Question about Swift Optics
I have pair of Admiral MK 1 Model 751 10x50 Swift Binocs. Dropped, not in sync. What shoould I do?
2 Suggested Answers
  • 321 Answers
SOURCE: Left binocs out in rain. Now have moisture between
Try to blow hot air inside whit an air dryer
that all ican say from here...
good luck
Posted on Mar 29, 2010
How do I collimate my binoculars please because they have double vision.
It'll depend a bit on the root of the problem.
You can get double vision from properly aligned binoculars if the optics are too far apart or too close, relative to the spacing of your eyes. you'll need to bend them at the central hinge to make sure that both eyes are centered on the input lenses.
If you're still getting the migraine-inducing double image, they probably got dropped at some point. This can be a wide range of difficulty to fix. Here's what I've done in some past cases with flea market binocs that I bought cheap due to the skewed alignment.
For many binocs, the upper (eyeball end) and/or lower (field end) are screwed to the central body of the binocs, where all the folding optics are to widen the lenses from your eye spacing. If they have been dropped, (or disassembled and put back together sloppy), then they may be cockeyed at one of these joins. Look at each seam to the central body and see if any of them have a gap, especially one that is larger on one side than another. You can then apply firm un-screwing twist and see if it will unscrew. if it will, and before you unscrew it all the way, wash your hands and clear a clean surface to work on. Unscrew the segment, inspect the threads for crud that might have got in while cockeyed. Then visually square up the component and gently screw it back in. if it was mis-assembled, the threads may be a bit gummed, and you'll have to be patient to keep the optic square, and back off and start again if it tries to drag over to cockeyed threading. Once it's square, gently working the thread back into place by turning back and forth a half turn back, 3/4 forward, half back, 3/4 forward, can help the thread recuperate. Eventually, it should screw all the way in, firmly, and be square. No more double vision.
For some models, like my Nikon fixed pocket binocs, there's no zoom and just a focus knob. On my brothers pair, it got cockeyed. In that case, I gently unscrewed the locking rings for the glass on the eyeball side. One of them was loose and the lens was a bit cockeyed. In that case, I removed, it (wearing nitrile gloves), cleaned it with eyeglasses cleaning solution and a microfiber cloth, put it back in, screwed the ring in firmly,and it was good to go.
Bottom line, if you have some basic DIY skills, unscrewing the entry optics, or the optics sections, isn't too big a deal. Just be mindful not to let dust (or worse) get inside while you have things open. You can get a lot of fix just from that much.
Good Luck!
Mar 11, 2015 | Fujinon Mariner WPC-XL Binocular
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 | Cell Phones
Need 1 rubber eye shield for swift ferret model 747
Regards, Tony
May 10, 2011 | Swift Kestrel 826 (10x50) Binocular
My grandson dropped the binoculars and now I see double. How can I fix this? These worked great until this happened. I see the screws on either side of the eyepieces but don't know if I am supposed to use...
Hello. When the binocs were dropped one of the lenses popped out of it's retaining frame. If this is an old set you can open it up and see what you can do. However, my recommendation is to call Tasco Customer Service at: (800) 423-3537. Opening it up will void any warranty and introduce dust into the interior which will appear and annoy you. Joe
Apr 14, 2010 | Tasco Futura LE 14-103050-1 (10-30x50)...
good luck
Mar 29, 2010 | Optics
Doesnt sounds right...
Try a diffrent pair of earphones if that does not work the jack is shorted on the media player and needs to be serviced.
Apr 22, 2009 | Philips DVP3960
Wiring diagram for a minn kota mk220 2 bank charger
First. the +/positive/hot wires go to the respective/separate +positive/hot side battery terminals.. and the -/negative/ground wire go to their respective/separate -/negative/ground battery terminals.
The wires from the charger are "paired out".. meaning the + and - pair must go to the same battery. .. you can't mix and match.
Feb 27, 2009 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
The central wheel between the eye pieces is frozen
sounds like you dropped it awful hard. if center wheel wont turn you must have. hard to say without seeing it,but check to see if x-bars are broken. good luck...larry@reichinstruments.com
Jan 14, 2009 | Konica Minolta Activa Sport (8x25) WP...
Bent
Not likely. These binocs are reviewed elsewhere by many, and appear to be pretty much cheap junk.
I happen to have a pair, and the right lens support that is screwed onto the body is cracked plastic.
Maybe with your set, and mine, we could make one good, functional unit... but when you could buy another (ah ma zon dot c o m) for less than 11 dollars, why bother.
Sorry... but they just aren't really very well made. As to the bent focus mech you have, I doubt you could obtain a part, anywhere, to replace the bent one. You might try to straighten the bent part by careful disassembly of the body, but do know that there's a bunch of glued together parts in these binocs, and not too many parts that can be removed/replaced with screws.
Oct 29, 2008 | Vivitar Binoculars 7 X 50
Optics Logo
75 people viewed this question
Top Swift Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Bill Laudeman
Bill Laudeman
Level 1 Expert
Are you a Swift Optic Expert? Answer questions, earn points and help others
