Question about Sony Cyber-Shot DSC-W7 Digital Camera
Camera will not operate when power is turned on
Every time I turn on the power I get a message on the screen telling me to turn the power off and then on again. When I do this the message repeats and repeats and I cannot use my camera. My battery is fully charged.
  • Lynn Johnson Jun 30, 2007
    When I tried the power on again I got the same message and I did notice that nothing opened on the lens. Before I contact sony repair, are there any other possible solutions?
  • 944 Answers
It is just possible that vibrating the camera can free the lens mechanism. Put the camera on a towel on top of the washing machine for a couple of minutes, or take it for a drive. If this does free the mechanism, whatever it has shaken free is still in there somewhere, so even if the camera seems to be working fine it is worth getting it serviced anyway or the problem will probably reappear. Hope this helps, Dinoza is right - there is little that you can do inside yourself without serious risk of destroying the camera completely :) PS If you need us to find you a service centre, please post back with your general area and we should be able to find one close by.
Posted on Jul 01, 2007
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
From sony support site "The error TURN THE POWER OFF AND ON AGAIN will be displayed if the lens assembly is not operating correctly. Ensure fresh batteries are installed or make sure they are fully charged and then try turning the camera off and then back on. NOTE: If the error message still occurs, service may be required." I think you can pass on checking the battery. obviously your lens mechanism is somewhat busted (usually this happens when a camera is on and put in the pocket then the zoom button gets pushed and the lens tried to move with no avail, or sand that got into the mechanisem), and you'll have to get it repaired. However, If you are handy or daring :-) you can often clear the problem by removing the lens assembly and using compressed air on it to blow any grit out of the way. To dismantle the actual assembly can be really asking for trouble as they can be mongrels to put back together. But if you're methodical and have a good memory you may be lucky. I'm sorry there's nothing I can tell you which is DIY. Use your warranty if valid. Good luck D.
Posted on Jun 30, 2007
SOURCE:
My Sony DSC-S60 camera lens in stuck open and my camera is stuck on access. It tells me turn off camera then back on. I have done that several times with no luck
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Sep 10, 2011 | Sony Cyber-Shot DSC-S60 Digital Camera
Configuring display language, Date and Time Settings.
Perform the reset operation to initialize the camera’s setup (page 136). After that, configure each setting. If the language selection screen does not re-appear when you turn the camera on, it means that the camera’s built-in memory management area has been restored. If the same message appears after you turn power back on, contact your retailer or a CASIO service center.
Main support number800-962-2746
http://www.fixya.com/support/p504372-casio_exilim_ex_z1000_digital_camera/manual-19919
Jan 29, 2008 | Casio EXILIM EX-Z1000 Digital Camera
The lenses were stuck and on the screen it says "lens error".I do not know how it happened. We were just taking photos and when we are about to view them, it vibrated then turned itself off.
This message appears when the lens performs some unexpected operation.If the same message appears after you turn power back on please check that if there is something which blocks the motorized movement of the lens.If so clean it with cotton swabs or soft cloth.After cleaning power off and on again repeatedly two three times.
Jun 04, 2011 | Casio Exilim Zoom EXZ33 Digital Camera
Turn the power off and on again message
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
I do have the same problem
You can tell Sony and maybe they can fix it.
Jun 07, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Failure to operate - reimsert battery
Replace the battery. After you turn it off for a while, the battery comes back just enough to allow operation for a short time. After that time is over, the camera doesn't operate. Then if it sits for a while, the battery can power the camera for another short time.
Feb 01, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Black screen
Turn the power off and on again message is displayed when the Lens mechanism is stuck or when there is an internal malfunction. To resolve the issue, try turning off and on the power for few times. If the issue persists, try power resetting the Camera.
To power reset the Camera, remove the battery from the Camera. Press and hold the power button of the Camera for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery to check the operation.
You can also try Initializing the Camera by selecting the INITIALIZE option from the SETUP1 Menu of the Camera.
Thanks for using FixYa
Nov 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Help!
i have the exact same camera as you..
i had the exact same problem as you did too..i got so mad
this worked for me, so i think it will work for you
1.take the batteries out of the camera
2.hold the power button for 30 seconds
3.let go of the power button, and wait 1 minute
4.stick the batteries back in
5.turn the power on, and it should stop acting crazy
if this helped, great
Oct 04, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cybershot DSC W50
when I turn the power on screen is blue with "access" message. after a few minutes, message is replaced with "turn power on and off". I have removed and recharged battery but keep getting the same message and other functions of the camera will not work.
Apr 30, 2008 | Sony Cybershot S650 Digital Camera
SONY
The lens element is damaged internally and needs to be replaced as an entire unit. The camera runs through a "self check" each time it is powered up and it is detecting an error in the lens. Ship this unit to Sony in Laredo, TX. The warranty may not apply if they see there is impact damage to the lens. The flat rate repair charge will not apply here either due to physical damage to the lens element. be sure to request an estimate before the work is performed. Hope this helps you, we see this problem all the time with digital cameras that have lenses which extend during operation. Joe Weibel Custom Electronics (customelectronics.org)
Mar 18, 2006 | Sony Cyber-Shot DSC-S90 Digital Camera
Sony Cyber-Shot DSC-W7 Digital Camera Logo
41 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
