladder tanks so air needs to be added periodically. I think all bladder tanks have a car tire like valve stem attached to the tank so that the opperating pressure can be set by the manufacture. The valve stem rairly leaks so bladder failure causes the loss of the air in the tank. There should be a label on the tank specifying the factory pressure. Use a tire gauge to test for the proper pressure. Add air if it is below setting.
Posted on Dec 12, 2013
2 Suggested Answers
SOURCE: oil for submersible sump/effluent pump
I have a master plumber 1/3 HP model 539892 submersible effluent pump and was wondering if it takes oil and if it does what type of oil.
Posted on Apr 03, 2011
Change pump hydraulic to electric jacks
I would contact the MFG for their recommendations for changing to electric jacks. Is your current hydraulic system an electric pump or hand? You might want to consider an electric hydraulic pump. Availability for the snow plow community is high. Their reliability is well known.
Apr 01, 2015 | Cars & Trucks
Can electric ignition on a gas range draw too much electricity?
it shouldn't effect your electric bill that much . try something else .
Mar 13, 2012 | Kenmore Kitchen Ranges
Stove causing a very high electric bill
Hello...There are several factors to consider....It's normal for the meter to speed up when you use the oven because the heating elements are high current devices...Several questions come to mind like do you use your over normally on a daily weekly basis??...Do you live in a house or apartment??..What about you heating system..did you use space heaters? or use the over to heat the house? what about Christmas lights and other decorations that use electricity...Were these all current charges?If all this checks out...I suggest you post a complaint or inquiry with your electric company...Let me know the outcome...I hope this was helpful.....PEACE...
Jan 24, 2012 | Stoves Ovens
Steps replacing a 1985 grand marquis fuel pump for first time alone thanks
See Figure 1
Two different electric fuel pump configurations were used on fuel injected models. One consists of a low pressure in-tank boost pump in conjunction with an external, frame-mounted high pressure pump. The low pressure pump is used to provide pressurized fuel to the inlet of the high pressure pump and helps prevent noise and heating problems. System pressure is controlled by a pressure regulator mounted on the engine.
The other configuration consists of an in-tank high pressure pump which does not utilize a boost pump.
Fig. Fig. 1: Disassembled electric fuel pump
REMOVAL & INSTALLATION
In-Tank Pump
See Figures 2, 3 and 4
  1. Disconnect the negative battery cable.
  2. Depressurize the system and drain as much gas from the tank by pumping out through the filler neck.
  3. Raise and support the rear end on jackstands.
  4. Disconnect the fuel supply, return and vent lines at the right and left side of the frame.
  5. Disconnect the wiring to the fuel pump.
Fig. Fig. 2: Low pressure in-tank electric fuel pump
Fig. Fig. 3: High pressure in-tank fuel pump
Fig. Fig. 4: Removal of electric fuel pump
  1. Support the gas tank, loosen and remove the mounting straps. Remove the gas tank.
  2. Disconnect the lines and harness at the pump flange.
  3. Clean the outside of the mounting flange and retaining ring. Turn the fuel pump lock ring counterclockwise and remove.
  4. Remove the fuel pump.
To install:
  1. Clean the mounting surfaces. Put a light coat of grease on the mounting surfaces and on the new sealing ring. Install the new fuel pump.
  2. Installation is in the reverse order of removal. Start the vehicle and check electric fuel pump operation. Check for fuel leaks.
High Pressure External Pump
See Figure 5
  2. Depressurize the fuel system.
  3. Raise and support the rear of the vehicle on jackstands.
  4. Disconnect the inlet and outlet fuel lines.
  5. Detach the electrical harness connection.
  6. Bend down the retaining tab and remove the pump from the mounting bracket ring.
  7. Install in reverse order. Make sure the pump is indexed correctly in the mounting bracket insulator. Start the vehicle and check electric fuel pump operation. Check for fuel leaks.
Fig. Fig. 5: High pressure external fuel pump
Feb 12, 2011 | 1985 Mercury Grand Marquis
I puchased 5 year old home back in July and up until the last few months my electric bill has been any where from 800kwh to 1500kwh. It jumped in December to 3880 and 4500 in January. My home is 2400sq,...
You will need to have a HVAC tech to check your Heat Pump..... It is not working or not heating properly....And you are heating the house with the electric heat strips which will make your electric bill double The electric heat strips are there as back up if the heat pump is not working or keeping up with the heating demand.
Feb 12, 2011 | Heating & Cooling
Craftsman mower keeps breaking primary mower belt
Have you check the tensioners? The idler pulleys that are on the arms with springs on them. My reasoning is, if the arms are rusted, or stuck for some reason and not moving freely then the springs can't pull the belt tight. If that's the case, I could see where the belt could be slipping more than it needs to and prematurely wearing out. Just something to check. Good luck.
Jul 29, 2010 | Craftsman Garden
Hello, I have a rbha-17 electric heat system. My
the orange or blue wire should go to the heat pump and energize the reversing valve and the compressor should be running when the heat pump is on. All it does is reverse the flow of refrigerant and pull btu's from the outside air and deliver them to your house. Check to see if your aux. heat is coming on with the heat pump. If it is electric furnace, this will help explain why your bill is so high.
Jan 13, 2010 | Ruud UAMB042 Air Conditioner
My monthly electric bill is huge.. am thinking that it might be my furnace is not set properly? (true or not?) usually keep it around 68. Seems like its in an 'auto' mode (which might make sense), but...
Typically electric resistance heat draws three times the amount than a heat-pump be sure to not set the thermostat too high, its possible the sequential heater relays arent shutting off continually on without the blower causing super high electric bills
Jan 21, 2009 | Heating & Cooling
Water heater problem (no leak on floor)
shut off the power to the hot water heater wait 5 to 15 min. If the noise stops it is the water heater eating up electricity. Turn it back on if noise starts again feel about 5 or so feet down the hot water line. If this line is hot you have a leak beyond the hot water heater. If you still hear it when the power is off to the water heater. next turn the water off on the cold water line at the water heater with the power off also Look at the water meter and see if the hand or wheel on the meter is moving and it should no be. Also think if the breaker to the hot water is off the electric meter should practically stop if no refrig oe anything else on. Have someone watch the electric meter and switch 1 breaker at a time leaving the one you just shut off in the off position until you cut them all off. Should the meter still be moving you have a main service cable shorting somewhere call the power company to advise you further if this is the problem.. Should just cutting the circuit breaker for the hot water heater stop the noise and down the hot water line is not hot then you are probably wasting power due to a thermostat or element inside the hot water heater.. Thank you j
Nov 23, 2008 | Ruud Central System Air Conditioner
Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP Logo
131 people viewed this question
Top Water Electrical Supplies Experts
Lawrence Oravetz
Ottoniel
Are you a Water Electrical Supply Expert? Answer questions, earn points and help others
