Question about HP Laserjet CM2320nf All-In-One Color Printer
My HP Color LaserJet CM2320 won't initialize and print
713printech
  • 32 Answers
SOURCE: HP color LaserJet 2600n stucked on Initialzing
Well we can check and see if the printer is able to run an engine test. This is how you can run this test;
  1. Turn the printer around so the back of the machine is facing you.
  2. Remove the Engine etest button acess door. This is located in the bottom center of the back.
  3. Push the botton once while the printer is on. The printer should print a page with colored horizontal lines.
If the printer is able to print this page there is a very good indication the problem revolves around the PCA formatter board.
The Firmware might be outdated and causing this problem. Worst case scenario the board might be faulty, in that case your better off buying a new machine, since the cost to replace the board will be higher than that to replace this machine.
Posted on Nov 19, 2008
  • 291 Answers
SOURCE: My HP color laserjet 4500 is printing only blank pages
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
Posted on Aug 31, 2009
steveparlin
  • 61 Answers
SOURCE: HP LaserJet 1500... prints color yellow ONLY
Missing or incorrect color
 You have changed the color settings manually. Return the color setting to Automatic. • Windows: On the Color tab of the printer driver, click Automatic. • Mac OS: In the Print dialog box, select the HP ColorSmart or HP Color Quality pop-up menu and then select the Manual option.
 Your print media does not meet the specifications for this printer. For example, you are using coated, glossy, or photo paper. Use a different paper, such as a high-quality paper designed for laser printers. See the user guide for information about print-media specifications.
 You are operating the printer in excessively humid or dry conditions. Verify that the printer environment is within humidity specifications.  A print cartridge might be low on toner. Check the printer control panel, print a Supplies Status page, or view the embedded Web server (HP color LaserJet 2500 series printers only) to see supplies status. (If you are using a non-HP cartridge, none of these sources will provide information about a low or empty print cartridge.) If a cartridge is low on toner, replace the print cartridge.
Clean the sensors and perform a calibration.
The HP Color LaserJet 1500 Series Toolbox is not supported for the Macintosh operating systems. 1 Make sure that the printer is turned on and in the Ready state. 2 Open the Toolbox. 3 On the Troubleshooting tab, click Cleaning Page and click Print. A page with a pattern prints from the printer. 4 At the printer, remove any media from tray 1 (multipurpose tray). 5 Remove the page that printed and load it face-down into tray 1 6 At the computer, click Clean.
Note For even better results, repeat this procedure several times.
The printer automatically performs a calibration when the imaging drum or a print cartridge is changed, and at set intervals that are determined by the total number of pages the printer has printed. For the HP Color LaserJet 2500 series printers, you can change the interval at which the printer performs automatic calibrations by using the embedded Web server.
To calibrate the printer manually Turn the printer off, wait one minute, and then turn the printer on again.
To calibrate the printer from the Toolbox The following procedure must be performed from the HP Color LaserJet 1500 Series Toolbox or the HP Color LaserJet 2500 Series Toolbox, which are only supported for Windows 98, NT 4.0 (HP Color LaserJet 2500 series printers with parallel connections only), Me, 2000, and XP.
Note The HP Color LaserJet 1500 Series Toolbox is not supported for the Macintosh operatingsystems. 1 Open the Toolbox in one of these ways: • On the desktop, double-click the HP Color LaserJet 1500 Series Toolbox or HP Color LaserJet 2500 Series Toolbox icon. • On the Start menu, point to Programs, point to HP Color LaserJet 1500 or HP Color LaserJet 2500, and select the HP Color LaserJet 1500 Series Toolbox or the HP Color LaserJet 2500 Series Toolbox. 2 On the Troubleshooting tab, click Diagnostic Tools (on the left side of the screen). 3 Click Calibrate Now.
Hope this helps!
Posted on Sep 01, 2009
HP Xpert
  • 112 Answers
SOURCE: HP Color LaserJet 2550N. Slow printing takes 16
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Posted on Jan 19, 2010
  • 3 Answers
SOURCE: hp color laserjet cm 1312 window 7 driver
It sounds like you downloaded the PCL Universal Driver. Try the full solution driver or the PostScript Universal Driver. Both allow color prints.
Posted on Oct 19, 2010
Hp color laserjet cm2320
No. Color printer need ALL cartridges with ink to print.
Mar 27, 2014 | HP Laserjet CM2320nf All-In-One Color...
Hp color laserjet cp1525
Here is a link to the HP Support Center Page that describes the Control panel messages for your printer....58.04 is not documented .
Troubleshoot problem for HP Color LaserJet CM2320 Multifunction Printer...
Mar 26, 2014 | HP LaserJet Office Equipment & Supplies
HP CM2320 MFP blank pages come out with printout
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Lang Dibba, Gambia
Jan 30, 2012 | HP Laserjet CM2320nf All-In-One Color...
CM2320 NF won't complete startup. Stalls when initailizing after clicking sound and both Ready/OK light and Attention (!) lights flash continuously. LCD display is blank. Nothing in paper path. No...
This usually indicates a failure of the fuser assembly. This part is what heats the toner to melt it onto the page called fusing. The fuser has a heat roller the turns when you print and when you initialize the printer. The clicking sound is cause when the heat roller is stuck and not turning and the gears are slipping. The clicking sound will come from the back right hand side if this is the case. You will need to get a replacement fuser assemble and swap them out. You can do a Google search for "cn2320nf fuser assembly" to get the correct part number. By the spelling of Colour I am guessing you are in either Canada or Europe so you may need a different part number than the US part, it would be based on line voltage either 110v or 220v
I hope this helps, if so please rate our solution.
BuddyMc
May 06, 2011 | HP Laserjet CM2320nf All-In-One Color...
HP Color LaserJet CM2320 MFP shutting off and on -does not work
unplug the telephone and network cable and restart the printer.
Dec 11, 2009 | HP Laserjet CM2320nf All-In-One Color...
HP Laserjet CM2320nf All-In-One Color Printer Logo
144 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
