Question about Abit LG-95Z Motherboard
No beeping, no video displayed.
I installed this Motherboard today, and when I tried to turn on the computer, nothing happens. The CD-Drive whirrs, the Fan goes, LED's in the case turn on, but nothing else. I was told to find a beep test result, and to post the beeps on another forum, but I cannot find anywhere to put the small speaker that came with the mobo! Can someone please help me?
  • 3 more comments
  • Joel Birney Jun 30, 2007
    Sure! Mobo is... Abit - LG95(z) and ram is... unlabeled... But it says... US1X128064BML293, 240 PIN. Other serial type thing is HYS64T128020HU-3.7-A
    Also, I can't find where I am supposed to place the small speaker on the MOBO, if you could find a picture of the location, that would be amazing!
  • Anonymous Dec 05, 2007
    Same issue. ABIT LG-95Z motherboard, 2GB DDR2 665MHz unbuffered RAM from Crucial.
    Sorry, should've been more explicit - just like original report - no beeping, no video.
  • Anonymous Apr 05, 2008
    same thing, just built a system with this board, turned it on , no beeps, no video either, i tried to install an old pci video card and same, no beep, no video, junk.
No, nothing. I exchanged the board at Microcenter, hopefully the new one will work better.
Posted on Dec 05, 2007
    President:
  • 4,402 Answers
Disconnect everything external to the computer and then turn on anything happen ?
if still nothing remove all cards, anything?
remove all ram anything, ?
Hi, The beep test is notrmally done with the small speaker attached to the computer internally, there could be a problem with the RAM installation check the RAM compatablity with the mother board, give me further details of the make and model of the mother board and RAM , i will try to help you.
Posted on Jun 30, 2007
  • Anonymous Jun 30, 2007
    check the RAM compatiblity
    that will help
    let me know the details of RAM and Mother board
    i will try to help
SOURCE:
When the 4 pin computer power connector is attached to the P4M900T-M2 V1.0 motherboard and turn the power switch on nothing happens, when I took the 4 pin power connector off from the motherboard,the power...
I had this issue once, turned out to be a grounding issue. Remove the motherboard, place it on a piece of cardboard, connect all needed parts (power, hard, memory, video, cd drive. Now try to power it up. If it comes up go to a home improvement store and buy some rubber or paper washers to place between the motherboard and case, were the mounting screws go.
Hope this helps
Feb 15, 2012 | EliteGroup P4M900T-M (V1.0) Motherboard
I have a Compaq Presario SR2020NX. I press the power button and the fan comes on, the green light is bright , the cd drive blinks then stops as if the computer is starting but nothing happens. The fan...
Disconnect the drive and try to boot to the BIOS (usually with F1, F2 or Delete key). If that doesn't work, try removing all cards from the computer (except a video card if the video port is not on the motherboard). If you can boot this way, try inserting back any removed cards to see what hangs it. Do you hear any beeps when the computer is booting (beep codes)?
Sep 24, 2011 | HP Compaq Presario SR2020NX PC Desktop
Hi i have a acer aspire 5100 on turn on i get 1 long beep and 2 short beeps.the fan is on and i can open cd drive but nothing on screen i took the ram out and that stoped the beeps but still no screen help...
Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.Video (Mono/CGA Display Circuitry) issue.Try to disconnect/connect the video card. If nothing happens, there's a possiblity that the problem is with the LCD cables or the LCD itself.
Hope this will help...Your response is very much appreciated...
Feb 06, 2011 | Acer Aspire 5100 Notebook
No display when starting after installing in new machine. I bought TWO ECS MCP61M-M3 motherboards for my kids for Christmas and have the same problem with BOTH. This is in a completely new computer build....
First thing I would do is try using the monitor on another working computer to see if it works. If so, you have eliminated that as an issue.
Kind of hard to fathom that you got two fubar mo bo's but as they stay in the street, sh-- happens. However, The lack of a beep means that the bios is not posting. When you turn on a computer, the bios does a check of internal components and environment - if all is ok, it beeps and then has the hard drive install the operating system into the computer's memory. And if something is wrong, the bios will usually give out certain beeps that are coded such as when you have bad memory, no memory, etc. But you are getting zippo, and no video at all on your monitor - this is one of the few times you wish you had the blue screen of ***** because with that at least you know your hardware is ok but your software has an issue.
The conditions you have reported would seem to indicate that the bios chips on both units are corrupted and not working. U might also make sure that the memory chips are good. A bad chip, not a missing chip, will sometimes prevent the mo bo from booting up.
If you also remove all the memory and turn on the witch, if the bios is working it will beep like crazy. If nada, bios is dead.
If boards are new as you indicate I would return for exchange.
Mar 03, 2017 | EliteGroup ECS MCP61MM3 (V10) AM3 NVIDIA...
I have a Dell Inspiron 546 running Windows Vista. When turning it on the Start button lights up, but the display very quickly goes into power saving mode. Nothing further can be done. The computer or...
Hi. Were you able to see the the DELL post screen when you turn on the computer? Take out the battery and unplugged the power adapter from your computer and to the wall socket. Press and hold the power button for 30 secs. Put everything back in then turn on the computer.
Nov 07, 2010 | Dell Inspiron 546 MT Desktop Computer
Dimension 4400 nothing happens when i power up cd doesn't read hard drive doesn't turn the only thing it does is startup beep
The bios is configured to boot to CD? Monitor turns on, and you can see the Bios? HardDrive has an OS installed? There may also be a ram / motherboard issue. I would also test the video card. But I would start by Unplugging the power cord, and reseting the Bios. If you know which jumper, use it, if not just remove and after about thirty seconds re-install the onboard QUATER battery. After this boot to Bios, check all the Boot - Drive parameters and try to boot up. If that fails continue with the Ram Check, the Motherboard, and the HardDrive, and the Video Card. Hope this helps.
Dec 17, 2009 | Dell Computers & Internet
How do iknow if my motherboard is bad on my computer
Usually, by a process of elimination.
First, inspect the motherboard -- all those round towers are capacitors; any that are leaking (brown stuff) are bad news; any towers bulging at the top, instead of flat, are bad news.
If you turn the computer on, and the fans start to spin, and the disk-drive makes a bit of noise for a short time, then the power-supply probably is NOT the problem.
If you turn it on, and you get multiple "beeps", then it's either the RAM or the video-card.
If you turn it on, and nothing happens, it's the CPU or the RAM or the power-supply.
Disconnect the disk-drive, the CD-drive, the floppy-drive, and all USB devices. If you then turn it on, and you don't get a single "beep",
it's the motherboard or RAM or power-supply.
Test the RAM in another computer.
Temporarily connect a different power-supply to your computer;
if it starts properly, it's your power-supply.
Dec 05, 2009 | Acer Computers & Internet
Trying to fix old computer
remove the external display card boot ur machine with on board then disable the on board display and then install your external display card and then connect it to the monitor
Dec 29, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Pc wont boot
Have you recently experienced a power surge or had an electrical (thunder) storm in your area? Potentially your motherboard and/or processor could be toast since the fan running and CD Rom drive opening will continue to function because they receive power separately from the motherboard via the power supply. If you have access to a different compatible processor, you could try to install it in the motherboard to rule out a motherboard failure, otherwise you're looking for a new motherboard.
Jan 12, 2008 | Computers & Internet
Abit LG-95Z Motherboard Logo
181 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Ekse
Bart Fonteyne
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
