I have recently purchased one of these for a Nintendo DS. The Nintendo DS manages to connect to it but it then gives me an error message indicating that it cannot connect to the server. I'm wondering if it has something to do with the router's incompatibility since I have turned off everything that could interfere with it including firewalls and such.
Nintendo ds should work with most routers it's just the set thats a problem, once the wifi game is in go to wifi connection one settings,then where it says auto obtain ip address click no, then edit,then use an ip address that is the next digit up from your pc or your router eg, if your routers ip address is 192.168.2.1( this is what you would type in your internet browser to get into the router settings), the next digit used by a pc would be 192.168.2.2, so use 192.168.2.3 or above incase you have more than one pc. Next is the subnet mask which should again be as the routers subnet mask which will more than likely be 255.255.255.0., press edit and enter that number Next is the gateway setting, press edit, this is the same number of your routers own ip address as mentioned earlier this is the ip address you type to get into the router eg 192.168.2.1. next is auto obtain DNS, again click no, then on the primary address click edit and again enter your routers own ip address. next is secondary DNS, again click edit and again enter your routers ip address, then click save settings. You should now be able to connect to your router and the wifi connection at nintendo server.
sorry but you have lost me, you say you were talking about wifi connector, this is the same as a wireless router, unless you mean something else; what is a wifi connector when you are refering to a ds it's built in and connects to a wireless router, you need a wifi (wireless) router to enable you to connect your ds to a network and then enable a conection to the Nintendo server, how else would you get a ds to connect, you have to have a router and the settings that i gave to set up the ds to connect to the server
if you have posted the correct model router, it is not wireless and there is no way you can connect a ds by wifi unless you have a wireless router, the ds cannot connect directly to the nintendo server without your internet connection, i think you are trying to do something imposible without the wireless router, unless i am missing something
I am actually talking about about using a wi-fi connector not a wireless router. the reason i talked about my router was because the error help explained that it might have a problem with the router or something like that where it might not be compatible/firewalls ect.
http://en.wikipedia.org/wiki/Nintendo_Wi...
THAT is what i am talking about guys. Do you not know what it is...
