Question about Harman Kardon AVR 630 Receiver
HARMAN KARDON 630
MY RECEIVER WHEN IN STANDBY MODE OR POWERED OFF DOES NOT STORE MY PERSONAL SETTINGS, SUCH AS SPEAKER VOLUME, DELAY ADJUSTMENTS, ETC. IT LOOSES EVERY SETTING EACH TIME I SETUP. IS IT THE CAPACITOR? SHOULD I BUY A NEW RECEIVER? PLEASE HELP!
    Scholar:
  • 39 Answers
Hi there, RikSound1. The problem is the C657 capacitor, located on the DSP PCB. It's a 0.047 farad capacitor, 5.5V. You can either replace it yourself, or just hand the info out at your local repair centre ! It will fix the problem for sure, i have fixed that problem already. Thanks, cheebster.
Posted on Jul 10, 2007
    President:
  • 3,130 Answers
If this is an older type receiver, yes there is a special capacitor inside to control the memory. Where it is at is the trouble. I do not remember. You will need to get a service manual to locate it. Good Luck
Posted on Jun 30, 2007
SOURCE:
How do i factory reset my Harman Kardon avr 55 receiver
Troubleshooting Guide
Processor Reset
In the rare case where the unit's operation or
the displays seem abnormal, the cause may
involve the erratic operation of the system's
memory or microprocessor.
To correct this problem, first unplug the unit
from the AC wall outlet and wait at least three
minutes. After the pause, reconnect the AC
power cord and check the unit's operation. If
the system still malfunctions, a system reset
may clear the problem.
To clear the AVR 520's entire system memory
including tuner presets, output level settings delay times and speaker configuration data,
first put the unit in Standby by pressing the
System Power Control button 2. Next,
press and hold the Tone Mode 8 and the
FM Mode Selector ^ buttons for three
seconds.
The unit will turn on automatically and display
the RESET message in the Main
Information Display Y. Note that once you
have cleared the memory in this manner, it is
necessary to reestablish all system configuration
settings and tuner presets.
[email protected]
Jan 05, 2017 | Harman Kardon Audio Players & Recorders
Why is it in standby mode only?
Hi
Harman Kardon is in STBY mode because its in protect mode
it will not start until u fix the problem
so, what is the model number for your Harman Kardon .!
Regards
Dec 28, 2015 | Harman Kardon Audio Players & Recorders
No display but have sound
HI
Try resetting the system . if this doesn't work.
"Service" is needed .
To clear the AVR's entire system memory including
tuner presets, output level settings, delay
times and speaker configuration data.
1: first put the unit in Standby by pressing the System
2. Next press and hold the Tone Mode button 8 for three seconds.
The unit will turn on automatically.
this will clear all the proccessor.
Note that
once you have cleared the memory in this manner,
it is necessary to re-establish all system configuration
Good luck
Kind Regards
Apr 19, 2015 | Harman Kardon AVR 235 Receiver
How do I reset my harman/kardon avr 630 receiver ?
See link for users manual. Instructions for Processor Reset are on page 50.
"Processor Reset
In the rare case where the unit's operation or the displays
seem abnormal, the cause may involve the erratic
operation of the system's memory or microprocessor.
To correct this problem, first unplug the unit from the
AC wall outlet and wait at least three minutes. After the
pause, reconnect the AC power cord and check the
unit's operation. If the system still malfunctions, a
system reset may clear the problem.
To clear the AVR 630's entire system memory including
tuner presets, output level settings, delay times and
speaker configuration data, first put the unit in Standby
by pressing the Standby/On Switch1. Next, press
and hold the Surround Mode Group Selector2
and the Tuning Mode Selector8buttons for three
seconds.
The unit will turn on automatically and display the
RESET message in the Upper Display Line #.
NOTE: Resetting the processor will erase any configuration
settings you have made for speakers, output
levels, surround modes, digital input assignments as
well as the tuner presets. After a reset the unit will be
returned to the factory presets, and all settings for
these items must be reentered.
If the system is still operating incorrectly, there may
have been an electronic discharge or severe AC line
interference that has corrupted the memory or
microprocessor.
If these steps do not solve the problem, consult an
authorized Harman Kardon service center."
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0CCwQFjAE&url=http%3A%2F%2Fwww.harmankardon.com%2Fimages%2Fmedia%2FAVR630_OM_EN.pdf&ei=HjALVeKILsyrNtyXg6gF&usg=AFQjCNG_sg9tBR5xnCJ4wxQ5ilVYI3RSfQ&sig2=kPcGUIhiWGqVexx8yZMpzQ&bvm=bv.88528373,d.eXY
Mar 17, 2015 | Harman Kardon AVR 630 Receiver
My avr 300 goes into standby mode and cannot be turn on. How can i turn it on and what causes this things to happen?
turn OFF avr 300 and unplug the ac power supply and also unplug the speakers terminals,input signal (optical ,coaxial,video1,.etc) after that you turn ON AR 300.
Jun 23, 2010 | Harman Kardon AVR 300 Receiver
No Memory Stotred in Harman Kardon AVR 65
You have a memory cap ,usally located on the front display,that is most likely defective.measure voltage on cap with unit off should measure at least 3-5 volts
Apr 10, 2010 | Harman Kardon AVR 35 Receiver
Hi, I am getting no sound when I connect speakers to the receiver... But the receiver comes on and goes thru all of the menus...
speakers may not be good. volume might not be up high enough. settings may not be right on reciever. i advise you check the speakers first by plugging them into a different stereo. if they don't work, inspect them to make sure they're not blown (cracks in the cone of the speaker). if they do, hook 'em back up and check to make sure there's no headphones plugged in or any settings on the reciever that say speakers or external speakers or anything like that are powered off. hope this helps.
Oct 06, 2009 | Harman Kardon AVR-630 7.1 Channels...
Harman Kardon AVR 500: randomly accelerates volume levels.
The problem is with the actual eltromechanical element on the volume control, my avr 300 does this as well and I'll let you know the secret to avoiding it. There are small indents on the volume control as you turn it, if you leave it half way between indents, it will periodically start reading volume changes, if you're lucky it will go down, if you're unlucky by the time you've noticed it act up your speakers are blown. When you change the volume, make sure the control rests in an indent and the problem will never crop up again. A simple solution if you're the only one that uses the receiver.
Dec 03, 2008 | Harman Kardon AVR 500 Receiver
Two amp
I don't know why you'd set the Peavey to 2 ohm to drive 8 ohm speakers??? My other thought is... I wonder if the phase is correct. try reversing one of the speaker wires Left or right side.
Geno
Feb 27, 2008 | Harman Kardon AVR 630 Receiver
Harman Kardon AVR 630 Receiver Logo
839 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Don Hart
Laser Plus Computers...
Level 1 Expert
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
