Question about Baby Lock Ellure
Will the Elure ESL model accept a twin needle
I was told that your can use a twin needle with any machine. However I cannot figure out how to thread this machine for a twin needle. Does anyone know how to do it.
    Scholar:
  • 65 Answers
The site shows a twin needle setting.
http://www.babylock.com/embroidery/ellure/
Have you looked at your manual or bought the more expensive book from your dealer? I have found my book for my Evolve a VERY good investment (70 bucks, but worth every penny these past 2 years!)
Baby Lock have very good cust. service either on the web or right at your dealer. Most dealers will give free lessons upon request.
I hope this helped
Posted on Jan 25, 2009
Can I use a twin needle on a Singer Trafition? It seems to only sew one line of stitches.
Probably depends on the model. Was a twin needle included with your starter kit?
This one indicates it will take a twin needle:
2277 TRADITION
Your owner's manual or the product specifications are probably the best source for information.
Instruction Manuals
BTW, you are using 2 spools of thread, right? You need to thread both needles with separate spools (do not twist the threads when threading!).
Double Needle Tips Video Demos
How to Use Twin Needle on Your Sewing Machine
Be sure to verify the machine is set to straight stitch. Any zig-zag could break one or both needles!
You also will have to thread the needles manually as the needle threader will not work on twin needles.
ALWAYS RAISE the presser foot when threading the top thread!
Jun 22, 2017 | Singer Sewing Machines
Thread breaks on the 2340CV Brother. Doing two needle and the right needle is breaking at the needle. Change needle and retreaded several times
Probably depends what that needle is hitting that is causing it to break. Make sure the presser foot and the needle plate hole are large enough to accommodate the twin needle. Twin needles come in different widths so if yours is too wide, it would break. However, it could be possible that your machine is slightly out of alignment that does not show up until you try to use a twin needle. Also, make sure that your thread is not causing the needle to break--could be misthreading. Some machines have separate guides and tension disks for twin threads. Those that don't have that accommodation may have more difficulty using a twin needle.
Mar 07, 2017 | Sewing Machines
I just need instructions to thread a Bernina Virtuosa 160 for pintucking
Your owner's manual should have instructions for using a twin needle.
Most machines can use a twin needle. However, some machines have two tension disks so one can separate the two threads and get equal tension. (The Bernina 930 has two tension disks, so am assuming your newer machine does also.) Look at the top of your machine where the tension mechanism resides and see if there is a right and left side. In either case, do NOT thread both threads at the same time as the threads can become twisted. When threading the machine, ALWAYS RAISE the presser foot, thread one thread completely. If threading the left side of the tension disk, also thread the left needle. Then thread the second thread, making sure to use the other side of the tension disk and needle.
Just a reminder to be careful using any zig-zag or decorative stitches since a twin needle requires a narrower stitch width to avoid broken needles.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwiawf-507_RAhVHwlQKHQrnAXgQFgg4MAQ&url=http%3A%2F%2Fwww.itsastitchonline.com%2Fmastery_on_the_web%2Fmastery_153qe_163_1-4-02.pdf&usg=AFQjCNHHww3jbxbLXZYNj6vuCZE4-kVa8g&cad=rja
Stitching Odyssey How to use your twin needle
How to use twin needle So Sew Easy
Bernina Instruction Manuals
Jan 13, 2017 | Bernina Sewing Machines
How to use a twin needle on my SR2000 toyota sewing machine
First, verify that your machine can use a twin needle. Most machines take will use a twin needle will have separate thread guides and duel thread spool pins.
To thread it, thread one thread all the way through one of the needles and then thread the second thread through to the second needle. This will help keep the threads from twisting.
Toyota RS2000 Instruction Manual
Aug 25, 2016 | Toyota Sewing Machines
How to thread with double needle
You'll need to use two separate spools of thread. Machines that take a twin needle will usually have separated thread guides and two separate tension disks. Just make sure the threads are not twisted when threading. Might be better to thread one all the way through and then thread the second.
How To Use Twin Needles
Be sure to check the width of your stitch when using a twin needle. Because the needles will be wider than a single needle, it is very easy to hit the needle plate if setting it too wide.
Jun 11, 2016 | Elna 1010
How do I thread my twin needle on my SQ9185 machine correctly so as not to break the needle again. The diagram in the manual is a little "sketchy".
with twin needles
you thread the first needle like you would a single needle and then you thread the 2nd needle then same way
make sure the setting are fixed for a twin needle
Feb 28, 2015 | Brother Sewing Machines
Twin needle treading for singer sewing machine 3116
Yes, put your second thread in a cup behind your machine and thread your machine like normal
Jan 22, 2010 | Singer 3116 Simple
Sewing Machines Logo
200 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
