Question about Kodak EasyShare C340 Digital Camera
Memory card i used wallmart site to download pics, with the usb, when i was done turned the camera back on, the message i get says memory card is protected, reset switch on memory card, i have done this several times and it is still there.i can not remove it or take pics, but i can get into the review option. help.
  • Anonymous Jan 27, 2009
    I wanted to delete pictures once the memory card was full. When I tried to do so, the message says "memory card is protected-reset switch on memory card". Pushing the white slider button toward the prongs does not help. I will try the tape solution mentioned, but It's a little worrisome.
    Looking forward to help. E.
    Sergeant:
  • 367 Answers
There is a catch inside the camera that is possibly out of whack. You need to make sure the camera itself is not moving the security slider on the memory card. This would be due to puting the card in wrong or just from wear on the camera.
Try securing switch on memory card to write position with either tape etc. Make sure not to get ape stuck in slot so don't use too much.
Posted on Jan 20, 2009
The camera doesn't download pics to the computer. It reads
TRANSFERRING PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and isinexpensive. You can copy photos from other cameras and you can also downloadphotos off your memory card to someone else's computer without the need ofinstalling any programs.
May 05, 2012 | Canon PowerShot SD1200 IS / Digital IXUS...
Inserted 4 GB memory card. new camera trying to take a pic and I keep getting the message card protected.
Memory cards particularly SD or SDHC have an option to protect the files from accidentally deletion. This is done by moving the small part of the memory card to the 'lock or unlock' position. Try to look for this small switch on the side of your memory card.
Dec 26, 2010 | Vivitar ViviCam 35 Digital Camera
I downloaded my pics off my memory card to my laptop now the memory card is reading when i turn on my camera memory card is write protected what does that mean? i have a nikon coolpix s60. when the memory...
Look at the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 22, 2010 | Nikon COOLPIX S60 Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Memory card showing 'no image' after trying to upload
Sounds like you didn't use the "safely remove hardware" function when you disconnected the USB cable. This can corrupt the card and even the camera. You could try using a separate card reader to download the pics from the card. If that works, and the pics are safely downloaded, then you should format the card in the camera to erase and optimize it. If it doesn't work, take the card to a Walmart that has a Kodak Picture Kiosk and it should be able to read your card. You can print the pics or even make a cd of them. Then, format the card in the camera.
Apr 01, 2010 | Olympus FE-370 Digital Camera
A memory card "write protected"
Get a card reader and download the pics from the card to your computer. Then, format the card in the camera.
Dec 23, 2009 | Cameras
Fujifilm FinePix Z20fd protected card??
The memory card should have a little switch on it, try it in the other position. It is a safety lock to stop it getting wiped.
Feb 13, 2009 | Fuji Finepix Z20fd Digital Camera
Write Protect error and I think all my pics dissapeared!
If you are using an SD card, it could be possible that the Write Protect tab (the yellow tab on the top right) is in the 'lock' position. Slide it back and try again. If this does not work, make sure you are using the card and not the internal memory to store images.
Feb 05, 2009 | Olympus MJU 400 Digital Camera
MEMORY FULL ?? CD310CE
if your cam is using a sd card, the card could be locked, theres a little switch on the side of the card try using that and see wat happens. its tiny on one of the sides.
Jul 01, 2008 | Cameras
Memory card problem
Download PC Inspector from www.convar,com run the stick through this program- if the images are there it will find them But of course no images may have been recorded Sony Tech Help Team will tell you more about the meaning of 'Access'
Jun 23, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Kodak EasyShare C340 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
