Question about IBM Office Equipment & Supplies
Storing key strokes on IBM Wheelwriter 6, Series II
This typewriter was donated to our company but without the manual. It appears that I can store keystrokes for things that I type over and over, but I don't know how to store them. Can you help?
  • IBM Master
  • 3,594 Answers
On the L. side of the keyboard are 3 keys store, play & delete.
To store hold the store key and type an address 1 - 99, release the store key and type info. press store again. To play hold play type address, release play. to delete follow same with the delete key. Be sure the batteries are good or you will lose data on power off.
DickyO
Posted on Jan 20, 2009
How to make multiple copies on IBM wheelwriter 30 series II
First be sure the batteries are are good and the holder is clean and making contact. On the L. side of the keyboard are 3 keys marked save , play and delete hold the store key enter an address 01-99, release the store key, type info, press store again. To reprint ho;d play and enter the address, release play.
DickyO
Aug 12, 2014 | IBM Wheelwriter 30 Typewriter
Ibm wheelwriter 6 Series II
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
Apr 28, 2014 | IBM Lexmark Wheelwriter 6 Series II
Data will not stay stored
I assume that the data clears when you turn off the T/W, if so the batteries need changed. Depending on the age of the machine they are either on the R. or L. on the base just beyond the keyboard, they will probably be corroded so be sure to clean the holder contacts.
DickyO
Feb 11, 2010 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 6 reprint key
There is no replay key on a WW6 however there is a memory.
On the L. side of the keyboard there are 3 keys store, play and delete, to store hold store and type 01-99 as an address release thwe keys and type info when finished press store again.
To play hold play and type address.
To delete follow same proc.
DickyO
Jul 22, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6 Series II
On the L. side of the keyboard are 3 keys store, play and delete.
To store in memory press and hold store key and type an address 01-99 then type what ever on completion press store again.
To delete hold del. and type address.
DickyO
Jun 11, 2008 | Office Equipment & Supplies
WHEELRITER 6 LOST MEMORY.
When it turns on do the lights blink and go out on the first key touched? If so the battery hilder is probably corroded. Clean the contacts with sand paper. When this is solved you can start storing again. The data is lost and can't be retrieved.
DickyO
Feb 23, 2008 | Lexmark Wheelwriter 6 Series II Typewriter
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
245 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
