Question about Dryers
Washer not working ...leaking water from the bottom .
  • Dryers Master
  • 3,904 Answers
You will have to remove the back. Run the machine and watch where it is leaking. Could be a loose hose or bad gasket.
Posted on Jan 07, 2013
Water leak from the bottom of washer
Hi friend, thank you for your post!
I understand that water is leaking from the bottom of your Frigidaire washer. There are many components that could cause a washer to leak the bellow (gasket), leak from drain hose, drain pump, or water valve. Since it could be any one of these underlying issues I would recommend having a technician come out to diagnose and repair your appliance. Hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
I bought an Admiral washer Model No. ATW4475VQ. I bought it from Home Depot. The first washer was delivered, and when I did a load of laundry, water leaked from the bottom of the washer. I did not see any...
It's impossible to tell. from your description.
Usually a new washer is set up with new hoses. If the installers aren't complete idiots that should be good.
You can look at where the water lines come out of your wall and make sure it isn't wet there.
You could also test the water pressure at your house and make sure it isn't extremely high. Sometimes these new units can't take overly high water pressure.
Good Luck!
Mar 27, 2017 | Whirlpool ATW4475VQ Washer
Water leaking from the bottom of washer
I had this problem the other week we turned the machine around and took off the water hose got to the water pump and found 5cents, hair pins, badges ect in there once cleaned out and put back together worked great again and no more leaks!
Apr 26, 2010 | KitchenAid KAWS850L Top Load Washer
I have a GE quiet power 3 dishwasher and water is in the bottom a the power will not work now what should I do?
This seems to be that the Anti Flood system has triggered. This device detects water leaks / spills to the bottom of the washer and automatically puts the washer in pump out mode and shuts off the water inlet. The device is made up of a pollystireene float and micro switch that activates once the float detects any leaks / spillage. Dry water and check for leaks and this should solve the problem
Jan 23, 2010 | Dishwashers
Water draining out of the bottom of washer
CHECK YOUR WATER INLET VALVES FOR LEAKS BY REMOVING THE TOP OF YOUR FRONT LOAD WASHER. IF LEAKING REPLACETHE PART.
Dec 09, 2009 | LG WM-2277HW Front Load Washer
Water leaking from bottom of washer
Tub Seal is leaking and needs to be replaced
Jun 11, 2009 | Washing Machines
Washer leaks water from bottom
Water pump or hose came off or broke but i bet its the water pump
Feb 06, 2009 | Kenmore 23822 Top Load Washer
Heavy water leak during when washing clothes
disconnect the hose on the bottom and see if the seal is good.If it is good, then remove the back panel, start the washer and watch and see what seal is broke and you can visually see the exact spot the water is leaking from.
Feb 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer is leaking water at bottom
You should look at the machine's bottom first- try to find out from where water leaking from. In most cases it is the pump.In such a case it should be replaced. Good luck!
Jun 14, 2007 | Frigidaire FEX831CS Top Load Stacked...
Dryers Logo
37 people viewed this question
Top Dryers Experts
