HAVE SANYO WASHING MACHIN AWD-A845ZT .SHOW IN DISPLAY ERROR (U2) PLEASE HELP ME panel
My machine sharp MX 3100N is giving the error code U2-05, what steps should i use to solve it
This error refers to a discrepancy between the HDD & the machine. If the hard drive has not been swapped out & nothing has changed on the machine then try resetting the copier to see if that rectifies it.
To reset the machine you will need to enter simulation mode.
First, make sure the copier is in COPY mode.
Then press the following 4 keys in quick succession: # * C *
You should then have a screen showing simulation mode.
Then enter 16 & press either of the copy keys (black or colour).
This should then display U2 ERROR RESET.
Press EXECUTE, YES then press the CA key.
The machine will exit simulation mode & restart.
If after restart the machine displays U2 again then you will probably have a HDD fault. Unfortunately, the HDD would have to be replaced by an authorised dealer as new Firmware would have to be reload to allow the machine to recognise a new HDD.
Hope this helps.
Dave.
Jan 19, 2017 | SHARP MX-3100N
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Sanyo washing machine AWD-703HCTP DISPLAYED EH1 ERROR CODE what is the problem
    Maybe you have solved your problem, but if not, I haven't much good news, just a website with more info about Sanyo washing machines. That division of the giant Sanyo was sold to Panasonic.
    The link for more about the washers is...
    http://ashachine.info/sanyo-washing-machine/
    Good luck.
    Nov 25, 2014 | Washing Machines
    Hitachi washing machine error code Fb indicates problems. what prolems is that? Can you list out the meaning ot each error code.
    My washing machineSF-110SS
    have a display FD. Anybody know what's that means? And how to solve it. Please
    Jun 23, 2011 | Washing Machines
    Hi My Sharp AR-275 has problem of U2-40 now. I tried Solution 1 or removing toner cartridge and replacing the same one (because there is still 50% left). And also I tried Solution 2 or press #...
    The U2-40 error is the machine telling you that there is a communications error with your CRUM chip.
    is there anything at all displayed on the screen??
    if there is, press the #, interrupt, C, interrupt in rapid succession. If you don't know what the interrupt button looks like, it is the third button from the right on the control panel. You may have to try it a few times, as with age, the buttons are harder to push so they register that you are pushing them. Once you get into the simulation mode, press 16, then start, and follow the on-screen instructions. once the machine has reset the code, usually shows by going back to the main code screen, then press the CA button, or "clear all".(second button from the right) that will reboot the machine and hopefully clear the code.
    Nov 03, 2010 | Sharp AR-275 Copier
    My washing machine is SANYO ASW-90WRTP. showes E4 on the screen. I guess it means Error 4, but I don't know how to solve the problem. Thanks.
    Check on the machine there is a schamatic and it has error codes on it. it may be on the in side panel.
    Oct 11, 2009 | Washing Machines
    Sharp AR 5316 E photocopier error clearing
    Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
    May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
    Washing Machines Logo
    Top Washing Machines Experts
