Question about Android Cortex A8 - 8 Inch Touchscreen 2.2 Froyo WiFi Tablet
I have a Flytouch 8 and cant get any connection using the USB lead to my computer help
The tablet is a Super Pad V111 Running Android 4 but no matter what I do when I plug the usb lead in either port I cant get my laptop to see it I want to transfer some music onto the sd card
How do i reboot a fly touch v10 tablet
Tony, you mean reset, Right ?
Check the attached links, to see how to reset.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to do Manual Factory Data Reset on Superpad Tablets Android 4 0
How to reset the SuperPad Flytouch 2 Google Android OS 10 inch
How to Do Manual Factory Data Reset on Flytouch Tablet The Classroom...
Superpad VI How to reset to factory defaults FlyTouch 3 Superpad 2
Mar 08, 2016 | Tablets & eReaders
How i recover my infotmic tab
Depending on which version you have please see the following notes:
How To Factory Reset/Recover the systerm On Your Tablet PC(Flytouch 2/SuperPAD 2/Infotmic tablet 2)
1. Press "Power" and "Home" button at the same time, hands off until you see the words on the screen.
2. Select:"wipe data/factory reset" with the "volume" button, and then press "menu" button.
3. Select:"Yes -- delete all user data", and press "menu" button.
4. Wait until you see" Enter erase_cache Data wipe complete" .
5. Press "reset", calibrate it and set the language.
How To Factory Reset/Recover the system On Your Tablet PC(Flytouch 3/Flytouch 4/SuperPAD 3/Infotmic 3)
1. first press the "MENU" key, keep pressing the "MENU" key while you press the "POWER" key, remove your hands when you see "recovery" from the screen.
2. Wait a few seconds until it is done. And then the system will start..
Precautions
A power failure during the firmware writing operation may disable the tablet PC.
* Use a fully charged Battery or dedicated AC Adapter for the firmware update.
* Do not shut off the power during the firmware writing operation
Feb 04, 2015 | Tablets & eReaders
I am trying to fix a friend's digital2 tablet the s/n is m961gpl1312 and every time it starts up it goes to the Android recovery page and I've tried to factory reset it and then restart it but it still...
you probably will need to update the firmware
D2_961 Firmware Update Instruction:
1. Download the D2_Firmware in the link below
2. Use an archiving software (Winzip, WinRar, 7 zip etc.) to extract the Firmware Update package and export it to your computer's local disk (ex. C:\)
3. Open up the zip file and there will be 3 folders as shown in image
4. Open "Pad Product Tool 1.05_02" folder and click on "setup.exe" to install update tool.3-284x233.png4-284x233.png5-284x177.png
Click "Next" all the way until the program starts installing. Click "Close" when the software has done installing.
6. Click the 7.png icon and choose the firmware file "jellybean_atm7029_m2909_131216.fw" from the "FW_m2909_961_1115_1216" folder.
7. When the firmware file loads, it will show up on the PAD Product tool.
8. Now, click and hold down the "Volume - "key on the tablet.
9. While holding down "Volume - " key, connect the tablet to a PC using the USB cable.
10. Still holding down "Volume - "key, use a paper clip (or a small pin) and press the "Reset" button on the back of the tablet ONCE (and let go)
11. The 9.png icon will turn into 10.png . Click it to start the firmware update.
12. After the update is complete, remove the USB cable first, then turn on the tablet.11.png
13. The initial start up time may take up to 50+ seconds.
14. After initial start up, tablet will require a reset. Please press and hold the reset button for 10-15 seconds to reset the unit.
http://cloud.d3reaction.com/public.php?service=files&t=2ff2083703cca9cfa4050bd47a793864&download
Jan 19, 2015 | Digital2 Tablets & eReaders
Frozen screen
hold the re-set button down until the tablet shuts itself down if you have already done this and it does not work and you have had your tablet for less than a year usually the company will fix it for free or send you a new one free of charge because it is a problem with tablet not something you did.
Nov 11, 2013 | Flytouch 8 Superpad VIII
Flytouch superpad 9 sticks on android logo,i need instruction on how to reset
Doing a hard reset will delete all your saved files and application. Press and hold the POWER, MENU AND BACK buttons while turning the power on After doing that action it will automatically hard reset your device, no confirmation, just wait for the proess to be completed and thats it
Sep 17, 2013 | shop-fun 10 Flytouch 9 GPS Tablet PC...
Flytouch 3 android acore problem
I also posted a problem, and I am wondering if you ever received an answer to yours ? thsuttle
Jul 02, 2013 | Flytouch Google Android 4.0 tablet
Reset vigo android
This works with devices having physical home button:-
1. Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
or you can Check my blog how to reset your tablet lol,
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Feb 18, 2013 | Android Flytouch 3 8gb 10.1 Inch Super Pad...
Users manual needed
Try this website: http://www.crashzilla.com/support/
The manuals for Flytouch 2 & 3 are on this page in pdf form.
Hope this is of help.
Jan 16, 2013 | Android Flytouch 3 8gb 10.1 Inch Super Pad...
Android Cortex A8 - 8 Inch Touchscreen 2.2 Froyo WiFi Tablet Logo
83 people viewed this question
Top Android Tablets & eReaders Experts
Yoav Shilon
Yoav Shilon
Lawrence Oravetz
Are you an Android Tablet and eReader Expert? Answer questions, earn points and help others
