Need to replace broken plastic gear on cutter SN121599 shredder
t_vinson57
  • 58 Answers
SOURCE: T7CM Fellowes shredder -- internal parts
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
  • 3 Answers
SOURCE: NEED A REPLACEMENT PLASTIC GEAR THAT DRIVES THE UNIT
This Shredder is an Aurora AS650C Rebranded for Walmart as Durabrand. You can call Aurora at 800-327-8508 8-5 PST and tell them that you need one of the plastic gears for the WM6X Durabrand, they know exactly what your talking about, and will offer you two gears. The one that is in contact with the drive motor is gear "A" and the Plastc reduction gear that drives the steel gears is gear "B" Hope this helps
Posted on Jun 04, 2009
  • 6 Answers
SOURCE: where do I get a gear to turn the shredder
Her
Date: Thu, 9 Jul 2009 11:16:33 -0400
Subject: TS4500 from Winsource Ind.
To:
Rick,
This TS4500 shredder had been discontinued for more than 5 years. The factory did not make any spare parts for this model.
Thanks,
Victor
Customer service
e is my response
Posted on Jul 11, 2009
  • 32 Answers
SOURCE: I need the large main drive gear for the Fellowes PS60C-2
200$ shredder or a 6$ replacment gear ,,,, great advice
takes about 10 min to replace the gear too
Posted on Aug 31, 2009
  • 4044 Answers
SOURCE: plastic teeth are broken
You could possibly replace these but it would be more cost effective to just get a new one.
Posted on Nov 03, 2009
Where do I get replacement gear for the shredder?
try a appliance repair shop for a supply agent for parts
office supply shops that sell shredders may be able to give you the names of repair agents
if it is more than 5 years old then junk it and get a new one as the cutter rollers will be blunt and probably the reason the plastic gear failed
Jun 19, 2015 | Tech Solution TS-6000 Shredder
Runs but doesn't feed paper and shred
Hi, If the shredder teeth / cutters arent moving, then there is most likely a broken/stripped gear or a gear with broken teeth.
If the cutters are moving, then look to see if there is something obstructing the entrance slot where you place the paper.
Good luck.
Mar 12, 2015 | Office Equipment & Supplies
The cross cuts are not working
It sounds as if the gears that turn the cutters is either broken or is turning freely on the shaft w/o engaging the cutters. If this is the case you will have to replace the gear(s). The cost of the gears may entice you to buy a new or refurbished shredder. Below is the manual for your machine, it may be of some help-just maybe.
Fellowes Shredder Manuals
Feb 13, 2014 | Fellowes Powershred 99Ci Cross-Cut...
Plastic separator missing
It is a tedicous process but it can be done. Disassemble the unit (remove the gear cover). remove the cutters and use an end plastic and place it where it is most needed, usually somewhere in the center of the cutters. Make sure the cutters are oriented in the same direction so as not to jam the paper. Reassemble in reverse order. Make a diagram of the preassembly and use it to reassemble the unit. Take your time. Perhaps you could request a replacement plastic. I just used a plastic washer on the ends. I do remove shredded paper once in a while but that is just preventive maintainance. Hope this helps.
Dec 12, 2009 | Royal 10X Shredder
Plastic teeth are broken
Nov 03, 2009 | Fellowes DM8C Cross-Cut Shredder
Apr 05, 2009 | Fellowes PS60C-2 Shredder
CUTTER GEAR BROKEN
Good luck, Tom
Jan 05, 2009 | Dahle Kobra 385SS4 Shredder
Motor runs both forward and reverse, but cutters don't turn
How about a hidden 7th screw? If you look at the sticker on the underside where the bar code is you may see a dimple like there is a hollow space under it. If you can't see it, rub your finger over it to find the hole. Just stick your phillips screw driver through the sticker to get access to this last screw. As for the motor working both directions but the cutter doesn't turn it is most likely a broken nylon cog on the drive gears within the white plastic housing at the end of the shredder. There are 3 or 4 gears - all nylon (plastic), my unit had one tooth completely broken off and the one next to it was worn. I am looking into finding parts but I'm not having any luck so far with local service centres. I have a call into the fellowes main 1-800 number to see if they can help. On reviews I have seen this is a common problem. One reviewer was told they use nylon to reduce noise, but of course it isn't going to last long, especially if you ever jam. Nice metal cutters but the weak link is the drive gears that you can't see.
Oct 16, 2006 | Fellowes P600C-2 Shredder
19 people viewed this question
jasbo
jasbo
