Question about Peg Perego John Deere Gator HPX Ride on Toy
How do I tell which gator I have?
I have a 12 volt is there a model number.What is the difference in measurements of the floor board from this model to the new model out? Thanks
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Look under the dash and there is a sticker with the model number on it
Posted on Jan 09, 2013
  • 156 Answers
SOURCE: i need a new batery charger for my peg perego
I bought my Peg Perego Charger at
http://www.shopjandl.com/mecb0034.html
They fit the 12 volt blue batteries for Peg Perego.
Hope this helps
Posted on Jul 10, 2009
SOURCE: Please let me know how I can change the rear tires
I want to add additional traction to my John Deere electric Gator. I have heard that you can somehow slip a bicycle tire over the plastic tires. Has anyone done this and how do you do it?
Posted on Dec 23, 2009
bayyagg
  • 1672 Answers
SOURCE: Is my battery bad or do i have another issue? When
Your battery needs replacement! It has 12V alright, but the CURRENT is way below wut it suppose to give! Hope you will be enlighten about that!
Posted on Nov 10, 2010
  • 110 Answers
SOURCE: is there a fuse in the pegperego gator 12 volt
yes, you have to remove the blue cover and then they are very easy to change. just remove the screws.
Posted on Jan 28, 2011
  • 110 Answers
SOURCE: where can i get a rubber tires for a Peg Perego
the whole tire would be difficult to replace with a rubber one, but you can put bmx tires on the plastic wheels and that will give much greater traction, but shorten the life of the gearboxes. here is a link to how to do it.
http://www.youtube.com/watch?v=AAySJVt6bys
How do you tell the difference between a 6 volt coil and a 12 volt coil on a ford 9n tractor
if you have a way to test OHM , a 6 volt coil should be around 1.5 ohm and a 12 volt would need to measure around 3.0 ohm..Don't know how accurate , but it should give you some indication
Sep 17, 2017 | Ford Garden
How many volts is 1200 watts
Watts to volts doesn't translate as they are different units to measure things. Watts is a power measurement while volts is what is trickling through the cable. You could have 12 volts at 6000 watts or 240 volts and 5 watts, depends on usage. If it's for a car audio amp, it will be generally 12 volts to power it which at 1200 watts means it will run at around 100 amps current according to ohmslawcalculator.com
Oct 14, 2014 | Car Audio & Video
Hubby went to charge the gator and the plug part that goes into the wall outlet became very hot to the touch. What could it be? Could it be the charger or the battery?
If the battery is completey drained or very low the charger will get hot to the touch, The charger put out 14.6 volts and then trickle down to 13.8 volts once charged, i would check the charger with a multimeter and check and see what kind of volts its putting out. if the battery is bad the charger wont think that it has completely charged it and will continue to push 14.6 volts into it
Apr 16, 2012 | Peg Perego John Deere Gator HPX Ride on...
I want to test motors on pergo gator can i hook up reg 12 volt lawn battery to test that they spin or can i test charger
no don't hook it up to regualr 12 volt battery, first check the voltage of the peg perego battery and make sure that its putting out 12 volts, then you can use jumper wires and connect to the motors with the peg perego battery and verify that they work
Jun 25, 2011 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator HPX 12 Volt Ride on Toy by: Can anyone tell me how to get the tires off of a j...
1. Remove the center caps from the rear wheels
2. use a 13mm wrench on each side and loosen the bolts
3. remove the rear wheels
May 18, 2010 | Peg Perego John Deere Gator HPX Ride on...
Help for my childs John Deer Gator
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
May 09, 2010 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
44 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
