Question about Rocktron 001 1560 Utopia G 100 Multi Effects Floor Unit
How to reset ROCKTRON utopia g100 - Rocktron 001 1560 Utopia G 100 Multi Effects Floor Unit
2 Suggested Answers
  • 5603 Answers
SOURCE: My Rocktron Utopia G200 displays
The symptoms indicate either the WRONG power adapter is being used or the adapter is failing. This unit uses a 9VAC (not DC adapter like many pedals) adpater. If you are trying to use a DC adapter or a multiple pedal power supply that is your problem. Use ONLY the correct power supply with this unit.
Posted on Jun 17, 2011
Rocktron starts buzzing when I play it on keyboard
If it's disconnected from everything else, it may indeed be the power adapter. Try a different one, but also try it in a different location as well to see if it's picking up outside interference.
May 04, 2016 | Rocktron Banshee Guitar Talk Box Talkbox...
Why doesn't the parameter adjust knob work?
did you try replacing the potentiometer that the knob is attached to?
Or hook and ohm meter and turn it to see if the changes are smooth and go the full range?
Jun 19, 2015 | Rocktron Utopia G200 Guitar Multi Effects...
Why won't my purchase go thru Is my Visa card not currant???
Visa uses a program called TALON that blocks some online purchases. You have to call your bank and tell them to allow it.
Dec 04, 2014 | Rocktron Banshee 2 Guitar Talk Box Talkbox...
My Rocktron Utopia G200 displays DSP RESETTING, no sound, no controlls possible... What can I do?
Jun 17, 2011 | Rocktron Utopia G200 Guitar Multi Effects...
The sound does not come all the way through the tube like it used to. The sound is faint and not loud at all.
Verify that if using the battery it is a new battery. Also check if you are using the correct power adapter if that is what you are using.
The "gain" control and Output controls should vary the level... make sure htey are turned up.
Feb 14, 2011 | Rocktron Banshee Guitar Talk Box Talkbox...
The light is on but im not getting any sound
Check your power adapter. This unit REQUIRES a 9VAC (not DC) adapter !!!
People are getting these things and trying to use common 9 volt DC adapters like many pedals do, and they juust will not work with these that require AC input.
Feb 03, 2011 | Rocktron Banshee 2 Talk Box Pedal
I'm using the rocktron banshee on a keyboard when I turn up the gain i hear the radio.
You are probably very near a powerful AM transmitter. This is a shielding problem and use of a better quality audio cable between the keyboard and the Talk Box might help as well as CHANGING the length of the cord. Length afects how good an antenna the cord is.
One could put a bypass capacitor in the Talk Box as what you are hearing is "rectification" of the radio station in the high gain of the inout circuit of the talk box... one or two capacitors would likely fix it... I would try 330 Pf caps first right where the cord comes into the box between the signal and ground points.
Jan 21, 2011 | Rocktron Banshee 2 Guitar Talk Box Talkbox...
The active light does not light up when I plug my guitar in and no sound comes out from the talkbox ... But the guitar sound can run through it to an amp where the guitar sound comes out
It sounds like you have NOT connected the power adapter to the box to power it. The guitar sound won't be too loud as you run the hose to your mouth and pick up the sound with a microphone such as a Shure SM57 which then goes to your amplifier. Without the power adapter the internal amplifier will not produce any output.
Jan 08, 2011 | Rocktron Banshee 2 Guitar Talk Box Talkbox...
Rocktron 001 1560 Utopia G 100 Multi Effects Floor Unit Logo
176 people viewed this question
Top Rocktron Music Experts
rhodesworks
James Kovacs
James Kovacs
Are you a Rocktron Music Expert? Answer questions, earn points and help others
