Question about Baby Lock Sewing Machines
I can't change the stitch on my babylock Encore. It won't change from "01" setting. How do I fix this?
My machine sat for a while. When I went to sew on it again, it worked, but only on one stitch setting, "01". It wouldn't allow me to change it to any other stitches. Please help. Is there a reset button or somthing that I cannot find? I can't afford to have someone repair it, so I would like to try to fix it myself. Please Help!!
RickE1
  • 202 Answers
SOURCE: long stitch!!
If your feeddogs look like they are working properly it could be this...I have seen and corrected a few problems like this in the past. What can happen is your needlebar is stuck in the Basting position. Basting is when even though the machine is turning properly the needlebar will only go down every few revolutions. There is a small pin in the needlebar that disengages when Basting stitch is selected (by an electro-magnet). Usually these will stick from hardly ever or not using it. Old oil gummed up usually but can happen in a drop. The pin will not go back in. Possibly (probably also) the needle bar got turned ever so slightly knocking the hole for the pin slightly off so it can't go back in. In which case the needlebar has to be turned to the correct alignment. This should only be fixed by a trained tech. Everyone... use the basting feature occasionally. We have a saying about those. "Use it or lose it".
Posted on Aug 27, 2007
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
SOURCE: Wrong type of stitch/tension not working
Found a solution to my own problem.... hope this helps someone else. Make SURE the bobbin case is seated correctly! (follow the instructions carefully). Don't put the cover back on right away after you put the bobbin case in. First check and make sure it doesn't move when you turn the hand wheel.
Also, when threading the bobbin make sure the thread passes down through the tension adjusting spring of the bobbin case.
Posted on Aug 24, 2008
SewTechWayne
  • 186 Answers
SOURCE: 5932 knotting every other inch
Try oiling the hook if you haven't recently.
Check you needle plate and hook for damage, they may need to be buffed or sanded smooth.
Check your upper tension discs for lint and double check your upper thread path (proper threading).
There are other things like hook timing, needle clearance or broken check spring that may be wrong but you need a technician for those things.
best of luck!
Posted on Jan 31, 2009
  • 36 Answers
SOURCE: Brother XL--2600 Sewing Machine not picking up Stitches at all!
Take the thread out, Take the needle plate out Watch as the needle comes comes down, make sure the hook is just above the eye of the the needle as it makes its pass by the scarf of the needle if not refer to my post on timing.
Posted on Jun 02, 2010
I'm trying to get my mother's Singer Touch & Sew Deluxe 645 to sew a straight stitch. I don't want to buy a manual since the machine rarely gets used and I have limited time to "fix"
Not much information to go on. What do you mean it won't sew a straight stitch. It just won't sew a straight line? It won't form a stitch? What?
Dec 12, 2012 | Singer Sewing Machines
The pattern (stitch) selector doesn't work when I turn it
it sounds like you need a new pattern selector dial & it wouldn't
hurt to have the machine checked to see if the internel part of the
dial is ok inside
Oct 11, 2012 | Singer Featherweight II 117
I just bought a Singer Stylist 457.
if you bought the machine used, then it's possible that a
cam or gear is either worn or damaged. & needs to be check at a sewing machine shop.
if the machine is new,,then take the machine back to where you
bought it & tell them about the zigzag, even let them try it & see
what happens, I been sewing for over 30 years & I wouldn't keep
it,, if you bought it new,, I'd get another one
Aug 10, 2012 | Singer Sewing Machines
I have the Mega Quilter and Quilters Cruise Control. My stitches are very inconsistent.
I agree to have the regulator check, & even having the whole machine checked wouldn't hurt.
May 15, 2012 | Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Distorted embroidery with Designer SE
have you tried changing the needle
try rethreading the machine top & bottom
also clean under needle plate area & bobbin area for loose threads & lint
Jan 27, 2012 | Husqvarna Designer I
My Bernina 1090 in which I have had for 20 years is not behaving itself! I will be sewing away and the stitch adjustment will just turn and no matter what setting it is on, the stitching will get...
if you just had it serviced & it has not been 30 days, I would take it back & have them check it again.
if that's your only sewing machine, I would recommend that you get another machine as a back up or a new machine & use the other as a back up
I have a mechanical & electronic sewing machine, that way if I'm servicing one I can use the other
Aug 01, 2011 | Bernina Virtuosa 160
The machine isn't making stitches. It's threaded correctly. I have been sewing leather recently and it's been acting up since then. I have cleaned the bobbin area. And have adjusted the tension...
Hello
Adjust the Stitch Length;
To make longer stitches, set the stitch length to a higher number. On many sewing machines, four is the longest possible stitch length and two is average.
To make shorter stitches, set the stitch length to a lower number. At a zero, the sewing machine may not actually make stitches, since the needle will go up and down in one place.
Cut a small scrap of fabric, preferably the same type you want to sew with.
Sew a few test stitches on the scrap. Examine the stitches to make sure they're the length you want.
Adjust the stitch length again as needed.
Jul 12, 2011 | Singer Sewing Machines
Kenmore 1764180 will not advance fabric, feed dog just doesn't appear to be moving. This has been happening intermittently but now will not advance at all and have been unable to get it to work. Any...
How old is this machine? At zero setting of stitching length the fabric wouldn't move. There may be problem in stitching length mechanism or the fabric feeding mechanism is wornout.
sonsunny
Jun 18, 2011 | Sewing Machines
I am new at sewing, my machine is sewing small stitches and then larger stitches, I need it to just sew small sitches
Check to make sure the stitch length gauge isn't loose allowing it to jump between longer & shorter stitches, or that it isn't set on variable stitching. Something that could create this too is if you're holding the fabric too tightly so that the fabric feed doesn't pull the fabric through smoothly & easily - allow the machine to pull the fabric through on it's own and control the speed with your footfeed, not your hands. Hope this helps! Have a good time!
Nov 08, 2009 | Singer 3116 Simple
Sewing Machines Logo
43 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
