HDMI input failure
I finally decided to upgrade my input to HDMI once my cable company got a new box that had HDMI out. When I hooked up the TV the HDMI input gave me only a black screen then after plugging it in and out a few times gave me a green screen. I know the box and cable work since I hooked up another TV and it worked fine. I called JVC and went through the whole HDMI reset without any luck. They said I need to get this serviced, but I really don't want to pay for this for a TV 3 yrs old, especially since it obviously never worked from the beginning (I just never used the HDMI input until today). How much would this cost me (or is there something I could replace or check myself for less money?) I have a 57 inch Toshiba rear projection HD with a HDCP compliant DVIinput. For over a year now I have been watching HD from my HD DVDthrough a HDMI/DVI cable connected directly between the HD DVD and thetelevision, with no problems. After I bought a Vudu Internet receiver, I connected boththe Vudu and the HD DVD to my Onkyo 506 receiver (HDMI passthrough)withHDMI cables, and the receiver to the television with the HDMI/DVIcable. I was able to play the HD DVD successfully with this setup.However, when I tried to play the Vudu, I got the noncompliance notice-- and no picture. Moreover, I now get no picture when trying to viewany HDCP source, including the HD DVD, regardless whether it'sconnected through the receiver or directly to the television, as itused to be. It is as if the VUDU "blew out" my television's HDCP"handshake."
  • 8 more comments
  • pmalter0 Jan 20, 2009
    The first half of that post should not be there. The Post should start with: "I have the 57 inch Toshiba...."
    Moreover, my Toshiba model is a 57H83 .
  • pmalter0 Jan 21, 2009
    The television is four years old, and I don't think there are any new software issuences. I am also quite sure that it is not the cables-- I can play a non-HDCP HD DVD successfully over the same cables now(hence, it is not the DVD either). A number of people have had a similar problems on this website with their JVC rear projection televisions; and in every case it was the television and not the cables. Similarly a number of people on the VUDU forum have had this problem -- and in every case it was not the cables.
    As I said in my first comment, that part of my post should not be there. This is not an issue involving my cable box-- that post belonged to somebody else. My problems started with the VUDU (I really think that the VUDU messed up my television's HDCP handshake; the VUDU support can figure it out either).
    Everything worked fine through my Onkyo's HDMI inputs/output initially. I was able to play HD DVD movies and select a HDX movie to be downloaded on my VUDU. When I went to play that movie I received a HDCP noncompliance notice and then a blank screen( afterward I had a blank screen on all HDCP HD DVD discs as well). Nothing changed when I took my Onkyo out of the circuit.
    I am going to do the repair myself, I just hope that the DVI circuit board is easily accessible and has the components labeled or marked. Can anyone tell me if it is. Thanks
  • pmalter0 Jan 27, 2009
    I've got a couple of problems: 1) I can't find C 268; the only
    capacitors near P202 are in the 800s; do we have the right model
    --57H83 ? 2) how do I access the television's motherboard; I could get
    the DVI module out by just taking off the rear small access screen, but
    to put it back in I will need to slide out the whole motherboard -- and
    it doesn't want to slide out the back -- help. Also, could you possibly
    e-mail me or fax me that Toshiba bulletin (I could probably get Toshiba
    to provide me a new DVI if I had the bulletin)? Thanks.
    Bigger problem -- the DVI circuit board is not accessible for replacing the capacitor. The circuit board is in a metal housing that is soldered to the circuit board in at least a dozen places -- replacing the capacitor doesn't look reasonable now. I guess I have to buy (or get Toshiba to replace) a new DVI module. I still need to find out how to access the motherboard.
  • pmalter0 Feb 02, 2009
    Comment posted on Jan 20, 2009
    Comment posted on Jan 21, 2009
    The television is four years old, and I don't think there are any new software issuances. I am also quite sure that it is not the cables-- I can play a non-HDCP HD DVD successfully over the same cables now(hence, it is not the DVD either). A number of people have had a similar problems on this website with their JVC rear projection televisions; and in every case it was the television and not the cables. Similarly a number of people on the VUDU forum have had this problem -- and in every case it was not the cables.
    Comment posted on Jan 27, 2009
    I've got a couple of problems: 1) I can't find C 268; the only capacitors near P202 are in the 800s; do we have the right model --57H83 ? 2) how do I access the television's motherboard; I could get the DVI module out by just taking off the rear small access screen, but to put it back in I will need to slide out the whole motherboard -- and it doesn't want to slide out the back -- help. Also, could you possibly e-mail me or fax me that Toshiba bulletin (I could probably get Toshiba to provide me a new DVI if I had the bulletin)? Thanks.
    Thank you--good response
  • 15,935 Answers
CLICK HERE to order a Service Manual for $6.50 (half the normal price)
Your Problem is definately in the DVI board - however specialized testing equipment is required to troubleshoot and replace faulty components on the board (unless there is obvious physical damage).
Your best approach is to either remove the board, and take it to a repair shop to save labor of disassembling the unit - or remove/replace the board altogether.
Without seeing a service manual, or the actual unit, this is as far as we can go here.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 02, 2009
    President:
  • 2,559 Answers
I don't know if this is the case on your's,but I had the same issue on mine and it turned out to be a loose solder on the HDMI input jack.
  • 19,396 Answers
You probably need to set up the Onkyo 506 HDMI output properties.
First connect the Onkyo to TV alone, to test it.
If it does not work, try a different HDMI input on TV, and if you have one , test a replacement HDMI cable.
This to ensure that there is no connection problem.
Then you perform the HDMI setup explained at page 39 on user manual below:
TX-SR506
Posted on Jan 21, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
You can buy a converter from the link---
http://www.amazon.com/gp/product/B001OFG2LG/ref=olp_product_details?ie=UTF8&me=&seller=
Thanks
Rylee
Posted on Jan 20, 2009
  • 350 Answers
I would call my cable provider and explain your problem to one of their experts.! I find this the fastest and easiest way to resolve any cable TV problems!
I've wasted countless hours trying myself, going on-line and asking friends for help yet it always winds up being the cable company that gets everything working properly!
I hope this is helpful!
Good Luck!
    Scholar:
  • 87 Answers
What is the model # of this unit?
  • 1 more comment
  • Albert Vasquez
    Albert Vasquez Jan 20, 2009
    I am an authorized Toshiba service center and I did find a bulliten that is related to your problem.Remove the DVI input module and open it up, and locate C268. It is a small surface mount capacitor located near P202 which is one of the connectors.Replace it with a 100k ohm surface mount resistor.Toshiba part # 24011104.Good luck!!
  • Albert Vasquez
    DVI input module Toshiba part # 23788762.partsstore.com should have.Easy to replace.This would be an alternative to reparing.partstore.com $69.99
  • Albert Vasquez
    Albert Vasquez Jan 21, 2009
    Two screws hold this unit in place.It is accessable through the back panel and th components are clearly marked.
    Genius:
  • 1,550 Answers
Have you tried with different cables and also check current software for the TV.
Also did you try with another DVD to make sure since the symptom did not sound like the disc had an error.
How do you hook up cable box using coaxial in hdmi out
If your cable box has an HDMI OUT connector you simply connect the HDMI cable to the TV and the coaxial cable from the cable company to the coaxial input on the cable box. Then select the HDMI input on the TV that matches the number of the HDMI input port you chose on the back of the TV.
Mar 03, 2016 | Insignia NS-LCD32 LCD TV
Cable box is plugged into denon's hdm1, but I can't get a picture. Hdm1 out monitor (arc) is plugged to TV hdm1 in (arc).
Power up all components. Select the HDMI 1 input on the Denon amp, and the HDMI 1 input on the TV. Additionally, run the old analog cables between the cable box and the TV. If no picture, select the input on the TV that is associated with the analog input from the cable box. You should have a picture at this point - but it will be a standard definition type. Check the settings on the cable box to change the output from "A / V" to Digital on the HDMI jack - if present. You may have better luck unplugging power / replugging in the cable box first - or calling the cable company if you can't find settings for this. Once you have the output of the cable box to HDMI, select HDMI on the TV. If you still don't have it working - try bypassing the Denon and go directly into the TV from the cable box. Try it with BOTH HDMI cables. Also - try different inputs and out puts (HDMI 2, HDMI 3, etc.). Discard any HDMI cable that fails to show video and play audio.
May 04, 2015 | Audio Players & Recorders
I have audio but no picture, just "Video 1"
You didn't mention tv make / model so thjis is only a guess . The tv may need tuning to find the direct tv cable.
Jan 07, 2015 | Audio Players & Recorders
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
* HDMI
to "listen" to.
Oct 24, 2014 | Samsung PN60E6500 60-inch 3D Plasma TV
A new cable box was connected to my 32" Proscan LCD TV. Now everytime I turn on the television I see the message "HDMI-1 No program information available" I contacted the cable company and...
I know this may be a dumb question but I have to ask because even though the cable company has HD boxes a lot of them still dont have HDMI outputs instead they use the 5 Component cable (red,blue,green,for video and white, red for audio). Not only that most of the cable guys are not the brightest in the world I work in an electronics store for 13 years and cant tell you how many times I went to someone house and it was hooked up wrong. Are you stuck on HDMI-1 or can u chnge the channel by using the tv/video button it may say input as well. Check how its hooked up easy to tell 1 cable HDMI, 5 cables -Component. If it is HDMI check the other hdmi input as most LCD tvs have at least 2. same for component it will say component on screen
Dec 14, 2010 | Proscan Televison & Video
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
HDMI trouble: ''Your TV does not allow display of this program...
''Your TV does not allow display of this program through the DVI input source. Please choose another TV input source
whys it say that
Mar 19, 2010 | LG 32LG30 32 in. LCD HDTV
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
May 22, 2009 | Onkyo HT-S5100 Theater System
Hdmi input not working
Sounds like a failure on the main or av pwb in the TV. Do you have another component such as sat. rec or cable box to try with hdmi?
Jan 29, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Maxent MX50X3 HDMI input
I had the same problem and found that the ground wire outside where the cable companys box is was not even hooked up. It was just hanging there, once I hooked it up it went away. The cable company gave me the run around telling me it wasn't their fault. I now have Direct Tv.
Dec 04, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Televison & Video Logo
236 people viewed this question
Top Televison & Video Experts
Electro Med Services...
