Question about Kyocera Copystar CS-1820 Black and White Copier
Can you help with a Kyocera 1820
The Kyocera 1820 will not boot up. It comes on but on the screen it only says Kyocera and sounds like it is running fime but the screen never changes to give me any options.
  • 523 Answers
You have firmware probem, its easy just laod the new firmware on a cf drive and you will be fine, i can help you in firmware.
Best regards
Posted on Mar 01, 2009
Copistar cs 1820 not boot, the panel is locked
It sounds like you have a bad control board or EEprom.
Feb 08, 2011 | Kyocera Copystar CS-1820 Black and White...
How to change email addfress for fax
Instructions for registering and editing the address book (fax, email, scanning destinations) can be found on page 5-21 of the advanced operations guide wich can be down loaded from the following link; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14173&rid=14774. THe KM-1820 and CS-1820 are the same machines and this link is for the KM-1820.
Jan 17, 2011 | Kyocera Copystar CS-1820 Black and White...
How do you make a kyocera KM-1820 make 2 sided copies?
Hello, The Kyocera KM-1820 does not support automatic duplexing (double-sided).If a double sided copy/print is required you would have to do it manually, print the first side, then flip the paper over and run it back through the printer again for the second side.
Pre
Jan 14, 2011 | Office Equipment & Supplies
I have a kyocera km 1820 copier at work and cannot figure out how to navigate it to make 2-sided copies???
The Kyocera KM-1820 does not have an automatic 2-sided option. This is why it cannot be found in the settings.
May 20, 2010 | Kyocera Copystar CS-1820 Black and White...
Kyocera cs 1820 error 2102 using ftp
I reset the IP adderss to another printer on the network and it worked so it looks like not all printers are compatable
Jun 17, 2009 | Kyocera Copystar CS-1820 Black and White...
Where is waste toner on kyocera 1820
TO empty the waste toner on a KM/CS 1820 you have to remove one of the side covers from the drum unit on the machine and vac out the old toner i've had customers try to reuse the toner please do not do this. just vac it out good and your normaly good to go!!
Apr 08, 2009 | Kyocera Copystar CS-1820 Black and White...
Kyocera cs 1820 or copystar = error message = 3200
3200 is a problem with the exposure lamp. If you are in a dirty enviroment, the problem could be dirty mirrors under the scanner glass.
Apr 02, 2009 | Kyocera Copystar CS-1820 Black and White...
Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Oct 20, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera Copystar CS-1820 Black and White Copier Logo
223 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
