The screen will cut on for a split second and then cut off.
  • 7,627 Answers
There is a tiny switch that turns the backlight on and off, located near the hinges, if the hinges are loose or the switch is dusty,dirty it may not be function correctly. With it comming on and going off I don't think it's the switch. That leaves the inverter or a pinched wire. If you connect it to a external monitor does it work? Her's a video to assist you in troubleshooting: http://www.youtube.com/watch?v=2Yi6GNFcP3w. There are other videos, you can get a general idea. Your laptop has a few miles on it, problems will start to popup.
Posted on Jan 07, 2013
Green power light comes on but screen is black
could be 1 of many problems.first does it come on for a split second then cut off?if so probably the inverter board.second does it not power on at all?id ay that was problem with the power board.look for buldging capacitors on the board.and ones buldging,replace with like kind.simple fix
Mar 16, 2013 | Haier HL37E 37 in. LCD TV
Google maps: street views keep going to a split screen with street on top and satellite on bottom. Also street views in full screen mode disappear after a second and the split screen mode reappears.Very...
When you go into the split screen, and you don't want to be there, just click the little arrow in the lower right hand corner (the arrow pointing down and to the right). This will reduce the bottom map portion into a small overview box in the lower right portion of the screen. It only takes a second to get out of the split screen that way. To get back into split screen, click the arrow in the upper left corner of the overview box (the arrow pointing up and to the right).
Aug 15, 2011 | Computers & Internet
Xtpe 2.1 petrol manual 2003 cuts out suddenly for
Check for leaking manifold if problem occurs around 3000 rev point
Feb 16, 2010 | 2003 Jaguar X-Type
1985 Porsche 944 Engine cuts off for split mili seconds.
check in the truck area where fuel pump relays and wires are.something is loose look at fuel pump relays and fuses see if they all the way in place.
Apr 12, 2009 | 1991 Porsche 944
HI
I'd definitely check the fuel pump, had a similiar fault with mine, all seemed ok until upon closer inspection there was a hairline facture around the inlet pipe on the pump which was drawing in air and losing the pressure in the fuel system
Mar 15, 2009 | 1986 Porsche 944
Honda Civic 2002 1.7, when driving the car, it's seems like the car switches off for a split second and the engine management light shows for the split second. The rev counter drops. When cutting out...
Check all the wires. Especiality the ground wire.
Battery terminal.
And grounds mounted on the intake.
Normally when no codes are present, Is a lost of electrical power.
Jun 05, 2008 | 2002 Honda Civic
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
