Question about Goodman Manufacturing Goodman HKR-10C 10kW Electric Heat Kit 34,100 BTU Circuit Breaker
HKR-10C FURNACE BLOWER WONT KICK ON
HEAT STRIPS HEAT UP THEN CIRCUT BOARD MAKES A POP AND BLOWER WONT COME ON...IT WONT COME ON
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 37 Answers
If you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
Posted on Jan 08, 2013
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Luminux furnace won't kick on. Makes sound like its trying. All hoses are clear. Shows 3 lred lights flashing. 1. 2. 3. Any help would be greatly appreciated. Thx
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition providing current to flame sensor--main blower motor comes on after a set time
Feb 08, 2014 | Luminox Watches
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
WEATHER KING GAS FURNACE . BLOWER MOTOR COMES ON INSTANTLY ON CALL FOR HEAT AND WONT SPARK IGNITE.
You have a high temp safety open. The control board sends a signal through all safeties first. And if there is a safety open, the board believes the unit is overheating, so it engages the blower to cool it down. The safeties are normally on the blower assembly, near the burners, and near the heat exchanger. Hope this helps!
Sep 24, 2017 | Heating & Cooling
I have a GMP100 furnace and I replaced the control board because the blower fan wouldn't kick off now and then. It all works great but the main blower only stays on about 45 seconds after the burner turns...
Check the board for a set of dip switches. Check against the old board for switch positioning. These control fan on/off times. Ensure you turn power off before changing switch positions. If no dip switches,??
Dec 04, 2009 | Refrigerators
Electric furnace. Just replaced the controller board but no heat. The blower does come on when the thermostat gives the heat command and I was wondering if that means the relays to the furnace coils is...
On a Trane furnace the fan realy must energize before the electric strips will come on. On the thermastat. See if there is setting for electric heat. This will bring the fan on and the strips should come on. First just turn on your heat and and turn fan to on postion if it works you need to set tstat to electric heat mode. Most of the time there is sswitch in the back of the stat that says gas elec. Turn to electric. Rus
Oct 29, 2009 | Heating & Cooling
York Diamond 80 Issue. AC and Blower work fine. Heat will not come on. Circut breakers are fine, all power is on. Any advise.
Open the furnace door. Turn the thermostat on, and hold the power switch on. Look for the service code on the control board. That should tell you whats wrong with it. www.FastACservice.com
Oct 12, 2009 | Heating & Cooling
I replaced my Janitrol 7 wire thermostat with an RTH7500 which now controls my heatpump system. The switches on the Janitrol were cool - off - heat - Em Heat. Does that mean I have auxiliary heat? There is...
There should be electric heat strips in the airhandler.
They automatically come on when the unit goes into defrost, the thermostat is turned up more than 7 degrees over the indoor temp or if the outdoor temp is just so cold the HP cannot keep up.
Tat is your auxillary or emergency heat.
What does the new t-stats installers booklet say that the 0170 function and #2 #7 options are for?
If it is for gas vs elec heat then set it on the elec option.
The difference is that in gas heat systems the blower comes on a few min AFTER the furnace fires up to allow the heat exchanger to get hot.
In an electric furnace the blower has to come on emediatly because the heat strips get hot emediatly and if the blower is delayed the system will shut of in high temp overload.
Dec 18, 2008 | Heating & Cooling
Goodman gmp075-3 led blinks 5 times
I Also have the same and other problems with my furnace model # GDS80703AXBB. First the LED kept blinking 4 times and I too jumped the primary limit, that didn't kelp. After several attemps I moved the wires going to the circut board and everything starting working again. After a week It stopped working again, so I pulled the plug out of the circut board checked all wires for for a bad connection plugged it back in. Now the LED blinks 6 times again I move the wires. Then the LED blinks 3 times. Then the transformer burns out. I have burned out 2 transformers and I have ordered a new circut board.
Oct 22, 2008 | Goodman GMS90703BXA Heater
Goodman Manufacturing Goodman HKR-10C 10kW Electric Heat Kit 34,100 BTU Circuit Breaker Logo
177 people viewed this question
Top Goodman Manufacturing Heating & Cooling Experts
Robbie Daniels
Level 1 Expert
snowmanii
ray gallant
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
