Question about Dinosaur D-rex Interactive Dinosaur By Mattel
D-Rex won't walk. Motor is running, but legs won't move.
He moves his tail, eyes, head, growls, burps, roars, but is very still when the leg motors are running. Is there any help?
How do I take motor off boat? there is no lifting eye or bracket.
normally a job for 2 or more people
one way is to remove the retainer bolts and undo the clamps on the transom
have a mate lift the front of the trailer so that the leg sits on the ground and the transom moves below the clamp plate while you steady the motor
lean the motor back slightly while he lowers the trailer down then he can come around and help you lay the motor down onto the ground
to move the motor around use something like a fridge removal trolley where the clamp plate can hook over a bar with the leg sitting on the bottom of the trolley
Oct 09, 2015 | Boating
Steering wheel wont move right or left engine wont move don't want to force it
inboard or outboard motor ??
unbolt the steering cable from the steering point of the engine or leg unit , then try turning the wheel and if it moves then try moving the engine or leg unit and see if it moves !?
Mar 27, 2015 | Boating
Car making roaring noise
double posted, now roar. not growl, back up 1 post.
Jan 23, 2014 | Honda Element Cars & Trucks
D-rex dinosaur doesn't walk
You may have to conclude D-rex is defective. I have had similar experience with other complex toys.
Jan 16, 2014 | Dinosaur D-rex Interactive Dinosaur By...
2008 Jeep Liberty Starter Issue
cant figure out your post at all !
"When my car will not start it only growls & never roars/never turns over."
it either cranks robustly nor not
then and only the can it start, run
cranks
starts
runs
or maybe stalls
the dealer can fix it , if you demo it and it works.
its not broken then.
if it cranks correctly every time ,say so
that is a failed engine start.
if engine stalls, say so.
if rpm on the engine is real low, too low, say so.
the word turns over means nothing, Im sorry
1/2 say, it means cranking
other 1/2 means its running,
the order is
cranks, starts, runs , and keeps running or stalls.
btw if it stalls, its needs a tuneup'
get one in last decade, (sparks filters)
my guess growls is starter sounds
so if it starter works try cranking with throttle wide open
this is super secret unflood mod. it cuts fuel and clears flooding.
Good engines that fail to start are
bad spark plugs
flooding
starving for fuel.
we discount them 1 by one until. bingo
Mar 08, 2017 | 2008 Jeep Liberty
Tripod leg stuck
loosen the allen head screw for that legs snap lock
Mar 13, 2013 | Manfrotto (190XB,128RC) Tripod
Having trouble with my 1997 lincoln continental i changed the radiator thermostat and the water pump and it still over heating please help
Have you burped the system? If air gets trapped it can prevent the thermostat from opening and make your engine overheat. To get the air out, start with a cold engine, turn the heat on vent or floor only and run full blast, run the engine with the radiator cap off until it gets to operating temperature. Keep an eye on the coolant level and add as needed until it doesn't drop in level for five minutes. Some cars may require removal of the thermostat so you can drill a small hole in it to allow air to escape from the engine side of the thermostat. Keep any eye on the temperature gauge to make sure you don't over heat it while trying to burp it.
Nov 17, 2010 | 1997 Lincoln Continental
Dinosaur D-rex Interactive Dinosaur By Mattel Logo
97 people viewed this question
Top Dinosaur Toys Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
Mirela
Are you a Dinosaur Toy Expert? Answer questions, earn points and help others
