Question about Dayton E51 Oil Filled Utility Heater
Blows big puff of smoke on start up.
Not to bad first time it is used but there after alot of smoke when it lights back on. any suggestions? where can i get a manual?
I have a all pro modelspc k100 will not ignite when pluged in
Posted on Mar 01, 2009
My 94 VW Golf After driving it a short time and turning it off after 10 to 15m i try start it and it will crank a fair few time before starting back up with black smoke. Any help will do thank you
Sounds like an indication of a rich fuel mixture. Check your air filter. The MAF sensor, oxygen sensor, ECM, fuel pressure regulator or injectors could cause the rich mixture. Have the vehicle scanned for codes and if possible read the operating values for the fuel trim and sensors. If sticking injectors are suspected you can remove spark plugs and see which has excessive carbon deposits.
Nov 04, 2017 | Cars & Trucks
Blowing white smoke
use a good gas additive and non ethynol gas
should clear it up
Dec 07, 2013 | Cub Cadet Snow Blowers. 26 in. Two-Stage...
1992 grand marquis ls. My car has white smoke come out when I reverse alot of times and when Im sitting at a red light and take off i see a cloud of white smoke, but it evaporates quick, it doesnt come out...
Could it possibly be that you may have to much or not enough transmission oil or even water in your transmission being its an automatic transmission or maybe your clutch needs adjusting or replacement if its a manual/standard transmission
Sep 27, 2013 | Mercury Grand Marquis Cars & Trucks
I have a 2002 LW200 that for the past week and a half has been randomly going into misfire fits for about 30 seconds when under load. The 'Check Engine' light starts blinking and it blows one big puff of...
I would say you need to take your cat off and check to see if the monolith is blocked/broken up. The big puff and black smoke tell me you are getting a pressure build up, a blocked/broken up cat is the most likely cause of that.
Sep 13, 2013 | Cars & Trucks
4d56 injection pump,after install engine still high and smokes alot
recheck the injection timing as you may be 1 or 2 teeth out
Jul 22, 2013 | Cars & Trucks
1999 jeep grand cherokee.uses alot of gas idals bad.new fuel filter.blowing black smoke.hit the gas.and it will get away from you...need help...
Can be a bad O2 sensor. Check with a scanner which shows live data the 1-1 and 2-1 (upstream) sensors. Good sensors show a rapidly fluctuating voltage from 0.2 to 0.8 V. When the sensor has a steady voltage, then its most probably bad. There is no check engine light and no fault codes set?
Jul 18, 2013 | 2000 Jeep Grand Cherokee
Potiac fire bird starts hard.
Sorry but white smoke is a sign of water getting into 1 or more cylinders.I would pull the oil dipstick and see if it looks like a creamy color.If it does then you may have a blown head gasket or a crack in the engine block somewhere.
Oct 23, 2012 | 1998 Pontiac Firebird
Loud knocking in engine with white smoke
Hi Tracey P, sounds like you have a TERMINAL problem! If this noise and smoke symptoms came on suddenly while driving, and your performance is impaired, then I would suggest you might well have lost one cylinder dur to component failure. That might be a piston breaking up, a valve dropping or perhaps a combination of the two. I would seriously suggest that it's time to remove the cylinder head/s to check what exactly the problem is.
Jun 11, 2012 | 2001 Ford Focus
23 hp b&s leaks oil but also as mowing you can see
well if it runs the carb is okay the smoke is just changes in how the carb loads up most of the time unless its not smoking all the time.and most mowers leak from around the dip stick or the crankshaft seals.hope this helps would be curious as to where the oil is coming from.good luck
Aug 26, 2011 | Husqvarna Garden
I have true duels on my 1986 chevy pickup. It has a 305 motor. It only smokes on the passenger side of the tail pipe blue smoke only when the motoor gets hot. If im going down the road it stops. When I...
Bad news. Depending on what your mileage is, you can have a burnt valve, sticking lifter, bad piston ring all on the right side of the engine. The blue smoke is burning oil. Oil from the crank case is being compressed up into the cylinder and being burned. You will have to get a compression check on that side of the engine. You check the compression one sparkplug at a time while the engine idles. A loss in compression will tell you what cylinder is failing.
Good luck and thanks for your question and I hope my suggestions help. burdfrenzy
Visit My eBay Store!
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Jan 04, 2011 | 1986 Chevrolet Chevy
Dayton E51 Oil Filled Utility Heater Logo
261 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
